Showing content with the highest reputation on 25/07/26 in all areas
Another 2 1/2 years? Time for another update.. Took it for a wof a couple of weeks ago thinking it would fall at least on the g-grids from the 1990's but it failed on a bottom outer ball joint.. Classic. I had actually been wondering when it would fall as the other side failed on the first wof after a revin, but the boot had split and let water in and grease out.. Literally a 30min job as they just unscrew. Fixed it with a new one.. Which resulted in this, for a whole year.. Luxury Went to the mussel inn for a celebratory beer. The POR15 is looking worse for wear, suffice to say I won't be using that product again but I don't know if I can be fucked going through the whole process again straight after finishing the zed.. The struts and backing plates are actually fine, just the springs, sway bar and bottom arms look shit Anyway, stoked for it to pass again with little to no effort, now to fix some other things.12 points
7 points
7 points
Picked up a rare Gloria custom van. L20 with 4 speed column manual. Imported in 1990 with 70,000km and now has only 124,000km. Last owner passed away, and had some rust by the rear tailgate hinges professionally done Rest of the car is excellent. Straight as just needs a paint. Any recommendations for a closed door respray ? interior is pretty good seats need a clean and a bit tatty, wish it had the rear jumbo headrests the ‘wagon’ version got - not to mention the dickie seat. But made the 300 km trip back and goes well enough although dumping a L28 in would improve things. Any leads of a L28?6 points
6 points
Fired some tunes out for people in exchange for parts now ive got an LSD and a mini spool. If i can be assed I'll probably fit the LSD my diff is fine been open it stops me from killing myself so ill leave it till closer to drag day. Have the boosted part of tune locked down now its on point and ready for action off boost is a little lazy ive been diagnosing and found TPS was reading ok but going out of range giving me a TPS short to ground DTC just had to plug in with laptop find the sweet spot and tweak it around till voltages were in correct range. Also found the Narrowband had failed likely ages ago it was picking up just enough noise to not throw a DTC but not ever going in to closed loop now thats working ive made some adjustments and picked up some off boost punch again. Explains why even with 9psi it couldn't quite break a 13 at drag day was lazy as hell it was in need of quite a bit more fuel off boost in the 1800 to 2200rpm range, possibly more efficient with ported heads but likely I just never filled in that part originally to match my injectors response and rest of car. Anyway learning heaps!3 points
Hi All, Should probably introduce myself, I'm colin, long time fan of old cars but have been without ownership of anything oldschool worthy for about 10 years now, but recently managed to snag what appears to be a decent DR30 at auction in Japan, it's yet to show up so time will tell if it's a patched up rust bucket or a genuinely good car. have previously had a number of R30 skylines, one '84 four door L20ET, one '83 Paul newman version Coupe (much regret losing that looking at prices now), an '82 DR30 RS2000 with a FJ20ET fitted, which is now somewhere in blenheim i believe, and a red coupe we put in someones paddock for storage about 10 years ago, which we now can't find, so if you find a mostly stripped red R30 coupe near Tai Tapu somewhere, sing out. Plans for the DR30; -Fix whatever rust and corrosion is stopping it from getting through compliance (I know f**k all about panel repair work which is crazy consider Ive owned a number of one of the rustiest Nissans ever made -Cert for coilovers, appears to have R31house coilovers fitted, this could be a rigmarole in itself, given that no welding on steering parts is certifiable, and thats what these look to be, if you have any intel on that situation, please let me know! -15x8/8.5 Watanabes, looks like ex-japan is the only option, as the right offsets are to hard to find 2nd hand -Facelift tails (dear god these have got expensive since my last car, if you have a set floating around at a reasonable price, get at me) -Some period correct front seats, similar in style to recaro fishnets, square shape, good side support etc, open to suggestion on this -Drive it! I've been to car meets with friends etc over the past few years and that is far more accessible fun as I get older Some pics of the car and some underbody stuff to give an idea of general condish, tried to buy a number of these, and they were all pretty rotten in comparison to this car, and for some reason this car we got for alot cheaper than we expected to pay, so i'm losing sleep over that, ah well. Yolo or whatever they say these days.2 points
I spent way too long trying to get that shopping window working, from memory it is indeed an absolute cunt to get at and yeah condensation gets into the motor etc and they seize solid. I wouldn't think it's still there, but I can find out if my old parts one is still rotting away, had a clean L26 from memory just the body was too far gone.2 points
