Showing content with the highest reputation on 23/09/26 in all areas
Since my last update I’ve done quite afew things. I’ve fully mounted the engine and box, made a custom drive shaft, shortend axles and adapted an exhaust manifold to work. Currently im working on a custom intake manifold to work with the rwd layout. Once that is done and my cv boots arrive it’ll be ready for a test drive.17 points
Got this from the wreckers for 20 fucking slaps And had all this stuff bought previously Still feeling very flu-ey but sitting down and Tigging is easy; Still have to sort hangars etc13 points
the RB26 is a fucking shitly designed rubbish engine and if you think they're great then you're fucking retarded. because the engine cant oil itself properly a good fix for this is to increase the sumps oil capacity. i chose to do this. this involves removing the sump. and thats where the Nissan engineers really shine. the 4 M6 bolts that hold the sump to the rear main seal housing behind the flywheel. yep, behind the flywheel. its 10 billion percent unnecessary to bolt the sump to the rear main seal housing with 4 M6 bolts, and even if it was, putting the bolts where you could get them from the bottom of the engine would be the sensible thing to do. what a fucking load of shit.11 points
Rear seats in, which shouldn't have required a hammer but did. They're still the stock tan interior which ill sort eventually but for now they just need to pass a wof Mounted the wipers only to discover that the previous owner has only wired them to one speed and they don't return to neutral position when switched off, so I'll need to find a solution.5 points
Since you've got the bottom out may as well put a Holden crank in (rb30) and paint it red. then it can be closer in capacity and looks to your favourite inline 6.....4 points
Design team went on to work at Audi I reckon…. They were just warming up with this one.3 points
So I drove this thing up the road a couple times, then lost interest. as the gearbox leaked again. it was just a slower version of the starlet, that wasnt any nicer to drive. I probably should have put the interior and the likes back together before driving it. Then the starlet engine exploded. so i pinched that back from this car and put it back in the starlet. I had this idea already, but this chain of events made it happen. Build a junk turbo engine to test a bunch of stuff on. Got an old bigport block From @Dudley which he go from @GARDRB and also some ze pistons and crank from @Dudley So all under lifetime warranty some china rods which i was given back in the day weight matched them all. well the were all bang on even the factory pistons. gaped the original rings for all the boost running low on oil pump housings other than crappy square tooth pumps. managed to dig this one out of a swamp tho ported and fresh gears ive taken out of a new pump to swap to toda gears arp main studs i took out of the exploded block. same deal with main bearings. found some more 2nd hand big end acl race bearings also bearing clearance is actually really good for whats its going to do. So yeah its built from a bunch of old trash. but should be a fairly solid engine The bro gave me a deal on a bellhousing. so can go back to w box on this car. Just easier to work on and i cbf'd dealing with this leaky j160 right now3 points
Mine is on the road WOF and Rego with patina intact. I had to get a repair cert done on some rust repairs, and the repair certifier guy was told me I was going to need to work really hard on maintaining it in NZ conditions, but as far as compliance goes, no one seemed to be concerned. I've been putting penetrol on it, and have put RIPO Oil in the sills and around any seams that have lost their paint. It looks cool, but I'm getting over the maintenance, so eventually its gonna get painted.2 points
Brendan was living with me at the time he built that thing - open headers start up... argh2 points
do cert/rereg and just do it once. most of the time thats the better way, unless you are doing just minor things ie if you have a morris minor and you are putting a 13b turbo in it, youd spend money on stock brakes getting them right for re reg, then throw them all in the bin when you put your 400hp motor in it. if its a 2026 civic and you are putting adjustable suspension in it then it doesnt matter which way you do it. the fact the vehicle is certed does not make any difference to the compliance process 1. get vin number assigned to vehicle 2.get lvv cert and repair cert sorted and passed 3.go back to compliance and get their bit done. once you have repair/lvv cert done this is usually quite easy 4. drive into the sunset2 points
