Showing content with the highest reputation on 05/07/26 in all areas
  1. Few pics from when I got it. Did spot a few areas of rust as these all have it , but this was not bad for one of these
    18 points
  2. Obviously you always find more rust as you dig, which is why most people won't dig because their car is "rust free" Yeah, right...... Anywho some of which I knew about, some I had suspicions, nothing too surprising though. Understand that I'm not going through this process twice, do it once so I can drive this for years to come Had my helper? If you call him that? Benefits of having a hoist at work Few late nights after work while the young fulla was with his mum trying to get shit done Stripped to bare naked chassis and waterblasted multiple times trying to get it clean
    15 points
  3. Ah soooo maybe I should do this to make myself accountable to see it through Here's my L200 I held out to find one worth buying This popped up on bookface I was like nah i won't get it some twat will beat me to it Stuff it sent the lady my number, "ring me, I'm seriously interested " Well hot diggity dang, it was some back n forth talking cause on bookface no one and I mean NO ONE is a genuine buyer on old mitsis unless you're some sick person like myself Eventually they realized bookface is full of f**kwits and rang me, "come and get it" And here we have it.... Deregistered 1983 L200 sport with a welside, one owner [local business] for one year then the second owner till he deceased around 2006 and it falls to my hands. Paid more then it's worth but I challenge anyone to find a better one I found the canopy locally off another tidy green one that had sold recently and buyer didn't want it. Rookie
    11 points
  4. Another huge update, Backs broken, tired asf. But it’s all one colour (primer) and 98% straight, just needs a tickle in places with fine filler, not long to go now before hitting the booth 😌
    9 points
  5. Horns came up mint! I went and grabbed that 56/7 Chevy wheel, it’s going to work These floor support/chassis mounts had been in the molasses for a month then blasted them. Theres one welded in and surfaces all prepped for plug welding Now once those tubes warm up in the Sonomatic radiola, the passenger has a dance floor for some boot scootin’! The drivers side coming along.. I got the toe board partially welded in when the great weather, became un-great So inside I went, and made a start on the exhaust
    8 points
  6. 6 monthly update for @Nominal No actual progress, but still runs and drives. Spotted a leaky frost plug though, source of coolant on the floor. At least this one is accesable without pulling the front cover and taking belt off....
    8 points
  7. So being that the rego lapsed it obviously needs a revin and repair cert for the rust patches This is where the rabbit hole begins ..... To do the rust in the cab it's easier to pull the cab off chassis so off with the panels, tray, glass, doors etc. Even had the young fulla on the tools Took it down to work to continue with the strip down and waterblast
    7 points
  8. Bit of maintenance that has snowballed a bit. Went to put new seals in the front calipers, pistons are a bit fucked so now I'm buying new front brake calipers. Also had to make a new brake hard line. and the radiator is showing signs that it may be about to leak so it's getting a new radiator too. In other news, these parallel jaw pliers are the absolute undefeated champion of getting flare nuts undone. Fuck your snapon flare nut spanner, these bastards NEVER fail.
    7 points
  9. I'd been thinking of how to make the exhaust hanger, I was going to use some 19mm stainless solid bar and turn up some bungs and weld it all together but I thought just keep it simple. I dug out my manual tube bender, bought some 16mm aluminium tube from Bunnings, bent it, squashed it and drilled some holes. I'm pretty happy with it. The seat is pretty cooched, I pulled it apart to see the condition of the base, it looked good from but far from good. i've cleaned it up as best I could and will treat it with some Por15. @felixx has offered to help me make a seat cover for it, what GC! For the time being I'll use this generic brat/cafe racer style seat I got from a swapmeet at the beginning of the year. I'll paint it black with some vinyl dye
    6 points
  10. I did a little more adjusting today and have got it running really nicely now. It’s got a nice smooth idle and pulls away really clean. stoked. Here are some photos of it in various carparks today displaying how badly the front end needs to meet my grinder.