Talked my fingers into being helpful today, these plates were far more of a bastard to fit than they needed to be. I blame the weather, definately was not due the fact i refused to remove the radiator to get better access. (Squint and look for the little shiny bits) Put radiator mounts and oil cooler back on with the new grille, as usual need to buy some nicer bolts, everything i touch on this bike seems to have been reassembled using whatever was close enough to reach, very annoying as at this rate i will have spent as much on bolts etc as the rest of the parts.2 points
Shit yes. Fellow gloria wagon owner here Rear side window not working seems common (mines the same). Suspect the motor siezes up over time. Its in a prick of a place as well, so I've never been motivated to pull it out and try free it up. You do you, but I say leave the paint as is, don't want to ruin it with a cheap paint job.2 points
Hung that boy in the hole and spent some time tweaking the position. Its fairly straight and flat and hangs free, and can move 10 or 20mm in each direction before it hits things. That's without any massaging of sheetmetal so very pleasing. I started to look at the mounts, these all seem pretty doable. I may just see if I can tweak the existing headers and give them a bit more angle rather than remake them... They already clear pretty well but another 20 or 30mm would be primo.2 points
With the new motor in place it was just a matter of hooking everything up. After 2 Days and approximately 200 beers, the motor was in and running, the maiden voyage was a success, so we crashed for the night and the next day packed up, loaded the camper and set off for home. About an hour and a half from home the left rear wheel bearing started making noises, but after the episode I had been through I just turned the radio up, We got home without a drama so I'll chalk that up as a win...2 points
Will make my way down another way = )1 point
Managed to squeeze some o-ring grooves in this one. Pretty much done on this fixture, just some more manifold holes to go. ports are roughed out close as they are going to get on the mill. can only do so much firing a end mill down there on a bunch of different angles They are pretty close though. only a small amount of hand porting to finish them. The fins on top and bottom of ports are a byproduct of the angles the ports are drilled on. They are staying there, as works out well to take up some of the cross sectional area in front of the divider where its little big.1 point
This years plan: -Attendance -Exhaust not sound shit -Hoosiers -flat shifting and launch control setup -10k rpm -Send it (possibly to Valhalla)1 point
You're allowed again. It'll annoy a few people and that's OK with me.1 point
Managed to tighten the belt on the lathe a fracky and made a mess. Plug all tapped in and clamped up. Of course once i parted the plug section off the main chunk, it was in between the sizes for the chuck with the jaws either standard or reversed. Good news is the fairings will hide all sins. If i get another sunny day tomorrow i might even make some gaskets and fit the emmision blankers. Already feeling 3 months ahead of schedule though.1 point
After more than 30 years as a professional musician I've accumulated rather more guitars than any one person can reasonably justify. I have always hung my acoustics on the wall, partly because I enjoy seeing them, and partly because it helps them acclimatise naturally to the room's humidity. About a year ago, gravity intervened. One of the guitars decided to part company with its wall hanger and plummeted onto a polished concrete floor, landing squarely on the rear strap button. The impact split the soundboard and lifted the top. While it wasn't my favourite acoustic, it was an expensive Ovation that had earned its keep over the years through countless rock gigs. As anyone who's played in a rock band knows, there are always one or two songs where the electric guitars get put aside for the obligatory acoustic number. Ovations are a bit of an oddity in the acoustic world. Their rounded composite backs and heavily lacquered tops make them incredibly stable, they stay in tune remarkably well, and their onboard electronics have long been regarded as among the best in the business. They are superb working instruments—built for the stage rather than the campfire—although perhaps they sacrifice a little of the warmth and soul of a traditional wooden acoustic. Unfortunately, none of those engineering virtues made the slightest difference when mine hit the floor. With little to lose, I built a custom cradle to support the body and began the painstaking process of gluing, clamping and coaxing the instrument back to life. Over the course of several months, I repaired the damaged soundboard, re-set the neck, dressed the frets and did a full setup. Against the odds, it once again became the solid, dependable guitar it had always been. There was just one problem. It still looked exactly like a guitar that had been dropped onto something bloody hard from a rather impressive height—which, to be fair, it had. My artistic niece, (she was once head-hunted by Wētā Workshop), suggested she paint it. My instructions were simple: "Do whatever you like." Her interpretation was nothing like I had imagined! She transformed the damaged top into a piece of art. The worst of the impact disappeared beneath an intricately painted skull entwined with roses and thorns. Running along the repaired cracks she painted surgical stitches, complete with subtle shadows and highlights that make them appear three-dimensional. Instead of trying to disguise the guitar's scars, she celebrated them. I'm still not entirely convinced it's my style, but the few times I've taken it on stage it's become an instant conversation piece. People smile, wander over for a closer look, and almost everyone asks the same question: "Where the hell did that come from?" Perhaps, like a few ageing musicians I know, (myself included) it wears its scars proudly. And if a broken guitar can be given a second life with a little patience, glue, and an artist's imagination, there's probably a lesson in that somewhere.1 point
