Showing content with the highest reputation on 23/07/26 in all areas
I pulled the rusty piece off to see what fun times lay beneath . Not toooo bad but there's a bit of work to do. I welded the first two pieces together then set about making the channel that the seal glues into. I've made pieces of this channel before but never this long and deff never in one piece. This is one thousand percent the most difficult piece I've ever made. It's a channel but more of a retarded V shape than a U shape and is curved in both directions and the curves tighten at the ends. It fits Perfectly. Fuck I'm so happy to get this right. I'm going to have a celobrateobeer and bask in the glory until tomorrow when I fuck it up.12 points
Managed to squeeze some o-ring grooves in this one. Pretty much done on this fixture, just some more manifold holes to go. ports are roughed out close as they are going to get on the mill. can only do so much firing a end mill down there on a bunch of different angles They are pretty close though. only a small amount of hand porting to finish them. The fins on top and bottom of ports are a byproduct of the angles the ports are drilled on. They are staying there, as works out well to take up some of the cross sectional area in front of the divider where its little big.10 points
8 points
So I was a busy beaver annoying people this morning and got a really good steer on a couple of things. One is I brought my spare radiator in from the Jag parts bin and the chap at the radiator shop showed me the tag where he himself re-cored it in the 90's. Blimey. I bought it from a guy in the area a few years ago so it adds up. Anyway he said that he'll be able to modify the inlet/outlet to suit the AJ6 easily. Also spoke with WAGs who have done my gearbag stuff in the past on the chev. Put forward my case and he suggested the R151. He thinks the T5 is getting too long in the tooth and the R154 is overkill and the shifter too far back. I did mention the stock box and he said whilst it will take the power easily, a rebuild is a $7k exercise including the OD unit and only getting harder to get bits.5 points
Building the 1961 Datsun 310 Bluebird - Lower Rear Quarter - Parts Making. The small repairs to the lower rear quarter structures has escalated just a bit. And where does it stop? Should I just go ahead and repair the rest of the trunk/boot floor while I'm at it? Maybe. The parts in-work manufacturing progress...not done yet. Summertime travels, fun, and numerous other interruptions and obligations have slowed things down a bit. New metal in work on the left and rusted parts on the right. Lower left part is done, sanded, acid etched and treated with a zinc phosphate chemical film. Other parts still need a few finishing touches or more. How I made one of these things. This is the horizontal, far right hand side of trunk/boot pan that supports the dropdown panel. A couple of deep indents, made separate, then cut openings in panel and welded them in. I got a bit impatient with all the tack welding, went fast and crazy with stitch welding instead and warped the heck out of it. After much heating with a torch and beatings it was fixed. No pics of the embarrassing warpage! Have to slow down next time. A rusty pile of junk. I may still salvage the bit on the upper right as it has a only few craters that need drilling and plug welding.5 points
Wof fail, boo On the bright side, thats quite possibly the best ever brake balance result for this car! But fail on 4 simple things, some engine bay wiring was taking the piss on lack of restraint, exhaust hanger bolt loose, brake hardlines needing grommets where they pass through the body and front wheel alignment. All 4 were about 30min after work to sort out, wheel alignment was just with stringlines for now, I initially set it up as it came apart but was excessively toe in, that with the mud tyres made quite a noise on the wof station floor! I do need to machine up some shims in preparation for caster and camber, it can't be too far off as so far handles as I remember. On the list to fully assess, stay tuned as they say. With all that down a return to the testing station yielded that small sticker of dopamine Warm fuzzy feels, darn cool to have the old thing back on the road! No rest and straight to work, trailer of greenwaste to the dump and back via the hardware store, good laugh at the rally mudflaps, wasn't sure where to trim them so put them on straight out of the pack, with a bootload of supplies they were dragging a bit too much. Must trim before the first offroad trip... The cold weather is making starting a bit of a challenge, either need to sort out a choke linkage or wait a few weeks, a good chance here to prove the value of procrastination. Another current issue is a bit rough running at 50-60kph cruise, likely an air leak on the carbs so set up the CNC to cut out some new gaskets with a drag knike and will investigate when I next get some shed time.4 points
