Posts posted by dmulally
Another decent milestone today in that the rear Goldwing radiator is installed. Can't say Im entirely happy with it but it should do for now. I might weld on some proper brackets to the radiator when I get a chance.
I was too accurate with my measuring of how high to have the radiator and the engine lid was too close for my liking.
So after a little more drilling and grinding I dropped it down maybe half an inch which was much more comfortable.
I did have to cut an access hole to thread the nut on the captured bolt on the rad. It feels stable enough. You can see the access hole here but it's hidden behind the bumper anyway. I'll put a bung in it just in case of water pooling inside it.
Filling was a bit of a pain and I havent even plumbed in the heater yet. I want to flush it a few more times as the water is a little orange still. Probably because I have been letting a mix of water and white vinegar sit in the engine passageways off and on and it has stirred up some muck. I havent put the heater core in the loop yet but I might do it when I flush next because getting the air pockets out has been quite time consuming. I used the hoist to lift the rear to help work some of the bubbles out.
I have got to the point where I can see the water in the filler neck rise no matter where I push on the hose so Im feeling better. I drilled a small hole in the thermostat so it takes time to fill it up I guess. The electric booster at the front didnt really do much when bleeding so I just took a hose off at the front and sucked it through.
Next on the list is to install the thermo fans in the front then sort the air filter.
- 16
Really interested to see what you do AC wise if it is a bunch of bits or a kit. Having a bulkhead would make it easier. Where the condenser will go should be fun.
Semi related but I was having overheating problems in my 66 chev so I moved the gearbox cooler from in front of the radiator to under the passenger floor horizontally with a derale oil cooler kit with a fan. Seems to work ok so far so could be an idea.
38 minutes ago, Flash said:
@dmulallyYep, full scoop already in place. It dropped the max temp a little bit. I'm getting a consistent 95C max in both traffic and at top speed these days. Still feels a bit high to me but she seems happy enough. I'm going to give the rad another flush as I still seem to have a bit of a brown tinge in the coolant when I last drained the system. Not lots, but just enough to stain the bottom of the bucket that I drain the coolant into.
95 at both high and low speed seems interesting in itself.
I think that's a fine temp though. Especially for where you are!
@Flash I'm sure you're all over it but have you put in an airscoop to the radiator in the front?
All the commer van's I have ever had have required it when lowered or they overheat at highway speeds.
On 20/10/2023 at 19:06, dmulally said:So I went with this one. Will vent nicely to the windscreen too.
I zapped it with some power and it is 6 volt. I hit it with 12v for a laugh and it nearly took off!
I gave it a little service which included cleaning out about 50 years of muck and dust and oiled any moving bits. I'll give it a little black paint then figure out how to mount it later on.
Finally got the heater mounted. I managed to get it so that the pipes are outside of the cabin and it isn't in the way of legs or the gearstick. The hot air tube to the windscreen needs something at the screen end but I don't have to worry about that for a while. Should warm the trotters up nicely in winter. I might bypass it all together in summer. See how I feel.
It is powered by a voltage step down converter to 6 volts.
- 15
On 18/11/2023 at 22:46, fuzzy-hair-man said:
The blue wires are normally closed, (on when the switch is off, off when the switch is on) you could use them for fail safe things like if the sensor or switch for a temp sensor were to fail the pump or fan comes on as default, although most sensors would be normally open, so you'd need to be specific about using the blue.
Googling the relay number it says its a accessories relay.. but only giving 5A to accessories seems problematic.. I know you could change it. Maybe one of the red positives is switched and the other is permanently live?
Right so the second red wire will go to the switches. With both connected to the battery the blue wires are off. Ill tape those off so they dont get into mischief.
Few more things to test but I dont mind wiring.
Im just about to test the red wires now. I hooked them both up to the beefy red wire from the engine bay but I still need power to the other side of the switches on the dash.
So either that number 1 relay will provide it if it's always hot or one of the red wires will have to come off. Stand by.
They sure do. $266 per single tank.
Now to figure out when the hell I'll be floating over by Porirua some time.- 1
Yep perfect sense. Thanks.
No idea what that relay 1 does. Has a wire less and is a little different to the others.
So I bought a fuse/relay box off Amazon. Looking at the instructions I'm a little lost. It happens. Can anybody smarter than me (that's all of you) please let me know which of the yellow and blue wires go to the fan/pump/whatever?