So long time no update, I have started working on this again so I figured I need to get this up to date so I can document the changes. Basically after the disaster that was Street Week, I got to finding a new motor, I tried all of the normal avenues and got skunked. In passing I was talking to a mate and he said he would see what he can do. A couple of days later he rang and said he had found one at a local used car parts place, I went and had a look, it seemed alright, the price was fair, but it was sold as "scrap", so I took the gamble and loaded it on the trailer. It turned out that it was actually out an S class, so it had a few different parts on it, ie vacuum pump, front sump instead of a rear sump etc etc, luckily I noticed this before we left to Sweden, so I pulled the sump off my spare junk motor and got to packing. it was a 6 hour drive up to Lennarts, so the wife and I got plenty of snacks and got to driving. We arrived without too much hastle, and was greeted by Lennart, where he showed me the workshop where we could get after it. The first thing was to get the camper off, almost immediately one of the drives in the legs broke so it couldn't be raised or lowered, off to a cracking start then... After that was sorted, we go into the bay and got to work, Maria prepped the new motor and I got to pulling out the old one. While the motor was out I got to adjusting the trans tunnel, there had been a vibration that I thought was the top of the gearbox hitting the floor, but it wasn't that...1 point
One day after the last update the garage got flooded and filled with silt at 1am from an overflowing stream nearby, suboptimal. Anyway, got all that tidied up, new seal kit and swivel hubs fitted and passed the first annual wof. Took it for a drive on a nice day a few weeks ago and heard a clunk, looked in my mirror and saw several pieces of shrapnel flying through the air. At first I thought I’d run over something on the road, got home to find the left side free wheeling hub had disassembled itself. That’ll be the shrapnel I saw then. Back down the road for a treasure hunt and managed to find the mangled bits . Tried to find some spare parts but they only seem to sell seal kits. I did some googling and found Vincent truck parts online, they had a listing for AVM series Land Rover hubs on clearance, so picked up a new set for $150.00. New old stock anyway. Other places wanted $500 a set. I made a stupid mistake on disassembling the old ones and damaged the threads on the half shaft removing the nut. Of course it was a weird 16 TPI thread that wasn’t listed even on DTD’s spec sheets, so I cleaned it up with a thread file and some patience. The tyres on it were 16 years old, so decided to get the wheels powder coated and find some new tyres, went for hankook dynapro mt2 from hyperdrive. 30 9.5R15 Action shot of the tyre inspector All back together again, looks pretty good I reckon1 point
A day or so after that, decided to swap in another inlet cam. I only had one stock shim cam hanging around. being a 193b exhaust cam. which is a 278 advertised 8.5mm, pretty small in the scheme of things but bit of a jump up from the weak 232 7.1mm stock cams Just throw that in the intake side and happy days.. turns out the supertech valve springs and ti retainers i had hanging around, that i threw in this head. weren't agreeing with the stock buckets note the shiny ring around the edge. not the swaf, was rolling around on the floor before took picture stock retainer left. supertech right, bigger so can take dual springs lucky it didn't drop a valve. Was only an issue on the intake side as the valves had been tipped when it got a valve job. but must be super close still if everything was 100% stock. with shimless buckets, non issue also, as they have more clearance under them Pinched the springs and retainers out of the big valve head. Then done the super fun job of changing them in place. So 30min job into a day job, results 278 intake cam stock exhaust; Pretty good considering stock exhaust cam and ports. thats it for this head. It can stay on there until the other one is finished. which Ive already cut up. no going back now1 point
Got this going yesterday, after spending way too long making a new throttle linkage /pull this is the most ive made on stock cams - 125kw, the 129kw blue is uncorrected. the dyno over corrects a bit. so on a cold day the corrected power is lower than the corrected power on a hot day. so probably around the 127kw mark. which is pretty silly on the little stock cams. head also has pretty much stock exhaust side, i just zing'd a couple bumps off. still has the og toyota valve job. So looking good to do the same to big valve head1 point