This years plan: -Attendance -Exhaust not sound shit -Hoosiers -flat shifting and launch control setup -10k rpm -Send it (possibly to Valhalla)3 points
Talked to cert man today. He has no issues with my current plans. Told him i will get in touch just before the point of welding the floorpan in so he can check it out. Need to grab some more 3mm plate to make some backers for another sidequest. Which i also talked to him about and got the greenlight.2 points
Yeah man, ridealongs are all good during grudge if you sign a passenger form.2 points
And damn right i printed off the page from customs nz stating i have no duty to pay for the invoiced amount. Actually i added 15% to the amount to allow for error, and it still said clear $0 fees. So bonus.2 points
Yeah if it’s a 13b into a 12a body with unslotted crossmember it’ll definitely bind up your driveshaft. have a look at the gearbox mount, it may have aft loading on it pushing it backwards.1 point
So if you unbolt the centre bearing and disconnect at the diff end, it won’t slide into the gearbox any further? 13b in a 12a car pushing the driveline back a bit? can you slot the engine and box forward? the Mazda centre bearing is basically just a rubber bush. It won’t slide forward much if the car is already slammed. usually around 20mm in out movement at the most. if there is corrosion on the splines it will be a prick to slide into and out1 point
Fkn lovely. Subtle curves are a bitch to get right1 point
@chrisR has the entire NZ market cornered on Musso's sadly. T5's seem out there. A bit of a pain to google though as like with most things online it is a race to the bottom with second hand sharns about everything being the worst because a mate of a mate had one etc... So availability should be fine and size wise isnt too bad. Problems I see are shifter location being too far aft and being a commodore will likely have an electronic speedo which isnt impossible but does complicate things.1 point
SsangYong Mussos used the T5 in RWD utes too, can be had for around a grand if you look around. No idea if they changed the spines or anything for SsangYong use though.1 point
What about the T5's? I say that because there seem to be a billion of them and they all come with yokes, clutch, tailshafts due to everybody having dreams of converting their VP commy and then realising it's a VP commy.1 point
FYI, throttling a centrifugal pump reduces the load on the motor. I use this technique to get away with running a 10kw motor on a cable thats only good for 6kw...1 point
So yeah...... got bored did a turbo conversion. Intercooler powder coating looked like a urinal after a year in weather so got the dulux recon. Added 2 additional oil pressure gauges in engine bay oil main pressure and turbo reguator pressure so i can keep an eye on the filters in turbo feed (2 filters) good to see im back to having 40psi at idle for some reason it dropped Naturally Aspirated to mid 20s. Took about 2 hours all up to refit everything bumper off etc find all associated bits bolt on then nip up leaks. Had a few AN line leaks they just needed reseating and seemed happy. Has a base map in it at moment only 8 degrees of timing as boost ramps in by 2500rpm rising to 12 degrees at about 4500rpm than just rides out 12 to 6000rpm rev limit. Definitely some room to make that more punchy but a conservative start is good it still boogies! Even on 8psi. Cautious about using the high stall from stationary yet but she lights off the turbo instantly if you stab it transient response is great.1 point
Ordered the panel pieces out of aus, lets see how bent the arrive... Rear inner and outer lower quarter panels, new taillight panel, and a 60cm section of preformed A pillar skin to hopefully do both sides.1 point
Mmmmm sleepy time bubble bath 🫣1 point
Surely a 150000km 1kz, then the water gets heated directly by the combustion gases rather than by convection through the metal. Significantly more efficient.1 point
Why did my brain jump to a series of vrod engines, linked to a single twist grip on side of the bath, so when you want hot water you do some full throttle chorus nangs1 point
run the water through an engine lovely warm water plus the soothing sounds of internal combustion1 point
Check the distributor shaft for wobble/side to side play. Possibly the bushes/bearings in it are worn out.1 point
day 6 on the big valve head. Still a bunch of material to come out of the port entry. But everything works out a lot nicer starting with smallport head, even though this one has been pretty aggressively ported. Material needs to come out of the top where new port meets the head, which is just part of changing in to "high port" rest of it all lines up pretty close with nice even ports and spacing, unlike bigport head. Just a little zing here and there with die grinder will sort it1 point
