Showing content with the highest reputation on 24/07/26 in all areas
17 points
13 points
Managed to squeeze some o-ring grooves in this one. Pretty much done on this fixture, just some more manifold holes to go. ports are roughed out close as they are going to get on the mill. can only do so much firing a end mill down there on a bunch of different angles They are pretty close though. only a small amount of hand porting to finish them. The fins on top and bottom of ports are a byproduct of the angles the ports are drilled on. They are staying there, as works out well to take up some of the cross sectional area in front of the divider where its little big.10 points
9 points
8 points
Another 2 1/2 years? Time for another update.. Took it for a wof a couple of weeks ago thinking it would fall at least on the g-grids from the 1990's but it failed on a bottom outer ball joint.. Classic. I had actually been wondering when it would fall as the other side failed on the first wof after a revin, but the boot had split and let water in and grease out.. Literally a 30min job as they just unscrew. Fixed it with a new one.. Which resulted in this, for a whole year.. Luxury Went to the mussel inn for a celebratory beer. The POR15 is looking worse for wear, suffice to say I won't be using that product again but I don't know if I can be fucked going through the whole process again straight after finishing the zed.. The struts and backing plates are actually fine, just the springs, sway bar and bottom arms look shit Anyway, stoked for it to pass again with little to no effort, now to fix some other things.5 points
Yeah would not be using aliex injectors. I really only need 45mm throttle plates, as the xf manifold has a thin seperate section with the injectors in it so i could make an adaptor plate up between injector section and whatever ends up supplying the butterflies. Picture 6 small SU carbs with no innards. But bugger balancing 6 links.3 points
Wof fail, boo On the bright side, thats quite possibly the best ever brake balance result for this car! But fail on 4 simple things, some engine bay wiring was taking the piss on lack of restraint, exhaust hanger bolt loose, brake hardlines needing grommets where they pass through the body and front wheel alignment. All 4 were about 30min after work to sort out, wheel alignment was just with stringlines for now, I initially set it up as it came apart but was excessively toe in, that with the mud tyres made quite a noise on the wof station floor! I do need to machine up some shims in preparation for caster and camber, it can't be too far off as so far handles as I remember. On the list to fully assess, stay tuned as they say. With all that down a return to the testing station yielded that small sticker of dopamine Warm fuzzy feels, darn cool to have the old thing back on the road! No rest and straight to work, trailer of greenwaste to the dump and back via the hardware store, good laugh at the rally mudflaps, wasn't sure where to trim them so put them on straight out of the pack, with a bootload of supplies they were dragging a bit too much. Must trim before the first offroad trip... The cold weather is making starting a bit of a challenge, either need to sort out a choke linkage or wait a few weeks, a good chance here to prove the value of procrastination. Another current issue is a bit rough running at 50-60kph cruise, likely an air leak on the carbs so set up the CNC to cut out some new gaskets with a drag knike and will investigate when I next get some shed time.3 points
Only one way to find out.... Id run legit injectors though not China spec ones (assuming it comes with them)2 points
I pulled the rusty piece off to see what fun times lay beneath . Not toooo bad but there's a bit of work to do. I welded the first two pieces together then set about making the channel that the seal glues into. I've made pieces of this channel before but never this long and deff never in one piece. This is one thousand percent the most difficult piece I've ever made. It's a channel but more of a retarded V shape than a U shape and is curved in both directions and the curves tighten at the ends. It fits Perfectly. Fuck I'm so happy to get this right. I'm going to have a celobrateobeer and bask in the glory until tomorrow when I fuck it up.2 points
Hung that boy in the hole and spent some time tweaking the position. Its fairly straight and flat and hangs free, and can move 10 or 20mm in each direction before it hits things. That's without any massaging of sheetmetal so very pleasing. I started to look at the mounts, these all seem pretty doable. I may just see if I can tweak the existing headers and give them a bit more angle rather than remake them... They already clear pretty well but another 20 or 30mm would be primo.2 points