Mounted the passenger seat with all 4 bolts for the first time because apparently I don't know how to measure, and had to notch the holes in the rail to get the seat straight. Hopefully that's the last of the front seats for a while I don't think I can ever have more than 1 passenger because the front seat has to be all the way back to fit me in this car1 point
I am a few months into putting together an Altezza as a sort of period correct/semi respectable drift car of sorts, and realised I hadn't really documented the process in any meaningful capacity. So here we are, my misadventures in internet forum post form. Here's a short run down Car is an ex-skid car, owned by (several) questionable individuals in it's time before me, and as such a decent amount of work has been required in the process of getting it back into shape. My goal is to get car cleaned up and presentable. Will also be modifying car in line with the vision I have for it. I am by no means a master mechanic, but trying to give it all a crack myself either way. Have learned a lot so far, and I am excited to learn even more going forward!1 point
Funny story, I had an AE82 FXGT for a first car, which felt old at the time. My current Altezza daily is older than my AE82 was when I had it in high school1 point
Yeah I've just been getting it on a microfibre cloth, wiping it across the surface and then wiping off the excess. Then give it an hour or two and do it again, repeat until it stops soaking it up. The water seems to bead up nicely on it like after waxing the paint. I have only been using the penetrol on the front guards and bonnet, as it seems to stain the paint. So all the little worn edges and stuff are still giving me trouble. I've tried waxing them with the paint, but that doesn't seem to seal it enough and they keep weeping, which is annoying cos then it tea-stains the paint around them. \I should just paint it.1 point
Speaking of ae86 beams stuff, I will have beams 3s from the ex-LOSER ae86 drift car of Brendan Dunker back in my hands in next couple weeks and assessed ready to sell...1 point
RB nO GoOd? bUt GtR wAs s0 fAsT thEY hAd 2 BaN it AT BaThUrSt had to be banned cause it was faster than a vp commodore yeah big whoop1 point
So I have a dead reg Jag. I'll put the details up here of the journey in case it helps somebody else as it's a learning exercise for me every time. Deceased estate so I need a stat declaration from the son who sold it to me that he inherited it. The bill of sale accompanying the stat declaration is to include the seller's licence number and name, my licence number and name, a date, the vehicle number plate, and a price. Next Tuesday I am to front up to VINZ Palmy at 9am sharp with the car on a trailer to be assigned a VIN ID plate. That costs $178.61. The vehicle is already in land data so apparently that makes things easier. Once that is done I am to get a repair certifier to say that it isn't rusty and repairs/restoration were carried out to a satifactory level. I'm unsure who needs to have that information but as it is mint, I don't mind. After that I'm unsure if VINZ need it back again or it can go off to LVV but I'll report back after Tuesday.1 point
My theory on the beams exhaust noise is this: 1. The factory exhaust manifold with the very short primaries and long secondaries, makes for a pooey sound. A good long pipe 4-1 or 4-2-1 goes a long way. 2. I noticed with my car that the car sounded a lot worse, when the engine had hardly any ignition timing. The exhaust sounds rougher and louder. I suspect that with the high km cars with factory ECU, they probably have blown knock sensors and the ECU pulls all of the timing out. So they sound like dogshit. 3. There is a variable flap in the factory muffler that rattles after a while. So people swap it out, and put on something worse thanks to issues 1 and 2 above. The factory intake manifold is really good though and they can make a cool carb sort of induction noise when setup alright.1 point
And a mate coming over yo help if often a get out of jail free card for shed time/day drinking ON THE NOTE If any OS boes are in my town, giz a Holla. We can sink shed beers under the guise of getting shit done. "Yeah honey, this guy is a specialist in ecu wiring. He's only here tonight. He's gonna sort my loom etc"1 point
I was about to say, sometimes all you need is some other bugger looking at the project you're sick of to jump start your enthusiasm... Nothing wrong with a shed visit to shame/bully you into pulling finger...1 point
