Everything posted by datlow
Was he planning on changing suspension and diff? Might actually end up easier to go scratch bullt?
2023 Lvvta scratch build Surely your old man could whip up a new chassis with a belt driven barometric Mopar
Any wof cof reg what ever stickers on the window?
(b) The temperature rating of the cord. Cords are usually rated at 75°C or greater. Higher temperature cords of 85°C or greater rating are used for irons, heaters and toasters. Before replacing any cord, check the temperature rating that is marked on the sheath of the cord.
^ that's rated to 133, for heating appliances I'd say the tranny etc would be pretty fubar by the time it gets that hot This is 77 https://www.jaycar.co.nz/77-c-thermal-fuse/p/ST3800
Does it have an option to continue running after shut off to prevent heatsoak? Probably a good feature for post drag run too?
datlow replied to sr2's topic in Project Discussion
Not to poo poo your A+ barrying +1 safety glasses up to +2.5 I think https://nzsafetyblackwoods.co.nz/en/bolle-bifocal-iri-s-diopter-1-0-safety-glasses-each--412253 +2.5 https://nzsafetyblackwoods.co.nz/en/bolle-bifocal-iri-s-diopter-2-5-safety-glasses-each--412256 -
I would Low wheels and some factory? Aero/Spoilers etc gets my tick https://www.instagram.com/p/BpvqnWzBXZi/?utm_medium=copy_link
Probably more ride on sized .....
@bmxnz11not sure on legalitys but these would be more legit looking https://www.repco.co.nz/en/parts-service/steering-suspension/suspension-bushes/pad-kit-coil-spring-upper-47322/p/A1045688?kwSearch=spring Or Find some skinnier ones of these (mercs have them in different thicknesses fo adjust ride height) https://www.adenstyres.co.nz/products/universal-spring-spacers-10-15mm
Or $7 for 2 500g bags from pak n save.....
Actually just looked at my bike one that I did first and doesn't look to require it anymore (they probably leave that to the vin place) *maybe of note is the plate needing to be in "mint" condition, I maaay have used a low res photo of my bike one and painted over a big Crack so it wasn't so obvious
Yeah they don't seem to worry about that, I've done a bike and a car Only reply before approving me was asking for a photo of the back plate (that was the back plate i sent them just weird looking citroen so probably couldn't tell)
Re black plates Photos of them on the car (so they can tell its 2 diff plates) with patinad screws and a screen shot of car jam should suffice Photo of the chassis number if still there Reuseofplates@nzta.govt.nz
Yeah got excited seeing the pacer stuff was cheap as, but says for bare alloy wheels only....
Hmm some googling and "after some Digging i found out that the active ingredient in iron x is ammonia thioglycate " perming solution "With this in mind i decided to uphold a little experiment. I went down to the local hairdresser suppliers and bought a liter bottle of perming solution " pay careful attention its for normal hair and contains ammonia thioglycate as some are herbal and have different chemicals in them " any way I payed £8.49 for a liter and Diluted it 50/50 with normal tap water Some say you can dilute it 2-1 2= water 1-ammonia ......I then sprayed it very cautiously on my mothers civic wheels " she was going nuts in case it went wrong " within seconds a stream of purple began removing bedded in brake dust i was amazed " wish i had taken a picture " a little agitate with a brush and a hose off and they were gleaming
How could you reject a face like that! / should of been clearer I'm after a brake dust cleaner for (painted) alloy wheels That acid is the active ingredient that turns ferrous stuff red in what I imagine is over price and fairly watered down mag cleaners Ie $20 for 500ml https://www.repco.co.nz/en/car-care-panel/car-care/tyre-care/crc-mag-monster-mag-wheel-cleaner-500ml-9308/p/A1307798 Sds says 10% acid, 5% alcohol, >60% water So 20 bucks for a shot glass of acid.....
so google says brake dust cleaners are just "Thioglycolic acid" is there a cheap way of purchasing it, google wasnt very helpful
Cut out the middle man and str8 jumper leads and a arc stick
Likes like a ginuwine deal to me!
Yeah definitely a big fuse off the battery
Found a wiring diagram for it?
Ring council and Karen them into a free grooming