    6 points
  11. I’ve just gone over the air idle again since I did the last float adjustment and now it’s running really nicely 🙌
    5 points
  12. I have snuck an hour or so here and there to fiddle a wee bit, ie removed and labelled all of the loom stuff still attached and took off the massive intake. This morning I printed a plate to bolt onto the intake ports and cover the holes. Forgot to take a pic tho. Also today I modded the shift tower to be 90 deg rotated, and now points to the front of the engine. This was pretty trivial IRL, the forwards/backwards lever was held on the shaft by a roll pin inside another roll pin, so all I had to do was knock those out and drill another hole 90deg around. Then I chopped off the pivot for the left/right lever and fabricated a new one that is held by the tower bolts; Ill obviously need to set up a new cable holder bracket but that should be easy. Some mental gymnastics took place for all this and one part of that is that now the lever directions are flipped, which means the shifter will work as per the normal pattern but spun 180deg with the cables poking out what will now be the back, so it can go in the cabin probably unmodified. It will probably still need some loving but in principle that is sorted.
    5 points
  13. Spicy(ish) noodle time! Its easy right? Just install one fuse at a time and clear each circuit one by one... Except it aint, I got the engine running but as soon as I looked at the light switch its all over with multiple fuses poping, some times. When things started to go better the new front indicator/parklight buckets had no light, no worries, I bet they cheaped out and ship with no bulbs, install bulbs and still the same but the fuses now aren't blowing, eh wot? so open up the new buckets to find not only did they ship with no bulbs, no one bothered to connect the wires either! Yeah that'll do it. So easy job just hooking up and going for it right? 3 wires, park light, indicator and ground, except the new buckets needed two ground wires, eh wot? Original left, new right. In original form, the aluminium housing only needs the one ground connector. So new plan, polish up original units and combine them with new rubbers and lenses. Goodness, driving must be getting close now!
    4 points
  14. Yeah it was still running terrible 🫠 I’ve brought myself a vacuum gauge and watched a few YouTube videos and set about going over the basics, one thing at a time. I’ve never really played with carbs on a car before and only gone as far as setting the timing. I rechecked the timing, and tested the new vac advance unit to make sure it was working. Doing that showed up the first issue, I had clamped the hose to set the timing but it either already had vacuum, or it sneaked by anyway, so instead of 12deg base timing, it had 2deg… So I fixed that. Then I checked the float levels, the front was spot on. The rear had the screw wound in to the point the adjuster hex wouldn’t pick it up to wind it back out. I pulled the bowl off (which was dry), adjusted it out to what looked reasonable and refitted it, but then no amount of adjusting was getting the level up to the weep hole. So I gave the bowl a tap with the screwdriver handle, which freed up the stuck float valve and then sent a fountain of fuel out the top. A few more taps and it seemed to be working properly, so I adjusted the level and suddenly the idle smoothed out quite a bit. Next I hooked up my vacuum gauge and set the air idle. At the end of this I had a beautiful smooth idle, and really nice snappy response. It had a nice 20in-hg vacuum and I was a happy boy. So I shut it down, and came back a few minutes later to find a puddle in the manifold and one of the secondary throttle shafts dripping a teensy bit. Bugger. I was hoping that it might just be that I had left the rear bowl a little high, and was planning to take the kids for a drive, so I fired it up, brought the rear bowl down to where it should actually be and set off for town. Now my beautiful smooth idle is utter shit again… But it does all drive much better with proper timing stuff happening! My current working theory is that it probably has a vacuum leak at that throttle shafts, and that my nice idle was probably being supplemented by the bowl level being high and feeding it extra juice. In driving, it really feels terrible in light throttle (high vac) cruising, like 70km/h slightly downhill. Ill get a can of carb cleaner to squirt at it and test for leaks tomorrow. It is nice to know that several problems are now solved though, and hopefully I’m nearly there… I don’t have any photos with sharing, so here is the mockup my kids and I did today of our trolley derby racer.