Hung that boy in the hole and spent some time tweaking the position. Its fairly straight and flat and hangs free, and can move 10 or 20mm in each direction before it hits things. That's without any massaging of sheetmetal so very pleasing. I started to look at the mounts, these all seem pretty doable. I may just see if I can tweak the existing headers and give them a bit more angle rather than remake them... They already clear pretty well but another 20 or 30mm would be primo.1 point
*Probably a better place to post this here than the build thread as i can imagine build updates will be few and far between! Hi All, Should probably introduce myself, I'm colin, long time fan of old cars but have been without ownership of anything oldschool worthy for about 10 years now, but recently managed to snag what appears to be a decent DR30 at auction in Japan, it's yet to show up so time will tell if it's a patched up rust bucket or a genuinely good car. have previously had a number of R30 skylines, one '84 four door L20ET, one '83 Paul newman version Coupe (much regret losing that looking at prices now), an '82 DR30 RS2000 with a FJ20ET fitted, which is now somewhere in blenheim i believe, and a red coupe we put in someones paddock for storage about 10 years ago, which we now can't find, so if you find a mostly stripped red R30 coupe near Tai Tapu somewhere, sing out. Plans for the DR30; -Fix whatever rust and corrosion is stopping it from getting through compliance (I know f**k all about panel repair work which is crazy consider Ive owned a number of one of the rustiest Nissans ever made -Cert for coilovers, appears to have R31house coilovers fitted, this could be a rigmarole in itself, given that no welding on steering parts is certifiable, and thats what these look to be, if you have any intel on that situation, please let me know! -15x8/8.5 Watanabes, looks like ex-japan is the only option, as the right offsets are to hard to find 2nd hand -Facelift tails (dear god these have got expensive since my last car, if you have a set floating around at a reasonable price, get at me) -Some period correct front seats, similar in style to recaro fishnets, square shape, good side support etc, open to suggestion on this -Drive it! I've been to car meets with friends etc over the past few years and that is far more accessible fun as I get older Some pics of the car and some underbody stuff to give an idea of general condish, tried to buy a number of these, and they were all pretty rotten in comparison to this car, and for some reason this car we got for alot cheaper than we expected to pay, so i'm losing sleep over that, ah well. Yolo or whatever they say these days.1 point
I Have been trundling up and down the road a bit to see what falls off / what sucks / etc. What falls off: Exhaust off the one hanger at the moment. So will add a few more. What sucks: Getting a cramp in my leg because the ethrottle pedal is on a stupid angle. So I shortened that, and now its mint. I'm getting a general idea of fuel economy now that it's driving nicely. Including cold start, I'm getting around 10.9 liters per 100km when leaving my driveway and doing a few laps up and down the road driving gently. Not great, not hugely awful I guess. Will probably see some improvements diddling the VVT, afr target and ignition timing a bit. I could probably get it to mid or low 9s with some effort... But then I'm gonna jam in a 5.3 final drive ratio so it's all going to turn to crap anyway haha. I'm a bit better prepared for the dyno this time, I've got a full set of each of these to try out: doing some testing where I'm just looking at air fuel ratios though, it looks like the absolute shortest ones might be the winner. I keep getting sidetracked from finishing my airboxes, but a big milestone is having proper baseplates finished, and figuring out how it can go together and still be easy to put together. I have finalized something where there will be two alloy base plates that sandwich together. One half will be fixed onto the throttles, which will help make the whole assembly rigid which is good. Then the other half will be bonded to the airbox. Both made out of 6mm plate but milled down so that the perimieter profile locates the box correctly, then it only needs a few studs and cap screws to hold the halves together. Big thanks to Stu who is cutting these for me, much appreciated. Fusion 360 is looking preeeeetty fancy with its rendering these days! Unfortunately the real life versions are unlikely to look quite as pretty. But I'll do my best. Also I've been working on some branding for my products1 point
I see an em-dash. What are the odds you're an AI agent...?1 point
I just discovered now that tism is an acronym for. ‘this is serious mum’. Im on the drug that killed river phoenix1 point
Like many of us on here LG's autistic af.1 point
Never add up the receipts. It's fucking depressing. Last motor I built, (good while.ago now) I thought to myself, "this hasn't cost that much" I started adding up what I'd spent. I figured I'd spend $11-1200 tops. I got a bit over $3k, and decided to stop adding, and that I wouldn't bother adding that up again.......1 point
Car still with autosparky. It sadly wont be making it down as planned.0 points
