Everything posted by h4nd
it was this: Ah, ok, some bogan had put the bolts in the wrong place, and the long one eventually wore through the water jacket. I had a think, and realised the cooling is only 15psi at ~100deg C, so, JB Weld! Tickle up the top of the piston Button up the top of the engine Then decorate the front of the Prius...
- 81 replies
- 18
Except it wasn't So, I popped the top to have a look. HMMMMMMMMMM Yuck LHS cylinder, ooookkkkaaaay..... RHS: It took me a day to realise, but something about that RHS was just scratching my brain. (More story later, Milk bottle lolly prize if you can spot the problem already).
Then it started leaking coolant at work. I'd only just got the rad patched up, so, damn. Then I realised it was just the always wet leaky gutter at work:
- 81 replies
Set the points and check the dwell with the meter @governorsam gave me (thanks man!) running out the bonnet: Sweet, set.
- 81 replies
Except, no. I got to pondering the battery fail. I have a phone charger with a V meter. So I plug it in, and start watching. After a start it's between 13.8 and 14.5 as it should. Then after 5 min (replacing the charge taken by the starter motor), it started climbing, the gauge started flashing at 15V (nice feature), so at 15.7V, it's pretty clear why the battery was boiling off and putting white crusty around the terminals. Ah, oops. 5 or 8 years ago, it had that problem, and I took it to an auto-sparky, but now I think about it, it's killed a couple of batteries since then. Testing, testing: I put it on a variable power supply, it makes a cute buzzy noise. OK, looking closer, he'd bent the high-V contact away (incorrect, there's a spec gap), but the switching V was also incorrect (too high). So I set the gap in the contacts at the bottom correctly, and adjusted the switching voltage by bending the tab holding the resisting spring (per online guides). It Bench tests OK now. Tossed it back in the car. It's a shade low at start when idling, but now comes up to correct V, and doesn't over-charge. Golden. I wandered down to the battery merchant who'd been a GC, and told him it was a car electrical fault that killed the battery. He wouldn't accept payment for it, just told me to let him know if I was ever selling! Cool. People can be really good, if you treat them right.
- 81 replies
- 22
Got the Dai running 5m after this was 'sposed to begin. Even got the other cyl running 1/2h after that LoL. Thanks Karl, EJ, cookers and drinkers good to see e'ryone.
Heads-up: Marshland road is closed for part of the way. Find another way, pizza boy! https://ccc.govt.nz/transport/traffic-updates/travel-news/show/222
^A1 dad there, protecting bubs. Top marks.
Is this one of those, 'all easy if you lift the body off the k-frame' jobbies?
Kinda impressed that you ticked up +10°C ECT in 15 seconds!
This guy did it, (below). These servos should track 0-full in ~1/2 second (test 'em first) https://www.jaycar.co.nz/arduino-compatible-9g-micro-servo-motor/p/YM2758?pos=1&queryId=fd47b6f1a1e862373396fd71c281927d https://www.youtube.com/watch?v=eDLsrjLIHxM
The right time to test it would have been when everything else was working, but, meh, er'body too busy. I blame the trillionaires.
The other one is here with a set of bodgy repairs, exclusive warranty! (excludes damned near everything). Will cost beer.
pics? (joking, honest)
Low key underbody preventive work, no big deal.
Thanks folks, appreciate the support for both our tin benders.
Thanks folks. Next: "Do you have that one with that guy who was in the movie that was out last year?" https://www.google.com/search?q="Do+you+have+that+one+with+that+guy+who+was+in+the+movie+that+was+out+last+year?"
Ummm, I think Karls guy? I'd have tagged Karl, but I can never remember his username.
Hi yo, ol' mate Warrick runs a shop doing panel repairs now, I think. Can someone fire me come contact details? Chur
Ah, once in a blue moon I look at facebook. I think an event has been added...
Strong .jp emphasis tonight. so I get to set the topic of every sharn... Oh, man, they have gluten free, so good!
Should be fine, give it a go
Yeah you want a 12V charger with up to say 30-36V input. Batt size depends on how long you want to run the stereo. Charger current depends on how fast you want to recharge (battery will limit this itself in practice, unless you crank the V up), and if the stereo will be running at the same time you're charging (probably), but, at a guess, one of these would do it: https://www.aliexpress.com/item/4000238066768.html It's for solar, but it probably won't care, and you get lots of displays and functions and settings to fuck with
