Showing content with the highest reputation on 26/07/26 in all areas
  1. After removing a wall during the reno our old shelves didn't fit, also they were ugly and didn't gel with our decor. I acquired these oak veneer floating shelves from my former corporate overlords. Bought some 30mm steel and made the frame. The shelves are pretty strong but kinda narrow, decided to add a cross bar. Which made the top an issue. So I extended the vertical 30mm. And zapped it all together. 3D printed these TPU feet I designed. Fit perfectly and protect the floor from what is now a fairly heavy shelf. Screws. Fits like a german. That's a weird auto prompt. We got to much shit but the main thing it's not in my garage.
    19 points
  2. tImE tO geT THis ThInG MoUNTed Ffs that was a year ago and I'm STILL waiting for fucken parts. Modern engines and their death by 1000 adapters/sensors/diodes will kill me. Anyway this weekend's job was to get this thing mounted. Using Nick's fancy plates, I managed to get something sorted using the small block tubular mounts and rubbers. I was able to move one tubular mount forward and another rearward and they still didnt line up. But it is what it is. I was constrained by needing to use the chassis and the crossmember. If it were just the crossmember it would have been a piece of piss. I measured the angle off the chev block and copied that to keep the mounts in compression. Ran out of MIG gas which is pretty typical for a Sunday but it can wait till next Saturday. But it is tacked so I'm calling it a win. Next up is to man math a pulley belt.
    10 points
  3. Ol mate doing some shopping
    4 points
  4. Mocked up the rear for shits and giggles
    4 points
  5. cooling system needs to be done . I think the thermostat is stuck open, temp won’t even get to 1/4, Will service it this week. Need to check out why the electric mirrors and the rear cargo window aren’t working.
    4 points
  6. got the all the manifold holes drilled and tapped. managed to get the external drain back in also. half of it got cut off in the process Cut the valve spring seats and some hand porting to go. Then it can go to shop to get guides and valve job
    4 points
  7. Still playing around and experimenting with the art side of things and figuring out pound size Got an old wheel brazier in place, and the old door I found in the Kaingaroa forest. Rego expired haha I cut this up using the rego from my other RN40 and old lables...
  8. Hi Ho Hi Ho it's off to the engine tuner it goes. Should be running next week. Hopefully it behaves itself.
  9. Mate sent me this AI edit, pretty much what i have in mind
  10. This is the main reason I brought a 2010 Doesn't have dpf and first mod was new exhaust with cat delete and re map.
  11. Picked up a rare Gloria custom van. L20 with 4 speed column manual. Imported in 1990 with 70,000km and now has only 124,000km. Last owner passed away, and had some rust by the rear tailgate hinges professionally done Rest of the car is excellent. Straight as just needs a paint. Any recommendations for a closed door respray ? interior is pretty good seats need a clean and a bit tatty, wish it had the rear jumbo headrests the ‘wagon’ version got - not to mention the dickie seat. But made the 300 km trip back and goes well enough although dumping a L28 in would improve things. Any leads of a L28?
  12. Another 2 1/2 years? Time for another update.. Took it for a wof a couple of weeks ago thinking it would fall at least on the g-grids from the 1990's but it failed on a bottom outer ball joint.. Classic. I had actually been wondering when it would fall as the other side failed on the first wof after a revin, but the boot had split and let water in and grease out.. Literally a 30min job as they just unscrew. Fixed it with a new one.. Which resulted in this, for a whole year.. Luxury Went to the mussel inn for a celebratory beer. The POR15 is looking worse for wear, suffice to say I won't be using that product again but I don't know if I can be fucked going through the whole process again straight after finishing the zed.. The struts and backing plates are actually fine, just the springs, sway bar and bottom arms look shit Anyway, stoked for it to pass again with little to no effort, now to fix some other things.
