chris r
Everything posted by chris r
chris r replied to johnnyfive's topic in Upper North Island Region
Me if I get my scoot ready -
I had a sharn to my gearbox guy and he said the carbon synchros are good but often the springs etc are fucked so I'll be ordering a oem kit for now Yip that's the plan Since the gearbag has to be opened to fix the synchro i ordered this. Its only a helical but i don't do enough motorsports to justify a plate diff
Reassembled and made one carb out of the two I had. Wound it over and nothing happened, gave it a dose of crc and a couple of coughs but that's it. Im guessing the barrel is too scored or a tad oversize and tge rings aren't sealing properly. The barrel seemed to slide over the rings too easily when assembling it. I went to measure up for a new rear shock and realised that the starter was hitting the mount. The mount will clear the starter, but once its flipped its not centered anymore. Back to the drawing board for that one. I dummied uo the plastics to feel like I've done something today. The dio triple tree is a interfere fit with the plastics so out with the hole saw .
Making up a lead ends up relatively spendy as the flex(cable) is fairly expensive.
Thr melody i got for parts is in better condition than the 'good' one. Looks like it got warm and ate some rings. I measured and @Raizer ordered me a set of rings. I choose the least scored piston and gave the barrel a quick hone to knock off the rough edges. I'll fit the other gudgeon pin circlip and make a good old cereal box gasket and see if it'll run
I might actually be in something os for once
I didn't trust myself to get it straight any other way really. I eyeballed the angles and they looked to be the same. I guess I'll find out how it behaves once I get it running
I needed to somehow get the Dio stem to fit onto the melody frame. The melody tube is longer and thicker than the dio. Since IT was thicker I gambled that the thinner dio stem tube would fit the melody. Both frames had a date with the grinder and it mostly worked Melody vs dio I'll save those bits for mounting the plastics later Some A+ Grinding skills Couple of tacks and a test fit, Its a bit high so I raised the tube as much as I could. GTFO stand, I can't mount my engine properly In my wisdom I threw out the dio handle bars and of course the melody ones don't fit the Dio stem. I think one of the other nifty bars fitted the dio stem so I'll check my hoard
I did a quick pre check. Windscreen washers don't squirt and horn does not work. Pump was making noises but nothing coming out. I replaced the pump then the switch decided to break. The horn wasn't working as its meant to earthed through its painted mount via the single tek screw holding it in. Since tek screws are clearly gm approved I added another with a bit of wire and it's working. Quick trip to jaycar and one of the many switch holes was filled with a toggle switch for the washers.
Seat belts are in and after a bit of encouragement the doors are open. I managed to get the drivers side latch out and had and figured out why it was jamming. It was full of old grease and Arizona dust which had mixed with the rain water to jam everything up I gave it a good dose of brake clean and re lubed everything and its working perfectly now. Probably the best it ever has in my ownership. The passengers door latch was in much better shape so I gave it a dose brake clean in place. Quick late night trip to washworld to get rid of all the bird shit and its ready for a wof tomorrow
Last time it jammed i pulled it apart from the inside abd spent hours fighting with it. Couldn't find anything jammed external to lstch mechanism or faulty central locking solenoids
Pro tip: Don't work on your cars when jetlagged. I managed to get the passengers door unlocked but the rod came off the latch mechanism in the process. The drivers door lock is jammed/fucked and I broke the plastic knob trying to get it un locked. Anyone got tips/tricks on getting this fucking thing open? I've tried nothing and am all out of ideas
Tortron's 3.8 Mayte fair dinkum Mitsi Ute
chris r replied to Threeonthetree's topic in Project Discussion
Roof/canopy setup looks lush. Might steal some of your techniques for my wag Nats 2.0 setup -
New belts. Plastic buckles not the metal gm ones but having belts that hold you in is more important
I should be in the area too for once
I've pitched my own tent. No need for that fancyness -
Yup I'm keen. -
Im planning on coming. Also attending the ride. Just need to get a bike together -
They only have a listing for the truck, i should measure mine and compare lengths
Bunnings special, you need about thsr msny bits to drill a hole
I finally listed this on Tardme and of course it decides to play up. I did a pre wof check and both seatbelts are fucked. Drivers side wont lock and the passengers wont retract. I fouund the gm part number on the passengers side belt and I can find no exact replacement. I'll give awfe etc a call next week, Failing that can anyone recommend a seatbelt barry to go to? Blead the brakes thought and they are now OK
Nothing like basic maintaince shots. New rear pads and rotors. I got a deal on the hp+ pads for the front. The rotors are OK and just needed a skim. I'm hunting down some radius arm bushesand some early accord radius rods. Third gear still crunches at high rpm, if/when i pull the box out ill get a aftermarket lsd as the factory spec viscous one is unpredictable
Master is in but i still need to bleed the brakes properly. I sorted a few little things that were annoying me today. The blower motor was making a hell of a noise and wasn't moving a lot of air. I pulled the motor out and channeled my inner Barry. Drilled out the factory rivets and pulled it apart The bottom bush was rotating and flopping around. Its held in by a clip arrangement. Pulled that all out and saw the Bush was worn at one end. I flipped the Bush and gave the fingers a tap with the hammer to tighten it all up. Lubed it all up and reassembled. Its mint now. No rattles and i actually have some airflow The other annoying thing wss the paint behind the grill was a mix of silver and white overspray. Have it a quick degrease and a squirt of black and its heaps better