I spoke to the excellent Barry at Weber specialists ages ago, I asked about jetting, first thing he says is what size chokes are you running? 30mm, 1600 vw with 36mm Dellortos DRLAs need 28mm chokes. I'm sure you can buy them but I thought it was a good idea to try and make some. And it doesn't work, then I'll buy some! Haha. Halfway done. Done. Could not be fucked pulling the carb and manifold out so swapped out the venturis in place. Managed to not drop anything inside the motor. Turns out I had one of the upper vents in backwards, why is it possible to put them in backwards!!? Happy with the changes, car is much nicer around town to drive, now I can get the jetting better. Stoked to have made parts for my engine and have improved things!1 point
Chucked the engine back in but I am pretty toast with a flu at the moment so didn't get through as much as I wanted to. Firstly I hooked up the gearshift properly and things are tight and snickety snick. I slightly shortened the throw of the gearlever and this is noticeable. Nice. Mostly though I spent the time making a pseudo header tank for the cooling system. I didn't really want to use the tank that came with the Fiat even though it is a pretty stainless one as it would have meant more plumbing, but I talked to @Roman and my radiator man and decided to build a small filler tank at the head outlet. It is definitely the highest point, although my rad man suggested running a bleed line from the rad back to this as well. I will have a look and see how much of a faff this is, but it is a good idea. And after some fitment mods I made the two main coolant pipes down to the hard piping that goes through the tunnel. You can just spy them below the headers. I will probably have to extend my exhaust shield a little bit to protect the right angle hosing going into the hard pipes. I started to look at the heater pipes, these are going to be easy however I could not find any suitable tubing in my stash, so that will be another day. While I was grovelling I took a pic of the 3D printed TPU closure for the shifter cables for your visual enjoyment.1 point
What’s the NZTA view on patina that’s been oiled? I’m looking at importing a Galaxie wagon, and don’t want it to be un-warrantable. Similar patina levels to what Anglia4 posted above1 point
Awesome thanks for that. The more i measure this car it must have been a friday assembly day. I pulled a door hinge bolt out of the floor sound deadening the other day that had been embedded since 1978 lol. And as far as making both sides match rivetwise, my ocd is the same. To the fact my wife bought be this shirt.1 point
LSD showed up. Tore it down as you should. Lucky too cos more than half of the LSD cap bolts were loose. I was confused about missing preload springs (in the form of belville washers) but googled the shit out of it and turns out that some of the diffs don’t have springs. The diff has 4 clutches (some only have 2) but I won’t know how well it locks up until I try for a donut. Will install over the weekend but I don’t have oil for it, so waiting on my Redline 70W-140 GL5 to show up. Supposedly BMWs recommended fluid for LSDs. The E30 small case diffs are notoriously weak, specifically the LSD cap, but this is actually a Z3 (still small case) diff which has a much stouter cap design. Still a weak point but less weak! You can buy billet caps, about $250, but it means rechecking lash and shims and contact patch on gears and that sounds like more work than not doing it. Might do later, will see if it needs a clutch replacement first. fuck it’s cold down here at the moment. Harder to find motivation to get out to the garage. This is just up from my house: I pushed the car outside to work on the diff on garage floor, and by the time I pushed back inside bonnet was covered in ice. Moist1 point
Sooooo the whole no cert thing bugged me. I want it to be wof n reg so the dohc came out (I have other plans for it) The sohc 4g63 from my yellow ute went in. Also swapped in some ae86 springs to try out. Not sure if they'll stay And finally got around to polishing my 13x7 hotwires with some nankang 215/50s , pretty stoked on the look, front might be a little high though Anyway I finally got to drive it for the first time in a while, feels good to drive a car to break the project blues1 point
Fun times Actually isn't too bad to take the engine out. the gearbox is a knob though. hence why engine out, even though gearbox the problem. think it was leaking out one of the bolts that holds the bearing retainer plate / bit the release bearing slides on. what ever its called. wasn't the input shaft seal anway, which is good as i replaced it, and if it were leaking would have got oil on my expensive clutch Back together and doesn't seem to be leaking yet. the geabox oil looked bad for how long it had been in there, so still not sold on this box. see how it goes i guess It also changes gears now. After cutting some out of the clutch fork and moving the slave inwards, it still sucked. managed to drop the master cylinder down a touch, so could adjust the pedal ratio, which gave it enough travel to fix it. Some sneaky. well not so sneaky test runs up the road, since had to check that it changes gear at 9500rpm. It goes pretty good, obviously not starlet fast, but the better ratios are a good thing1 point