    4 points
  15. Oh yeah the oil filter manifold thingy. This holds the oil filter as well as the lines to the oil cooler. I gave that a proper clean out too of all its gross old oil and gasket'd it into its happy home. It probably makes sense to protect that oil filter connection too... with an oil filter. And I might as well get some other bits while I'm out... I also had a sparky mate drop by with a bunch of old office LED lighting It's soo much better and brighter than those old fluorescents! Really lights up how messy everything is, though... Something that caught my eye during disassembly is a coolant pipe that didn't look so great at first glance. I wanted to get a better idea of things though, so I gave it a clean and put it in evaporust. Yeaah.... it's toast... there's no just building up some weld or moving the bead further down. It seems like a simple part to source/build though. A problem for another day. On to the rocker cover. It's a little manky and a fair amount of the paint has flaked off towards the rear of it, so I'd like to zhuzh it up. The SIRIUS sticker is not in amazing condition, and it doesn't really spark joy in me, but I decided to gently lift it just in case... maybe I'll stick it somewhere out of the way. The area behind it is flat, fortunately, so there won't be a strange divot. I briefly attacked the cover with mechanical means to remove the paint before busting out the stripper. It took 2 and a bit coatings to remove the bulk of the paint. It turns out that heat-resistant enamel paint is really good at resisting heat from a hot air gun, who knew? Then it's just a bit of light sanding to get rid of the straggling bits. I'm probably being a bit anal here as it doesn't have to be a perfect strip. I'm going to be wrinkle painting it. The instructions (when you find them) are funny about whether it wants primer or not. I decided to use some engine enamel primer just in case... I can always strip it again if things suck. Figuring it's probably easiest to remove the paint now rather than later, I bristle'd the paint off the lettering when it had become touch dry, then attacked it the next day with sandpaper from 320 through to 5000 grit. I also polished it with a wheel but I don't think it's actually noticable, won't bother again. Unfortunately this is when I remembered that uncured engine enamel is chemical sensitive to wax and grease remover... But it's okay, I'll be using wrinkle paint ;). I just touched up the primer and sent it. The wrinkle paint I got has mixed reviews on SCA, as many things do. Most people are super happy with the effect it gives. Quite a few, however, report that it sucks and doesn't wrinkle. Some people attack it with a heat gun to get it started... not just this product, but others I found online, too. And if you search DIY wrinkle paint you can see some horrible jobs from people who took this path. The instructions are utterly unprovided for the product, you have to search for the data sheet online. I decided to stick to them once I found them, and they say 1. lay it super thicc 2. it won't start wrinkling for hours 3. it can take up to a full day to finish wrinkling 4. you can use a heat gun if you absolutely must So I laid three thicc coats to the rocker cover, and laid thicc sweet words to girlface to help offset any potential anger once she realised I'd moved it inside the warm house to dry while we were out. You can see there's no wrinkling going on, maybe some orange peel at best. Fortunately, a few hours later when we got home... The rocker cover and I were then kicked out of the house and into the garage. I razor bladed off the lettering (first with a metal one, then realised my error and moved to plastic) and let it finish its journey in that cold (but not dark) place. At the same time, I was preparing my 'new' oil pan. The original was quite beat up and had some worryingly sharp bends, and the pickup was also oddly bent at the bottom, so I'd put out the call for a new set. I think I should have asked for more photos though as what I received was marginally better. But still better. Forgot to take pix but the pickup mesh holder was also bent slightly; I used gentle vise movements to get it back into a more reasonable shape, and cleaned the absolute heck out of it. Here's the new pan after scuffing and W&G remover, which also indicated that the paint is also uncured engine enamel. Makes things easier, I guess. This one dried in the garage, with the first few hours babysat by a heater. Then back inside for curing... :3 Technically this doesn't have to happen, engine operation should cure the part as well, but I'd like to have some level of hardness during reassembly. I just had to keep moving it around every 5-10 minutes with a careful eye on my temperature gun. I think it worked. I then (picturelessly) enfitted the pickup tube and its permatex'd gasket, cleaned the sump bolts in ultrasonic petrol, and got the sump on the engine. It came with a paper gasket but there seems to be mixed information about how to seal the sump. Some sources say just to use gasket maker, others to use gasket maker with the paper gasket (including mitsi). I could have used the liquid permatex but ended up just applying a thin smear of permatex ultra grey to both sides of the paper gasket like one version of the manual said. If this was a bad move and it fails, it doesn't seem like it'd be hard to redo using another method. I then got all excited and re-polished the rocker cover lettering (the wrinkle came up fantastic), attached the new rubber gasket, applied ultra grey in the corners, got the final piece of the front cover attached and made me a long block <3
    4 points
  16. Got this going yesterday, after spending way too long making a new throttle linkage /pull this is the most ive made on stock cams - 125kw, the 129kw blue is uncorrected. the dyno over corrects a bit. so on a cold day the corrected power is lower than the corrected power on a hot day. so probably around the 127kw mark. which is pretty silly on the little stock cams. head also has pretty much stock exhaust side, i just zing'd a couple bumps off. still has the og toyota valve job. So looking good to do the same to big valve head