On 10/11/2023 at 22:11, Valiant said:
Try a garage that does LPG wof.
They should be able to point you in the right direction.
I tried that and the one they gave me shut down in covid lockdowns sadly.
I'll try the place @Nominal suggested and hopefully they can steer me in the right direction. This 25l/100 chev at around $3 is killing me.
I remember having massive dramas with this on my Commer van tank. For LVV I had to have a 1 way check valve on the breather and it made filling up awful. Used to just puke back at me at anything more than a trickle. I used to fill up jerry cans and use a hose line into the tank from that when I got home.
I ended up taking off the check valve which helped some. Then I made the breather bigger and plumbed it into the filler neck right near the top.
Probably didn't help where the inlet came into the tank at the half way mark:
Replying to this to prove I have at least tried to search.
Does anybody know where you can get your LPG tanks recertified? I'm looking around Wellington. I rang a couple of gas places in Masterton but they either didn't care or my aussie accent is too strong for them to know what I'm banging on about. -
Onto the rats and mice now the car is a runner so I'm trying to tackle at least one small job every day in the morning. Here are some pics of what I've ticked off this week. Nothing exciting but the wiring parts turned up today so I can start putting some fuses in (the car previously didn't have a single fuse) as well as the gauges. I'm a bit of a sucker for gauges so have spent a while finding what I think are the basics that I'll require. One of the pics below is for the oil pressure sender in fact. The other is new flexi brake lines to show the cert man I made an effort and also a pic of colour matched spark plug leads which I had to cut and shut as they were far too long stock.
- 24
Great news.
Clutch adjusted and no slippage. I should have taken photos but the clutch when I chiselled it off was rusted something shocking. I would have replaced it on the spot but owing it was a custom jobbie I cbf'd.
I couldnt get reverse initially but four forward gears werent a drama.
Took it for a spin and holy shit what a weapon. I thought the clutch was slipping in second until I saw that I had churned up the driveway with both wheels. The torque of the scooby brings shame and dishonour on the 875cc Imp engine.
I filled it with water and looped the hoses back on each other to get some flow and heat. Then with the engine off I stuffed the hose into it reverse flow and gave it a blast. Then went the normal way. Took a good couple of minutes both ways until the water coming out was crystal clear.
Thankfully reverse then decided to work (maybe it needed waking up after 30 years or so off the road). Then again probably all of it does. When I dragged it out the engine and starter were both locked solid.
Still so much to do but I'm enjoying it. Gives me a bit of a boost knowing it actually works and works well.
- 27
- 6
Whilst waiting for some wiring parts I couldnt help myself and rigged up some temp wiring to get it to start. Sounds fantastic and a shit load better than an Imp engine.
Clutch doesnt work and it creeps in neutral so Ill have to do some bleeding and adjusting on the fork.
It was hailing when I took this vid but in person it sounds so nice.
So next on the agenda is the clutch and getting a hose into the engine to flush out the crud before installing the rear radiator.
- 20
More for my reference as there are hoses snaking all over the shop. I changed the 16mm hose lines that snake through the body to 19mm. What an absolute shit job that is.
I'm not sure if I want the water running through the heater permanently or will attach it to a y splitter to bypass it. Mainly worried about coolant sitting stagnant in a shitty old core for 6 months at a time. Alternatively if I put in the Y splitter and the core develops a leak, it will take me two seconds to take it out of the loop.
I have collected some old heater cores over the years so will have to see which one has a fan (that is 12v and not 6v) and has no leaks.
- 9
Hoping the brains trust can help me. The only air filters I can find are pit bike ones on a 45 degree angle.
It is 60mm id. I could possibly get a 45 degree reducer to 50mm and then use some VW beetle aftermarket chrome ones.
I do have one ramflo but it wont fit without some pipe cut at an angle between.
Open to ideas.
dmulally’s 1965 Hillman Imp
in Projects and Build Ups
Some notes for myself:
Tacho wire snapped off
Rear rad needs a fan
Pops out of gear on deceleration
No reverse
Leaking from input shaft
Needs heavier return springs on carbs
3500rpms at 60mph
Lovely that it's going hard but I think the engine is too much for the little box. Shame the ea71 that is in it doesnt share the same bellhousing pattern as the ea81 to vw adapter I have.