  13. Managed to squeeze some o-ring grooves in this one. Pretty much done on this fixture, just some more manifold holes to go. ports are roughed out close as they are going to get on the mill. can only do so much firing a end mill down there on a bunch of different angles They are pretty close though. only a small amount of hand porting to finish them. The fins on top and bottom of ports are a byproduct of the angles the ports are drilled on. They are staying there, as works out well to take up some of the cross sectional area in front of the divider where its little big.
  14. Kumeu Tyre Garage put the Eagers on whilst I waited today. Looking sharp!
  15. Wof fail, boo On the bright side, thats quite possibly the best ever brake balance result for this car! But fail on 4 simple things, some engine bay wiring was taking the piss on lack of restraint, exhaust hanger bolt loose, brake hardlines needing grommets where they pass through the body and front wheel alignment. All 4 were about 30min after work to sort out, wheel alignment was just with stringlines for now, I initially set it up as it came apart but was excessively toe in, that with the mud tyres made quite a noise on the wof station floor! I do need to machine up some shims in preparation for caster and camber, it can't be too far off as so far handles as I remember. On the list to fully assess, stay tuned as they say. With all that down a return to the testing station yielded that small sticker of dopamine Warm fuzzy feels, darn cool to have the old thing back on the road! No rest and straight to work, trailer of greenwaste to the dump and back via the hardware store, good laugh at the rally mudflaps, wasn't sure where to trim them so put them on straight out of the pack, with a bootload of supplies they were dragging a bit too much. Must trim before the first offroad trip... The cold weather is making starting a bit of a challenge, either need to sort out a choke linkage or wait a few weeks, a good chance here to prove the value of procrastination. Another current issue is a bit rough running at 50-60kph cruise, likely an air leak on the carbs so set up the CNC to cut out some new gaskets with a drag knike and will investigate when I next get some shed time.
  16. So I've had this occasionally up on the forum over the years and now it's a proper project. But first, the yarn... As a 18yr old whipper-snapper I was fortunate enough to get a after school/uni job at the local rural mechanics - that was the start of where I learnt alot of what I know now. The workshop was run by a father-son, the latter of which owned this and then who I convinced to sell to me. It is an '89 AE92 Corolla GT and from what I was told, there were 2 brothers who imported one of each of these from JPN - one white and one black, that makes me the 3rd NZ owner. There are very few of these GT sedans which have survived (less than the FXGTs) and I had never seen another one in black (most are white/grey). Then one day, up popped on a random thread the reason why.... A basic translation has this descibes a small run of 215 units with black on black codes and some other slight factory upgrades to the 4age/5spd platform. I subsequently learned that Toyota also did a similar 254 unit run of Levins (and I know where at least one of them lives). So after being a daily driver and many teen/twentys antics it has sat for the last 15 years, moving between a few storage locations and sitting in my workshop until the landrover was pretty much finished. Some recent encouragement got me to get stuck into it again... Problem #1 is that after sitting for so long the fuel pump was dead, I had a Denso one sitting there but these things are a bit painful that you have to drop the tank to get the pump out.... I can assure you that dealing with the stale fuel which was in there was not alot of fun.... That was pretty much all it needed to fire back into life, some fresh fuel, a new battery and then that 4age was humming again... I immediately drove it outside to give a basic rinse of the accumulated dust. The years have not been super kind to the body work, there is some chipping/flaking paint, and I also spotted some very minor rust on the roofline, as well as some rust/cracking on the boot where the wing attaches (that was really an after thought from toyota). Also, during one of the storage moves it ran off the trailer and jammed the door, that then folded up the front guard when it was closed. So I pulled the affected panel off to give it some very slight tweaking to get it straight again. After working with 1.6mm alloy for landrover panels for so long I had forgotten how flimsy panel steel can be... So whats the plan? Basically a refresh of everything, but I'm going to spit up the work: The clutch is near done so the engine/gearbox needs to come out, and I think it is work pulling the head to at least do a check over and replace every seal/gasket while I'm there. While this thing has been used and abused it has also been very well serviced so I'll be interesting to see how it looks. In the process that also means all of the cooling/vac systems hoses, water pump/thermostat ect... Then the hydraulic systems - brake/clutch all need new fluids and seals, the A/C isnt working any more and I'd also like to have it back... Suspension, all bushes, and the top hats I see are cracking, so thats a complete go through. Plus gearshifter bushes. After that then its cosmetics, probably get the rims refurbished and i might be able to get away with a very good 'scotch n spray'. The steering wheel needs restiched and I need to find a Gen1 ipod nano to go with the pioneer stereo which I installed back in the day. Basically, get it back to what I remember when I was 18, but make it tidier than what I could afford at the times. This has been a long time coming, and the car means alot (plus its pretty unique) so I want to have a good go of it.