    4 points
  17. Bracing for the top end is all done ready to bolt in place and should tighten it all up. On to the pivot points.
  18. Took the Chal to cars and coffee with the bro who recently got this 140 swapped z50. went for a rip around town. realised my rear sprocket has some major play. put it up on the strops and took it apart. missing a circlip. Must've never been in there. lost some metal on the swing arm so lucky i spotted it early. ish.. Rear wheel bearings are toast because of it too. We will rebuild!
  19. Find one being ripped out of a safari for an RB swap and they are already factory turbo with boost compensated mech pump. They like to cook heads if not looked after properly but what 90s diesel doesnt. @Beaver is your man for RD knowledge
  20. Decent test running well Its alil bit of a egg to start dosnt take much but always needs a tickle of gas down the carbs to start ifu do it starts rite up ifu dont it won't but other than that bikes solid. So alil bita tinkering but all in all its prety decnt Has no issues revving out ect and rides well for what I want it 4 its fine
  21. More progress. Gotta say having a deadline does a hell of a lot for motivation 😅 because I want to get the car as straight as possible (and am only allowed the booth for a single Saturday) the plan is to do a closed door respray, so getting all non-closed door parts out of the way, ergo door jams are now done 🥳 next up, the insides of the doors so they can be bolted back on
  22. I had some dried fuel in the secondary needle and seat in my 600 Holley a while back from not getting used much. Made it leak fuel and idle like poos. @Shaz's Dad told me to clean it out and use my car more......... Bit of W.O.T to open up secondarys flushing fresh fuel through can't hurt now and then aye. Totally sick car too mate you've done really well getting it sorted, well done.
  23. The s-type is a bit of a cunt because not only does the sump have to clear the cross member but also the steering. There are ways around that of course but more work.
  24. I love these utes, they drive so good.
  25. Current state of affairs It's about to get 24v from a couple of car batteries with a headlight bulb in series to hopefully stop the smoke coming out and I'll see if I can get any sort of communication out of the usb - rs232 converter and will see if the manual controls work
  26. Yes! Why do you think I bought a running (poorly) musso for less than half the cost of a 606. I've got three om662, manual gearbag and conversion flywheel and still less than 606 long block And the single cam 662/602 have narrower heads
  27. Tighter than a nun's fanny in the S type bay. Quite impressive that blokes squeeze V8's into them. Today's job is finding a blockage in the fuel line after getting gummed up with stale fuel due to lack of driving it.
  28. How about om662, Om602 or om606?
  29. It's the interfacing with the rs232 port on the vending machine side that'll be the fun part Plugged it in again and smoke came out of the fan hole Yup that'll do it Wacked a spare slightly smaller 24v power supply in It was flashing on and off like it was hitting overload. Hopefully when the smoke came out of the old power supply it didn't take anything else out with it. Had a go at the thin client that came out of it. Yup it's dead. Full fan noise and nothing happening Only thing I have with a vga port is the old xp laptop Touch screen works It is now being used to hold its own parts
  30. Deezil spam. Funny that ya can't pass a wof because a sun faded or frayed seatbelt might kill you, yet they are fine to sling round a 400+kg lump of iron.
  31. Once you get it working, you can fit it into your daily life as a high-security pantry with inventory management and automated online reordering, while you work your way up to building a Rube Goldberg breakfast machine.