I have been daily driving this now for the past couple of weeks, because, why not 🤷🏻♂️ I’ve loved every minute of it. It’s beautiful to cruise in, just feels good to drive. Being out in the elements a bit is seeming quite hard on the patina, and it was all getting quite active and tea staining all over the place. So this afternoon I washed it, wire wooled it and then washed it again. That tidied up most of the tea staining and got rid of all the orange rust. Next I went over the car with turtle wax, not so much to try and make it shiny, but more to try and get some kind of moisture barrier over the little exposed edge pieces down the side of the car. Lastly, I put a layer of penetrol across the hood and front guards. Tomorrow I’ll add another coat of penetrol and wax on the bits I think needs it. It looks much nicer than it did yesterday 👌🏼2 points
There is plenty of people heading down from Auckland by the sounds - if you're wanting a ride there n back lemme know.1 point
Nah things will be sweet - I've spoken with the local sergeant in Matamata - more than likely a police car will be present. Fingers crossed for good-ish weather, looks like it'll be ok, odd shower maybe.1 point
Fkn lovely. Subtle curves are a bitch to get right1 point
I see the new managers of the pub have posted a few rules for the Rotang clan.1 point
So I was a busy beaver annoying people this morning and got a really good steer on a couple of things. One is I brought my spare radiator in from the Jag parts bin and the chap at the radiator shop showed me the tag where he himself re-cored it in the 90's. Blimey. I bought it from a guy in the area a few years ago so it adds up. Anyway he said that he'll be able to modify the inlet/outlet to suit the AJ6 easily. Also spoke with WAGs who have done my gearbag stuff in the past on the chev. Put forward my case and he suggested the R151. He thinks the T5 is getting too long in the tooth and the R154 is overkill and the shifter too far back. I did mention the stock box and he said whilst it will take the power easily, a rebuild is a $7k exercise including the OD unit and only getting harder to get bits.1 point
FYI, throttling a centrifugal pump reduces the load on the motor. I use this technique to get away with running a 10kw motor on a cable thats only good for 6kw...1 point
I went to the model trains place today, and it was ace. I got yarning to a friend (ex yank) who's a member of the society, and I got started trying to con him into building a 'Turbin' powered loco. He's not stupid: it is of course a terrible idea. No one wants a train that melts bridge decks anymore: https://en.wikipedia.org/wiki/Union_Pacific_GTELs ... and you'd need to find some unobtanium RC turboprop engine to pull the power electricity off the shaft. like these: https://pacificrcjets.com/collections/kingtech-turbines/products/kingtech-k-30tpg4 but he wants to find one of the tiny kubota engines, and build the clubs first actual diesel electric. Anyway, I got to looking at tiny gas turbine engines, (like car turbocharger ones), and of course, everyone's doing it wrong (😁). Radial compressor and turbine makes good sense for small units below 10-20kW, but -hobbyists don't tend to put in heat recuperators (25-40 thermal efficiency gains), and interestingly, china can help here from just $116 https://www.aliexpress.com/item/1005006746007538.html But as I pondered state of the art, i remembered some amazing microwave lenses a dude was working on, using 3d metal printing: https://www.youtube.com/watch?v=3YMRfw0uWlw and I realised, of course! 3d print heat exchangers! Sure enough, someone had thought of it before, so: https://hackaday.com/2022/10/31/3d-printed-heat-exchanger-uses-gyroid-infill-for-cooling/ The other problem is, that people line up the input shaft with the output shaft for easy coupling: so then the (very high speed) airflow has to bend all over the show, and the ratio of in/out RPM is fixed, so the efficiency goes to shit. Piece of cake nowadays to put a modern BLDC motor / generator on each of those shafts, to line up the airflow nice and straight, and allow tuning the ratios for max eff use 3d printed heat-exchanger / recuperator with nice thin walls for efficiency (per kg cheaper), and bang a 2nd turbine after the 1st, to scoop up more of that sweet enthalpy so, turning the turbine blowtorch into part blowtorch, partly more useful turbo generator engine, for your track bogie DC motor needs. and noise. I'm H4nd and that's my story, and I regret to admit that the law considers me an adult.1 point
