Everything posted by M.H.
And if you do find yourself getting stuck dont keep spinning until its beached as
What pressure were you running when on the sand? Worn out at's at low pressure (around 15psi) work well on sand,
How much are you wanting to spend?
Easily fixed be spacing them out
Ive been keeping an eye on this for a future project http://www.trademe.co.nz/business-farming-industry/industrial/engines-motors/diesel/auction-1368749203.htm?archive=1
1kz would be such a bad choice, will definitely want a truck based engine. What type of transfer case are you thinking of using
Also the isuzu engines have proper truck gearboxes behind them with cable operated shifters and a drum hand brake
Isuzu 4bd1t. 3.9l 4cyl diect injected turbo. Super strong, last for ever and capable of making serious power I have one that im fitting to my 110 land rover
Its easy as if its been legal before, ive got an xr600r im just about to re register after a bit of a tidy up
That xl looks like a nice survivor
2 Trailer Loads of Death... Mostly Gyro X build thread
M.H. replied to Raizer's topic in Other Projects
Hydroforming -
Can get them for $200nz plus gst
Ive sent that to mum as she works for abb so can probably get a bit of a discount
Are you definitely getting full voltage to your current lights and are they adjusted properly? Standard 55w bulbs are more than bright enough
Might need some more fuel while cranking
You dont need suspension on the 3 wheelers, my yamaha has no rear suspension and seized front suspension but the tyres only run a few psi -
I just went past on my way home, carpark is pretty busy, I'd recommend going down the side behind the anz and warehouse
- 63 replies
- business meeting
- have your say
(and 1 more)
Tagged with:
LT95 gearbox on tardme, http://www.trademe.co.nz/Browse/Listing.aspx?id=1373600944
The 407 with the 2.7hdi go pretty hard for what they are
It's easier to just reflash the ecu to never use the egr and just leave it on there
I looked at one for my land rover but decided to go with a quality recore, cost $700 though
A 200tdi will bolt in pretty much and is a better engine than the 1kz
Pretty easy to fix the chassis rust. I have a 110 that im dicking around with, have stripped it right down and will get it sandblasted. Tbh if you are wanting a coil sprung chassis it will be easier to buy a 110 or a 90 if you want swb.