  32. May I present the latest in procrastination. The autocrib, 2 meters tall weighing in at 350kg. It is(was) a automated vending machine (automated and vending does not apply at this point in time) Slightly sketchy unload with lots of puckering Me to myself. "it'll fit in the carport" Yeah just
  33. My mrs & I stayed at Takapuna Beach Holiday Park over the last weekend in the Lilliput. I lost count of the amount of good folks that happened to walk passed and shared a nice compliment about the van and even the truck too.
  34. No, toolscome out of the tool budget. Thats what I tell the wife.
  35. I think I've said multiple times that this is rust free now, but there keeps being more pop up! After blasting showed up these holes in the lower a-pillar/cowl area. Was a bit worse than expected once I cut the outer off. That's the backside of the lower hinge mount, so had to be fixed to a decent standard. 3d scanned, cad'd and 3d printed a press die to punch out a new panel to repair the hinge pocket backer. A bit of prestretching and shrinking and it worked really well. All repaired and painted in KBS. Outer repaired and welded back in. Otherside was a touch worse on the inside compared to the outside. The heater core needed repairing and would of set me back at least a few hundred dollars, so went though Rockauto and found a Toyota Camry heater core for sub $100 that would work with some slight modes. Had to lengthen the core housing for it to fit and then drew up a new front mesh to suit. New heater mounts welded in and a 3d printed outlet or some adjustability on the vent. Over Easter I got the front panels blasted and all in epoxy primer. On to getting the panels all aligned best I can and gapping it right. Made up a battery mount for in the boot behind the r/h rear wheel tub. See you in another year for an update haha
  36. Me hands are giving me jip this week so light duties this weekend. Last week I knocked up a drivers toe board, this week I roughed out the other side and both front floor pans. Made a start on the tricky corner section of the trunk floor. Here’s the ones I’ve just completed on the 57 at work: The headliner bows weren’t labelled, no surprises there. Tested them in the roof and believe I have something cooking so labelled and rust killed, stuffed them into the liner to help take out the shipping wrinkles. I’m missing one so I bent something up. Brought a pack of red dye and boiled the headliner windlace for 4x longer than it said I needed to, cant say it’s made enough of a difference. Dang Took the bolts and clips out of the front end inner guards/ rad support etc and will drop them off for a sandblast. Also stripped the interior mouldings/screen surrounds out and will see about a blast and powder coat or HPC coating to look chromie.. church up the inside to match the out! Whipped off the tiller and unwrapped to make an action plan. I wanted a lucite/clear and metal flake setup but too much effort. I’ll do mine white and then spray lots of clear with some sparkle in it. Can be a future side project. In the mean time There’s a sound 56/7 chev 2 spoke locally on marketplace so I might grab that and splice my centre in and transition it into the spokes with some filler.. anything to avoid making and sanding a rim with all the indents by hand.. Project creep: blasted horns and gave a quick wire wool polish to the alloy before some clearcoat. They are aren’t gonna win any awards but they will look better than factory intended
  37. Another update and heaps of progress! Engine bay is rust proofed, seam sealed, painted and ready to start going back together permanently 🙌 Honestly feels like such a huge milestone has been hit with this and I am absolutely stoked with how the colour has come out, I definitely think I picked the right silver and the car is going to look absolutely sick in it. Also sorted out the underside of where the guards go and the underside of the guards themselves. For the basecoat and clearcoat I didn't want to cheap out and went with DeBeer, it's a high-quality paint system and I used to work at a distributor for it so feel free to call me a little biased 😉 Base and clear were bloody expensive, so anywhere you can't see is going the 2k matt black, everywhere you can see will be the silver. Still got a couple of major rust repairs to sort, found a weak spot in the chassis that's been rusting from the inside that needs to be cut out and welded, I'm going to get a proper engineering shop to do that one and the rusted out boot lip where the boot rubber goes on needs to be sorted but I'll need to get help with fixing that boot lip as it's a bit beyond my skill set! I've got baby number 2 dropping in 6 weeks and I really want to get this body painted before she arrives so for the next few weeks I'm going to be in the garage every night sanding and priming the door jams, put the doors and guards back on, get everything perfectly straight and paint the whole body up to where the tail lights sit since the boot lip needs doing. Then windows can go back in and I can slowly just start putting the car back together... I've learned with this project that you don't realize how much progress you've really made on a car until you get to the point where you're starting to lay down topcoat like I am now and just think to yourself "holy s***, I really have done alot to get this car to this point." Every step gets me closer to the day I finally get to roll up to my local caffeine and gasoline and I was actually thinking about this the other day, besides my friend circle and you guys, nobody actually knows about me doing this project in my garage, so I'm just gonna roll up one day and everybody there is going to be like "wtf" and just steal the show 😎