Played around with this a wee bit. Chucked some wheels on that I had to see what fitment would be like. Somehow they fit well, slight rubbing on the springs at the front, but got a second hand 195/50/R15 chucked on one to replace the semislick 215/50/R15 that was on it (came off a KP racecar), and they clear. Have about a 30mm stickout that will need a flare, but not a major. Bit of a difference in width haha Got some roofracks, chopped 300mm off em and mounted a wee 1500 wide awning I had on it, had a previous life over the rear door of my 80 Series Landcruiser. Sorry about the terrible glary photo. Moved on to doing something that is actually required for legal driving, the wipers not working properly, drivers side one in particular. Pulled the dash for access, plus to clean up the wiring and clean up in general. Lucky its an hour job on one of these, probably half that if I had to do it again. Cleaned this and pulled the heater box out too since the photo as I need to replace the blower motor resistor and replace the foam on the joins. (Have no idea where I can source one of these, wish me luck? Haha) Found the problem with the wiper, the bit around the wiper shaft should be square and is captive inside the back side of the wiper panel, but the casting said no. Shouldn't be a major, will get a piece of ally flat bar and remake that square piece, then have someone tig it on for me because my tig is DC only. The bushes on the wiper arm are also cooked. Luckily for me the wonderful @ThePog has offered to help me in attempting to model and 3d print replacements for these. That and a small bit of rust in the rear left wheel well (seen above, hopefully only one skin so shouldn't be too bad) were apparently the only two things that it got picked up on the previous warrant check, so figured I would address them first before taking it in myself. I'm sure it will have plenty more though when I do take it in. Have some sound deadener on the way to make it a bit less tinny to be in, so that will go up behind the dash while it is out and in the doors once the stereo goes in, think that may be turning up on my birthday in August from my better half (she wants to be sneaky but doesn't know much about stereos so has had to ask some questions haha) Sat one of the Recaros in (temporarily stolen from the Datsun, they do need a very good clean) to see if it fits. Looks like it should bolt up with some adapters made from 50x5 flat bar to make it bolt through the factory mount holes and then bolt in to the seats. May need to be out for WOFs until it gets a cert in future, but the seatbelts and buckles are all seperate so I'm not too worried. That's where I'm at, will try and get it for a WOF check this month, but I am not overly concerned on the timeline of this one, it's fun to work on for the moment but the offroad camper trailer should really be the priority at the moment.1 point
Outstanding blasting service West Auckland - old school hotrod guys and Kyle is a legend. This came up mint and I laid primer down asap. headers will get the pacemaker blue high temp paint. The remainder of the exhaust will be painted black. I’d imagine I will need the end section to extend the exhaust to the rear of the car. Those are $340 for a pre bent pair.1 point
And it goes on and on and on, seems every weekend in recent memory can be summed up in the one photo While contemplating life choices, Doggo #2 said it looked stupid as without a front bumper and knowing not to argue with a big rotty, I guess I should refit it? Pulled out from storage it wasn't in good condition, the steel bracket that holds the rubber trim strip was corroding badly, not helped at all by the bumper being Aluminium. After a good scrub and water blast it was pretty clear that to stop the galvanic corrosion the bracket needed to be zinc plated but I wanted it done now. Pondering various fixes I came to the thought, why did they not make the bracket from aluminium in the first place? (Yes, the bumper could have been steel, but that would have doubled the weight of the car) That thought then went to why not remake it from Aluminium? The original bracket profile measured up pretty darn close to 65mm wide with a 1/4" bead down each side, didn't take long to feed a few strips through the bead roller and jobs a goodun' Couple of rivnuts later and there we go. Deceivingly easy. Fitted, happy As brake imbalance has been almost a given at every wof, I put some new style self adjusting rear cylinders into an order and fitted those along with new pads and rotors way back, I really hope they take away the pain of getting the pass grade. Preliminary testing hasn't been too conclusive other than to reaffirm my lack of sanity to the neighbours, trying desperately to make up speed in our short road before stopping hard in an attempt to bed the new brakes has been comical entertainment i'm told. It makes much more noise than speed doesn't it? and the painful, Oh, thats a Lada? Thats the car everyone jokes about! Next up, mental asylum or wof? Place bets!1 point
With the new motor in place it was just a matter of hooking everything up. After 2 Days and approximately 200 beers, the motor was in and running, the maiden voyage was a success, so we crashed for the night and the next day packed up, loaded the camper and set off for home. About an hour and a half from home the left rear wheel bearing started making noises, but after the episode I had been through I just turned the radio up, We got home without a drama so I'll chalk that up as a win...1 point