  17. Hi All, Should probably introduce myself, I'm colin, long time fan of old cars but have been without ownership of anything oldschool worthy for about 10 years now, but recently managed to snag what appears to be a decent DR30 at auction in Japan, it's yet to show up so time will tell if it's a patched up rust bucket or a genuinely good car. have previously had a number of R30 skylines, one '84 four door L20ET, one '83 Paul newman version Coupe (much regret losing that looking at prices now), an '82 DR30 RS2000 with a FJ20ET fitted, which is now somewhere in blenheim i believe, and a red coupe we put in someones paddock for storage about 10 years ago, which we now can't find, so if you find a mostly stripped red R30 coupe near Tai Tapu somewhere, sing out. Plans for the DR30; -Fix whatever rust and corrosion is stopping it from getting through compliance (I know f**k all about panel repair work which is crazy consider Ive owned a number of one of the rustiest Nissans ever made -Cert for coilovers, appears to have R31house coilovers fitted, this could be a rigmarole in itself, given that no welding on steering parts is certifiable, and thats what these look to be, if you have any intel on that situation, please let me know! -15x8/8.5 Watanabes, looks like ex-japan is the only option, as the right offsets are to hard to find 2nd hand -Facelift tails (dear god these have got expensive since my last car, if you have a set floating around at a reasonable price, get at me) -Some period correct front seats, similar in style to recaro fishnets, square shape, good side support etc, open to suggestion on this -Drive it! I've been to car meets with friends etc over the past few years and that is far more accessible fun as I get older Some pics of the car and some underbody stuff to give an idea of general condish, tried to buy a number of these, and they were all pretty rotten in comparison to this car, and for some reason this car we got for alot cheaper than we expected to pay, so i'm losing sleep over that, ah well. Yolo or whatever they say these days.
  18. Is there a plan to see this thing dyno tuned at some point? (That's part of why I follow this thread tbh) it's both fascinating and discouraging to watch the trials, tribulations, and challenges of people building "cheap, quick, and easy" HiPo "shitbox". *not saying your car is shit btw, merely using that nomenclature to denote its affordable nature. Internet videos were junky junkyard trash makes ELLEVENTY BILLION HORSEPOWER! never seem to show the trial and error/learnings (the hard way) I enjoy your progress. But your setbacks fill me with dread regarding the insurmountable nightmares which await me. (If I ever finish building anything)
  19. Those pictures make more sense if you are using off the shelf doubler plates. I just had top bolt to do in my car so was able to use them.
  20. Yeah would not be using aliex injectors. I really only need 45mm throttle plates, as the xf manifold has a thin seperate section with the injectors in it so i could make an adaptor plate up between injector section and whatever ends up supplying the butterflies. Picture 6 small SU carbs with no innards. But bugger balancing 6 links.