tired a bunch of stuff today. got a bit more out of it. Intake tuning wasn't really doing what i hoped. will try more stuff at later date, 1:1 run with same wheels, same diff ratio. starlet (current spec) vs trueno Ignore the disaster below 3500 an above 9500. Not bad considering the trueno is on stock valves, smaller cams and the headers make a little less up top than whats on the starlet1 point
Loom basically done. changed some of the split loom after this picture. as the ali special stuff is super thin, crushes and looks horrible. Coil / hot side stuff is heat sleeved. the xlr connector down bottom by ecu plugs is for dyno wideband connection Getting pretty close to first start up. shimless buckets showed up, so top end is all together properly now. e throttles and stuff all work. engine turns over and has oil pressure. Just waiting on a few more bits, then rest can go together made this dipstick tube that doubles as the oil return for the vvti Have room on this setup, since no fuel rail in the way. so the lines do a sneaky sneaky around the back Had a bit of a shitfight buying injectors, not naming any names NZAIRFITER / DSR TURBO massive sharn what happened. But bosch group the flow rates of their 980cc injectors with a little dot on the side , red, yellow, blue. I asked for them to be checked before sending them out. Yeah nar sends 2 red, 2 yellow. red ones can flow up to 7-8% more than the blue and yellow somewhere in between. I wont bore you with the details of the bad customer service, but was basically stuck with them. please dont buy anything of this guy The link can do pretty cool injector test. so ordered some measuring tubes off aliexpress and rigged up this abortion with one of the bike rails. conveniently they have clips to hold the injectors in the rail and i can run deadhead setup on my fuel system. This is all attached to the fuel system and ecu in the car Test run on the bike injectors. they flowed nice and even. pretty good for some 10 year old injectors that have been kicking around the floor of my shed. but they are a touch small to run as single set of 4. the bike runs 8 injectors with the 980's in the rail wide open test (100% duty) for 30 sec. (double the time about 900cc/min) red, red, yellow yellow Just as bosch states the 2 red ones on left flow more than the yellow on right. about 4.5% difference. real world (roughly) if you tuned the engine at 12.5:1 afr. you would have the far left running at about 12.3afr and the far right running at 12.7afr. not great, not end of the world. unless you got unlucky pair that far right injector up with a cylinder that wants to run leaner than the rest. Next with little math i simulated the engine running at about 8500rpm for 1 minute at about 40% duty. since this engine will never see anywhere near 100% duty. though may get lucky and they would flow closer to each other at lower dutys Still about 4% different down at that duty. Yes the math doesn't math, as they should be flowing around the 360cc (360ml) mark, going by the wide open test. The next day after the petrol fumes wore off i realized i didn't account for the the inejector deadtime. so real world with the right deadtime numbers, that would be at about 28% duty. Done another test at 80% duty also, with similar results, about 4% difference Will order a pair of yellow dot injector off someone who is less retarded, as thats whats in the starlet. flow all 8 and match up 2 sets for both cars. so not all is bad, the starlet might get a set of better matched injectors out of it as well1 point
I had a look around a 4wd manual Platz today. The rear chassis rails still seem to get in the way if it was slammed so not much difference to a standard Platz. The tunnel also seems to not be hugely larger height wise than standers but is wider for the exhaust to pass through. No matter what you would do itd need chopping up because if you ran it off the transfer case it probably wouldn’t last very long.1 point
I'm a fan of penetrol for preserving patina. If you dilute it with terps it seeps into all the rustworms under the paint and seals them. So easy too, and easy to touch up. I don't like the look of clear over patina.1 point
0 points
0 points