So long time no update, I have started working on this again so I figured I need to get this up to date so I can document the changes. Basically after the disaster that was Street Week, I got to finding a new motor, I tried all of the normal avenues and got skunked. In passing I was talking to a mate and he said he would see what he can do. A couple of days later he rang and said he had found one at a local used car parts place, I went and had a look, it seemed alright, the price was fair, but it was sold as "scrap", so I took the gamble and loaded it on the trailer. It turned out that it was actually out an S class, so it had a few different parts on it, ie vacuum pump, front sump instead of a rear sump etc etc, luckily I noticed this before we left to Sweden, so I pulled the sump off my spare junk motor and got to packing. it was a 6 hour drive up to Lennarts, so the wife and I got plenty of snacks and got to driving. We arrived without too much hastle, and was greeted by Lennart, where he showed me the workshop where we could get after it. The first thing was to get the camper off, almost immediately one of the drives in the legs broke so it couldn't be raised or lowered, off to a cracking start then... After that was sorted, we go into the bay and got to work, Maria prepped the new motor and I got to pulling out the old one. While the motor was out I got to adjusting the trans tunnel, there had been a vibration that I thought was the top of the gearbox hitting the floor, but it wasn't that...1 point
Finally, to do list time! I avoid making lists on big projects as it tends to be more demoralising than helful, instead focusing on chunks at a time to shield my fragile self esteem from reality. This would probably be why i've been saying just one more weekend for the last 6! Anywho, the time came to scribble up a pre wof list and it wasn't really that big: Oil catch can Rear shock nuts tighten Spanner check all suspension nuts Drop arm nut (Can't torque it easily off the car) Steering wheel alignment and trim Dash secure Radio trim Refit heater controls Fusebox clean and confirm correct fuse values Refit exhaust Spanner check seatbelts Refit firewall rubber bungs Floor mats and trims Drivetrain grease Transfer case alignment check Engine mounts spanner check Engine bay hose clamps check Wiring harness secure check Mudflaps and wheel flares fit Refit front bumper Fit new cambelt Tail light nuts check Tidy up fuel hose lengths Fit number plates speedo drive oil leak Fit new service parts on carbs Fit inner guards Check wheel alignment And all the other usual stuff found along the way I haven't listed. Guess its worth adding I made a new exhaust, 1-3/4 tube from the header back, joined up with V-bands so if it sounds shit, I can re do it. Muffler acquired from a pile of damaged Nissans in a paddock, perfect size and low profile enough to not be the lowest part of the undersides. Floor mats i've done the same as the Datsun, 7mm treated ply wrapped with garage carpet. This time I got the 3d scanner out so the CNC can do the chopping. Was it quicker than beerbox templates? probably not, but I did minimise the amount of time spent out in the cold so thats that. Check the fit Spray some contact adhesive everywhere and away we go Time will tell how well it holds up in a car that often goes swimming, if needed i'll recut them swapping the ply for Ali sheet.1 point
Ah soooo maybe I should do this to make myself accountable to see it through Here's my L200 I held out to find one worth buying This popped up on bookface I was like nah i won't get it some twat will beat me to it Stuff it sent the lady my number, "ring me, I'm seriously interested " Well hot diggity dang, it was some back n forth talking cause on bookface no one and I mean NO ONE is a genuine buyer on old mitsis unless you're some sick person like myself Eventually they realized bookface is full of f**kwits and rang me, "come and get it" And here we have it.... Deregistered 1983 L200 sport with a welside, one owner [local business] for one year then the second owner till he deceased around 2006 and it falls to my hands. Paid more then it's worth but I challenge anyone to find a better one I found the canopy locally off another tidy green one that had sold recently and buyer didn't want it. Rookie1 point
Copper coating blocks the case hardening /carburizing. The pivot/bores are under size. When you heat treat and case harden they go a bit oval. So they need to be reamed to size, but if they were case hardened that would basically be impossible. With a reamer anyway. Theres probably other reasons for it but that’s my understanding. It’s all new to me too.1 point
Another job to tick off the list was to replace the new front brake pads with some Winmax. I had purchased some pads from BNT and really didn't take much notice of them until it was to late to return them. They were a softer compound which I thought would help with less pressure needed to make them work. But when I finally opened the box I discovered they had a bevel on them that reduced the contact area but will increase with wear over time. Go figure because it doesn't make sense to me. With the Winmax you can get different types of compound depending on their use. These are for performance street-track day pads. so out with the new and in with the newer.1 point
