Content Count
52 -
Community Reputation
9 NeutralAbout L0n3Ly.Kp
Rank
Advanced Member
Local Area
Christchurch
anyone got a good condition spare alternator or a voltage regulator for a kp61 that i could borrow to check why my alternator isnt charging my battery? kind of getting sick of working on my kp hahah
Kp61 Worked 4k stage 7 racing cam - Help needed
L0n3Ly.Kp replied to lonely.Kp's topic in South Island Region
I'm around the burnside area, and yeah that'll be perfect if you could give me a hand!! hopefully someone here can help me get my beloved toy running again -
oh didnt know there was a south island section, and maybe I'll post on club k -
New Zealand, Christchurch -
so yeah all I know for sure at this point is that it's got a stage 7 racing cam, 40mm side draft carbs, electronic ignition, but I'm sure there's a lot more done to the engine because it ran couple seasons and was running before it was pulled... -
well the engine was from the minisprint rebuilt every season for the minisprint, worked to speedway standards, the chassis got written off and the engine was running before it was pulled out so I'm not 100 sure what the problem could be -
I had a look and seems like there still is a little bit of wire connected to the coil from the old looms I'll see if it works without those two -
oh wow think is super helpful!! thanks a lot will have a read and play around with the dizzy!! -
ohhh right I'll have a look at that, check and check for sparks -
to the block? ahh sorry I'm kinda new to cars only just did my first engine swap by myself hahah -
I've got a xr700 electronic ignition but not sure if the black box needs to be programmed hahaha oops -
yeah it's got a fireball xr700 optically triggered ignition system, not sure if the black box needs to be programmed or something -
thanks will start from there, I've got fuel, and air (hopefully my side drafts are working) and will check for spark, but the motor was pulled out while running and I haven't played with the dizzy yet so hmmm we'll see, hopefully everything will be all good!