  21. With it now more holes than car i thought i should weld some bits into the holes. So i did.
  22. I pulled the rusty piece off to see what fun times lay beneath . Not toooo bad but there's a bit of work to do. I welded the first two pieces together then set about making the channel that the seal glues into. I've made pieces of this channel before but never this long and deff never in one piece. This is one thousand percent the most difficult piece I've ever made. It's a channel but more of a retarded V shape than a U shape and is curved in both directions and the curves tighten at the ends. It fits Perfectly. Fuck I'm so happy to get this right. I'm going to have a celobrateobeer and bask in the glory until tomorrow when I fuck it up.
  23. Haven't done fuck all on this thing for awhile, haven't needed to!! Apart from what turned out to be a lose fuel pipe it been pretty reliable. I did balance the carbs again, which made a huge difference as it would stall at the lights.
  24. Started work on the lower bracket for the pivot points. This piece will follow the curve of the front sheet metal and be mounted where the front pan and fenders bolt together. using a 25 x50 x 2mm bar with drilled and filled holes.
  25. Building the 1961 Datsun 310 Bluebird - Lower Rear Quarter - Parts Making. The small repairs to the lower rear quarter structures has escalated just a bit. And where does it stop? Should I just go ahead and repair the rest of the trunk/boot floor while I'm at it? Maybe. The parts in-work manufacturing progress...not done yet. Summertime travels, fun, and numerous other interruptions and obligations have slowed things down a bit. New metal in work on the left and rusted parts on the right. Lower left part is done, sanded, acid etched and treated with a zinc phosphate chemical film. Other parts still need a few finishing touches or more. How I made one of these things. This is the horizontal, far right hand side of trunk/boot pan that supports the dropdown panel. A couple of deep indents, made separate, then cut openings in panel and welded them in. I got a bit impatient with all the tack welding, went fast and crazy with stitch welding instead and warped the heck out of it. After much heating with a torch and beatings it was fixed. No pics of the embarrassing warpage! Have to slow down next time. A rusty pile of junk. I may still salvage the bit on the upper right as it has a only few craters that need drilling and plug welding.
  26. That is awesome. And dont worry about how you got it home. Check this bad boy out.
  27. If those two jokers above can't sort it, find your car on Amayama (can use chassis number) and start adding things to your cart. When you have enough, submit it and they'll check what they can and can't get. My last two orders i've cancelled as they came back and said 90% of items were NLA. I've managed to get some parts though which no one else can source. One example was front side indicator lenses, NLA here but can get them off there for like $5-7 a pop. That was for a different car, but just illustrating it can be a lucky dip.
  28. And it goes on and on and on, seems every weekend in recent memory can be summed up in the one photo While contemplating life choices, Doggo #2 said it looked stupid as without a front bumper and knowing not to argue with a big rotty, I guess I should refit it? Pulled out from storage it wasn't in good condition, the steel bracket that holds the rubber trim strip was corroding badly, not helped at all by the bumper being Aluminium. After a good scrub and water blast it was pretty clear that to stop the galvanic corrosion the bracket needed to be zinc plated but I wanted it done now. Pondering various fixes I came to the thought, why did they not make the bracket from aluminium in the first place? (Yes, the bumper could have been steel, but that would have doubled the weight of the car) That thought then went to why not remake it from Aluminium? The original bracket profile measured up pretty darn close to 65mm wide with a 1/4" bead down each side, didn't take long to feed a few strips through the bead roller and jobs a goodun' Couple of rivnuts later and there we go. Deceivingly easy. Fitted, happy As brake imbalance has been almost a given at every wof, I put some new style self adjusting rear cylinders into an order and fitted those along with new pads and rotors way back, I really hope they take away the pain of getting the pass grade. Preliminary testing hasn't been too conclusive other than to reaffirm my lack of sanity to the neighbours, trying desperately to make up speed in our short road before stopping hard in an attempt to bed the new brakes has been comical entertainment i'm told. It makes much more noise than speed doesn't it? and the painful, Oh, thats a Lada? Thats the car everyone jokes about! Next up, mental asylum or wof? Place bets!