Here I was thinking I had it mostly done then realized I had not done the power steering. I had mounted the Toyota MR2 elec- hyd pump on the passenger side by the radiator so I needed to connect the hydraulic lines and wire it. I managed to get a pressure line from a MR2 which has the correct fitting for the pump and I had the correct fitting to the MX5 rack so I took them into the local hydraulic workshop and they put a swivel fitting in to connect the two systems together. Then it was just the return line and feed lines to do. I also connected a power wire and earth to the pump terminals to check the pump did work. All is well. Then all I had to do was the wiring and I had a diagram to wire a MR2 pump into another car. So off I went into town with great hopes of finding all I needed to achieve my goal of securing what I needed to sort the wiring. YEAH RIGHT. Plenty of places have manual re-setting circuit breakers but not auto re-setting. And they have resistor type relays but not diode type. So at the moment I have it set up with a 50amp circuit breaker which will work for now but will be replaced with a 80amp when it arrives. The resistor type relay may be ok. A mate of mine who is a stereo tech says as it's only acting as a switch and it would work, and faster than a diode but probably not last as long. But probably should stick to the recommended diode type. Any thoughts welcome.1 point
Sooooo the whole no cert thing bugged me. I want it to be wof n reg so the dohc came out (I have other plans for it) The sohc 4g63 from my yellow ute went in. Also swapped in some ae86 springs to try out. Not sure if they'll stay And finally got around to polishing my 13x7 hotwires with some nankang 215/50s , pretty stoked on the look, front might be a little high though Anyway I finally got to drive it for the first time in a while, feels good to drive a car to break the project blues1 point
I didnt know that was a thing with Imgur! Ive needed a reason to move away from it! It looks like you can embed images from Google Drive with a bit of manual mucking around. That might be the way to go from now on, unless anyone knows a reason not to do that? Heres one embedded from Drive. Let me know if that works for you. @felixx heres the model.1 point
Day 5: Vågårda Raceway We had Pretty high hopes going into the day, 2 PBs in 2 days will do that to you, so we got to thinking about suspension setup and how to improve the 60', which despite the faster time had been significantly slower than it had been previously. A bit of an AHA moment; Last year I setup a 2 step, and due to how a diesel works, ie fuel control, a 2 step works by cutting fuel, this in turn cuts power, so basically while the launch is much more consistant it is slower. With that disengaged and a bit more preload on the caltracs we queued up, the day was scorching hot, so we decided to try and get an early run in so we wouldn't have to wait in the heat all day. Also, maybe somewhat foolishly, I had the truck idling to warm up before giving it hell. I think I was the third car to run that day. It left hard but then fell on it's face, I quickly jumped into the logs while waiting for the return run, and nothing was really wrong, weird. Anyway, it was time to head back to the pits, so I started it up and low and behold there were some unwanted noises coming from the engine bay. BAD Noises, Bugger. Anyway, here we were a long way from home with a termanlly broken motor. So we grab a beer and have a think about how we fix this mess. We start scanning Market Place looking for another motor, we asked a few of the other racers, and came up empty handed, so we started figuring out plan B. I talked to Lennart, and he said we could stash the truck at his place, so we got on the blower to roadside assistance. They offered to deliver it to the nearest Chevrolet dealer, which I politely declined without trying to give the game away, but I offered that there was a local mechanic that was closer and potentially more suited to the job, they jumped at the offer to save money, so the tow truck was on its way, Phillip and I quickly packed up camp, ripped the stickers off and got to waiting. We loaded up the truck and headed to Gibb performance. With the truck unloaded at Gibb, we got to drowning our sorrows and planning our trip home. We were looking at a pretty reasonable train ride home, so with that in mind we crashed in the camper and decided to tackle it the next day. I let Lennart know that I would find another motor and be back in a couple of weeks to do a motor swap so I could get the truck out of his hair.1 point
Car still with autosparky. It sadly wont be making it down as planned.0 points
