Hello guys,
I know it is a little bit old topic but I was wondering if somebody can help me.
I have a Corolla ee80 with 2e engine and the other day that I was trying to change the water pump, I checked the timing belt and reallized that the timing marks don't coinside with the service manual. When the crankshaft is on mark the 2E hole on the cam shaft is a couple of teeth ahead.
Is it a fault of the mechanic that had replaced the timing belt, or is it normal? Should I reset it to the manufacturers positions or can the set position be correct?
Thank you advance
