Bellicose
Everything posted by Bellicose
  1. Well sh*t, nothing like keeping a thread up to date haha..................... So finally got some colour on the X and got it together to make sure everything fits. Floorboard isn't the one i'm using but it's what i have at the mo'. Will ride it around a bit over summer then pull it apart and do all the stuff i should've to start with.
  2. Bellicose
    PAINT THREAD
    Definitely over black. Just use black base coat. You just put the binder/pigment mix on like basecoat, it's easy as.
  3. Bellicose
    PAINT THREAD
    Cheers. Yeah i'm a car painter, been in the trade 35 years. Reason i ask is iv'e seen people put the pigments into already made colours and wondered why their fancy pigments do f all lol.
  4. Bellicose
    PAINT THREAD
    Cheers ears. Did you put the pigment in a binder?
  5. Bellicose
    PAINT THREAD
    400 for solids, 600 for metallics. Don't use a scotch pad to "sand" anything. I only use a scotch pad when I do blends into other panels, but only after iv'e gone over the blend panel with 1200. 400 wet is closer to 500 dry. I used to do everything 'wet' but now use a Festool dry sander and haven't looked back.
  6. I was doing that kinda stuff in oz in the early 90s. Done a f**k ton of old minitrucks and drag cars in that style. Long live the 'heartbeat' pinstripe, palm trees and checker boards lol.
  7. Have painted hundreds. (well probably not hundreds lol) What's ya plans for it?
  8. Have had a bit of a play around with different things and will be going with a rubberized coating with body colour over that for the floorboard. Yeah man no prob'.
  9. Bellicose
    PAINT THREAD
    Code = cheap ass job........ Looks to be about 3 different colours so which one do you want?
  10. Bellicose
    PAINT THREAD
    Have you only gone through the clear? If so just flatten with 800 or 1200 then just re-clear the whole panel. Easy as mate.
  11. Bellicose
    PAINT THREAD
    I just used 407 and put filler primer over that. Haha, i used to use Epotec as my base under the 407 on automotive stuff and it was mint. Wouldn't mind getting ahold of more 407 but can't justify the cost for the small amounts i'd use tho'. We used International marine epoxys on the stuff at work because of warranty tho'. Be sure to mix Epotec absolutely precise with the hardener or it'll stay soft for far to long and cause drama down the line.
  12. Bellicose
    PAINT THREAD
    When I was doing super yacht stuff I used to use West System 407 microbaloons on cars instead of poly' bog all the time. Worked well.
  13. Nah man. Waiting on spacers, tyres and me to make up my mind on a colour for the plastics.
  14. Bellicose
    PAINT THREAD
    If you end up going the way of the vid's just be VERY careful near the panel edges. If you look closely you'll see a "build up" of paint on them. If you try to flat them to much you WILL rub through. It's not so much a "build up" of paint, more a raised area of panel where the skin is deformed when they fold it over the lip when made.
  15. 1200 is easy as. Nope. On to it. Pretty much. Although i have many solutions when i get runs, but those two vid's will help ya sort it.
  16. Also never had an issue, and you can't get bigger panels than this......lol
  17. Add 70-80mm spacers and you'll get an idea of how wide the arse will be on this thing lol.
  18. Bellicose
    Dio ZX AF35
    I'm interested in these if Naoks isn't.
