Everything posted by MaxPower
!!!!!!Hanmeet 2024 23rd-25th August - Entry Form is up now!!!!
MaxPower replied to JustHarry's topic in South Island Region
Flights booked home, sigma may or may not make the journey. Place bets now -
I’ve got a complete 3.8 series 2 from a Camaro with gear bag been trying to sell for $600 if it’s any help. Has the funny front inlet manifold
Complete mounts, although if you’re running a 4g52 they may work too. Must be fairly rare wagon , had a few 1850 colts back in the day yours seems to have the same front.
Early 90’s mitsi Ute gearbox seem to be the better (less shite) box which should bolt up to your new motor, use the 2L petrol 4g63 one and not the 2.6 , any single cam 4g63 engine mounts will work too. Did it come with an ecu?
Arduino Bongo Turbo Diesel ECU - Discussion thread
MaxPower replied to R3spct's topic in Project Discussion
Have you looked into a gfb d-force controller? I have one on my landcruiser and it cuts the boost a bit if the egt gets to your set temp, have been pretty happy with mine. -
used to install underfloor heating (water) back in the day , boss used to say your solar collector size would need to be the same size as your floor area to be efficient. Which no-one ever went ahead with. Not sure if this is relevant
Do you have any measurements for the springs? I have a set of new falcon springs at home but don’t know what model they’re from, they’re blue and quite short.
There are about 50ish of these going in the skip this week, ex stadium leds, however quite a few of the drivers have blown but the leds are mint, are they worth salvaging? The new drivers are over $300 on Ali. Each big panel has two lights and two drivers at a total of 600w. They go hard for what they are, will sling a few up around the shed
Have you tried going for a drive with the hood off? Does it still boil over at idle with the bonnet up? Is it worth going to an electric water pump so you can run a big fuck off electric fan?
I have a kubota d722 copper radiator that’s brand new , might be worth googling specs to see if it will work , I’m never going to use it.
Tauranga / BOP Monthly meet - Discussion Thread
MaxPower replied to Connor's topic in Upper North Island Region
I wish but preggo wife and kids at home thanks -
Ah sweet guessing normal sharp drill bits will go through the ram with some lube
MaxPower replied to h4nd's topic in Other Projects
Some of you may remember my welding skills from such episodes as welding a tow coupling on with half a damp rod on east cape ride. Today I put those skills to use and made a steel rack and wished I had done so a long time ago, am planning on putting a drop saw in the middle.- 1288 replies
- 15
Am building a hefty log splitter soon, how do I join my hydraulic ram to my splitting plate without special tools? Not much force should be on the return stroke . Need to be able to rebuild the ram in the future too. Thanks
4V Century V8 powered Dyna Camper Discussion
MaxPower replied to HumberSS's topic in Project Discussion
I have a front cut off a 1995 Toyota dyna for cheap if you go down that Rd, had a 15b diesel in it, sounds like quite a lot of work this v8 engine would you be better off with a common Toyota diesel like a 1kz or 13b diesel? I’m sure the v8 would sound the goods though -
4g63 single cam, will use less gas too
Tried this on a Mitsubishi Outlander , buying 98 vs 91 did 3 tanks of each and got the same results. 450km to 50L fuel
Made a shitty planter out of an old cylinder, brazed up the holes and put some pipe round the top for safety left a hole in the bottom for the rain.- 1288 replies
- 20
Eastcapescapade 2021 November 12th, 13th, 14th
MaxPower replied to johnnyfive's topic in Upper North Island Region
Chur will give ct a hoon has never failed me in the forestry blocks -
@johnnyfive giz spare second bike plz? Scoot crapped out again and lack of talent to fix. If not I’ve got a dodgy ct200. Looking forward to side of the Rd sausage -
Got scoot running again yesterday am turning off all devices now will see you’s Friday