  38. I was feeling by a bit self conscious about all the grinder noise in the carport so I decided to put the frame in the shed. Tight squeeze! now I can start on the exhaust at nights. The trunk bumper pad always seems to pus out on these things. Neat wee profile I also melted out the lead in the very corner and patched, but forgot to photograph before etching. Can see it in background. Spent a while in the wheel arch, quick and dirty cause it’s a shit spot to work, & it’s going to be seam sealed and undersealed. Not a particularly smart design for longevity, will be fine when I seal it up properly Shout out to the plug-weld hole puncher, I forgot it last weekend and drilling holes was painful compared! Can swap the punch pieces for bigger and smaller sizes in the set. My headliner came in from Rock.. Always wanted a car with red guts! Will tone it down heaps with blacks and greys but red roof will be tits. Unfortunately they sent me the wrong windlace..ordered Maroon and got Cashmere. Too hard to send back so hopefully it takes some dye
  39. so the last few days went like this In that order. I found some pictures of that port and that hole wasn't there when i put the head on. so was thin enough, that in the 20 sec the engine ran, vac pulled what little material there was there out. managed to slide hammer the insert out, so could get tig down there to weld the hole. hole was in head not insert. Seemed to have a bit of material around the hole. so just a thin spot in the casting. fun times. but that's why this head is a test run
  40. Progress update for @Nominal Car has moved 90 degrees. With the ute all sorted now and back on the road, time to start on this.
  41. 1 point
  42. Since the last post I have still been working through this mildly. I had a look through my gearbox bits as the shifter still needed to be fitted to the box as it had been shortened years back. Little did I know that only the shifter housing and shift lever were returned to me, none of the other internal components including the lower and rear spring assemblies (I believe these are to stop you from over throwing into 5th and keep resistance from accidently bumping into reverse), also the shifter block and return spring. This was a pain to discover as I know it is gonna be a mission to find spares to replace. I then stumbled upon a s5 turbo gearbox for sale on trademe which I got excited about and ended up bidding way more than I had planned to spend. Looks like I'll be making a mission down to Morrinsville next week to go pick it up. In the background I'll find the other bits I'm missing to get the current gearbox complete. Separate to this I have been trying to work out the gauge cluster. I previously gutted and split the original cluster as I had the custom speedhut gauges made up. The plan here is to reuse the oem dash lights (such indicators and oil light, I might modify the park to be highbeam). I can reuse the gauge circuit board to power these as I still have the original loom. I'll then remove the original gauges, make a mounting plate for the new ones and marry them all together. As speedhut have a sale on, i have ordered another speedo that runs off vss, as opposed to the gps one I have already, as this can't be run legally, so if anyone is after a gps speedo let me know and I'll do a mean deal on this one. Chur
  43. Fucking legend! I'll be a gc and print him a copy and laminate it
  44. You missed the AND - so to require a cat for wof it must be all 3 - not have a motorsport card - be built after 1990 - be registered in nz after 2010
  45. Yeah its first registered in 2003, doesn't need a cat, its in the virm as per what @tortron posted
  46. You are a visionary, although its probably just the mushrooms.
  47. I had to get the E36 valued for insurance purposes. The valuer asked me to list out what I’d spent. Just big ticket items got to 85k, and that’s not including the first LS that died on the dyno, or any small things (oils, heat shielding, lots of other shit) So I’ve spent over $100k on a $2k poo spec auto e36, and now it’s insured for 40. E30 probably owes me $30+ at this point, but I won’t add up until someone makes me. Cars are a great investment.
  48. My strategy is Grow weed Sell weed for $ Spend $ on cars. No records kept cos that would incriminate