  29. Finally, to do list time! I avoid making lists on big projects as it tends to be more demoralising than helful, instead focusing on chunks at a time to shield my fragile self esteem from reality. This would probably be why i've been saying just one more weekend for the last 6! Anywho, the time came to scribble up a pre wof list and it wasn't really that big: Oil catch can Rear shock nuts tighten Spanner check all suspension nuts Drop arm nut (Can't torque it easily off the car) Steering wheel alignment and trim Dash secure Radio trim Refit heater controls Fusebox clean and confirm correct fuse values Refit exhaust Spanner check seatbelts Refit firewall rubber bungs Floor mats and trims Drivetrain grease Transfer case alignment check Engine mounts spanner check Engine bay hose clamps check Wiring harness secure check Mudflaps and wheel flares fit Refit front bumper Fit new cambelt Tail light nuts check Tidy up fuel hose lengths Fit number plates speedo drive oil leak Fit new service parts on carbs Fit inner guards Check wheel alignment And all the other usual stuff found along the way I haven't listed. Guess its worth adding I made a new exhaust, 1-3/4 tube from the header back, joined up with V-bands so if it sounds shit, I can re do it. Muffler acquired from a pile of damaged Nissans in a paddock, perfect size and low profile enough to not be the lowest part of the undersides. Floor mats i've done the same as the Datsun, 7mm treated ply wrapped with garage carpet. This time I got the 3d scanner out so the CNC can do the chopping. Was it quicker than beerbox templates? probably not, but I did minimise the amount of time spent out in the cold so thats that. Check the fit Spray some contact adhesive everywhere and away we go Time will tell how well it holds up in a car that often goes swimming, if needed i'll recut them swapping the ply for Ali sheet.
  30. Wooho have working indercators. Hoping I get lights working next Gota do some rust in the lower sils also I need to stop buying random stuff and save for some new tyers as these are very old and cracked and poor tread as well thinking white walls
  31. Here I was thinking I had it mostly done then realized I had not done the power steering. I had mounted the Toyota MR2 elec- hyd pump on the passenger side by the radiator so I needed to connect the hydraulic lines and wire it. I managed to get a pressure line from a MR2 which has the correct fitting for the pump and I had the correct fitting to the MX5 rack so I took them into the local hydraulic workshop and they put a swivel fitting in to connect the two systems together. Then it was just the return line and feed lines to do. I also connected a power wire and earth to the pump terminals to check the pump did work. All is well. Then all I had to do was the wiring and I had a diagram to wire a MR2 pump into another car. So off I went into town with great hopes of finding all I needed to achieve my goal of securing what I needed to sort the wiring. YEAH RIGHT. Plenty of places have manual re-setting circuit breakers but not auto re-setting. And they have resistor type relays but not diode type. So at the moment I have it set up with a 50amp circuit breaker which will work for now but will be replaced with a 80amp when it arrives. The resistor type relay may be ok. A mate of mine who is a stereo tech says as it's only acting as a switch and it would work, and faster than a diode but probably not last as long. But probably should stick to the recommended diode type. Any thoughts welcome.
  32. Also got this awesome period style trunk for the rack super cool
  33. Right then. Mind made up and sticking with 2wd. It should save me 6-12 months and $6-12k. Looks like Ill need an air locker and a big fuck off winch however. Spoke with the engineer again and it's pretty simple and will modify the old V8 brackets.
  34. Ok, so the thrash was real and no updates can happen whilst under time pressure. Plan was to get it going for my MC clubs year trip and use it as a sweeper vehicle, long story short, we made it... The basic idea is to put the HX40 compounded over the stock turbo, the goal was to keep the stock drivability but be able to max out the 400 cdi pump. I quickly found out that the C10 engine bay is designed for a SBC and not a Mercedes Diesel with compounds, but never the less these go here...
  35. thats true, if you like looking at your vehicle while its stationary. like, stationary on the side of the road waiting for the tow truck.
    0 points
