First time posting, sorry if I've done anything wrong.
This is my 1966 Mk1 Triumph, was my dads but he doesn't have any time to work on it so it now mine
Discuss:
Originally had a 2000 motor with auto gearbox but was changed over to a fully rebuilt 2500 engine with Tr5 cam, auto box was replaced with a manual overdrive around 96' I think, also was repainted around that time. Motor has only done 10000km since then. Failed a warrant in 2006 and has basically been sitting since then.
To Do List
Rusty Brake Lines
Fuel Pump Rebuild
Rust R/H Door Pillar
Rust in Doors
Rust L/H Door Pillar
Rust Front L/H & R/H Sill and Boot Floor
U Joints need replacing
Rear axle gasket needs replacing
Suspension seems higher on one side? Think needs new or rebuilt struts
Sorry about the pics but don't really have any of the car actually looking complete.
Car has basically been stripped on the outside. There was lots of rust bubbling out partly because of it sitting in a carport for 7-8 years and partly because of the bad paint job and repairs done previously. Dent on front where cat had knocked a piece of wood onto the car
Engine runs great. Radiator has been flushed, new oil and spark plugs. Water pump and thermometer gaskets have been replaced along with the rocker cover gasket Fuel pump also had to be rebuilt as it leaked.
This is the L/H front Inner fender, frame rail had almost completely rusted away. Basically same thing on the other side.
Wire wheeled and covered in rust converter, frame rail patch welded in.
Don't know what you call this but the water is supposed to run down here into the fender? Anyway rusted metal gone.
Probably the worst part on the car, Probably a centimeter of bog covering this, which rust had bubbled up through. Was a previous repair done with what I think was a gas torch, sand? and bog by the previous car painters. Not sure how to fix this. Ideally needs a whole new fender but 16 yo me is way to poor for that.
Anyway hopefully by posting on here I will have more motivation to work on this. Next planning on purchasing some por15 to do the battery tray and inner fender
