Showing content with the highest reputation on 04/07/26 in all areas
  1. Oh yeah the oil filter manifold thingy. This holds the oil filter as well as the lines to the oil cooler. I gave that a proper clean out too of all its gross old oil and gasket'd it into its happy home. It probably makes sense to protect that oil filter connection too... with an oil filter. And I might as well get some other bits while I'm out... I also had a sparky mate drop by with a bunch of old office LED lighting It's soo much better and brighter than those old fluorescents! Really lights up how messy everything is, though... Something that caught my eye during disassembly is a coolant pipe that didn't look so great at first glance. I wanted to get a better idea of things though, so I gave it a clean and put it in evaporust. Yeaah.... it's toast... there's no just building up some weld or moving the bead further down. It seems like a simple part to source/build though. A problem for another day. On to the rocker cover. It's a little manky and a fair amount of the paint has flaked off towards the rear of it, so I'd like to zhuzh it up. The SIRIUS sticker is not in amazing condition, and it doesn't really spark joy in me, but I decided to gently lift it just in case... maybe I'll stick it somewhere out of the way. The area behind it is flat, fortunately, so there won't be a strange divot. I briefly attacked the cover with mechanical means to remove the paint before busting out the stripper. It took 2 and a bit coatings to remove the bulk of the paint. It turns out that heat-resistant enamel paint is really good at resisting heat from a hot air gun, who knew? Then it's just a bit of light sanding to get rid of the straggling bits. I'm probably being a bit anal here as it doesn't have to be a perfect strip. I'm going to be wrinkle painting it. The instructions (when you find them) are funny about whether it wants primer or not. I decided to use some engine enamel primer just in case... I can always strip it again if things suck. Figuring it's probably easiest to remove the paint now rather than later, I bristle'd the paint off the lettering when it had become touch dry, then attacked it the next day with sandpaper from 320 through to 5000 grit. I also polished it with a wheel but I don't think it's actually noticable, won't bother again. Unfortunately this is when I remembered that uncured engine enamel is chemical sensitive to wax and grease remover... But it's okay, I'll be using wrinkle paint ;). I just touched up the primer and sent it. The wrinkle paint I got has mixed reviews on SCA, as many things do. Most people are super happy with the effect it gives. Quite a few, however, report that it sucks and doesn't wrinkle. Some people attack it with a heat gun to get it started... not just this product, but others I found online, too. And if you search DIY wrinkle paint you can see some horrible jobs from people who took this path. The instructions are utterly unprovided for the product, you have to search for the data sheet online. I decided to stick to them once I found them, and they say 1. lay it super thicc 2. it won't start wrinkling for hours 3. it can take up to a full day to finish wrinkling 4. you can use a heat gun if you absolutely must So I laid three thicc coats to the rocker cover, and laid thicc sweet words to girlface to help offset any potential anger once she realised I'd moved it inside the warm house to dry while we were out. You can see there's no wrinkling going on, maybe some orange peel at best. Fortunately, a few hours later when we got home... The rocker cover and I were then kicked out of the house and into the garage. I razor bladed off the lettering (first with a metal one, then realised my error and moved to plastic) and let it finish its journey in that cold (but not dark) place. At the same time, I was preparing my 'new' oil pan. The original was quite beat up and had some worryingly sharp bends, and the pickup was also oddly bent at the bottom, so I'd put out the call for a new set. I think I should have asked for more photos though as what I received was marginally better. But still better. Forgot to take pix but the pickup mesh holder was also bent slightly; I used gentle vise movements to get it back into a more reasonable shape, and cleaned the absolute heck out of it. Here's the new pan after scuffing and W&G remover, which also indicated that the paint is also uncured engine enamel. Makes things easier, I guess. This one dried in the garage, with the first few hours babysat by a heater. Then back inside for curing... :3 Technically this doesn't have to happen, engine operation should cure the part as well, but I'd like to have some level of hardness during reassembly. I just had to keep moving it around every 5-10 minutes with a careful eye on my temperature gun. I think it worked. I then (picturelessly) enfitted the pickup tube and its permatex'd gasket, cleaned the sump bolts in ultrasonic petrol, and got the sump on the engine. It came with a paper gasket but there seems to be mixed information about how to seal the sump. Some sources say just to use gasket maker, others to use gasket maker with the paper gasket (including mitsi). I could have used the liquid permatex but ended up just applying a thin smear of permatex ultra grey to both sides of the paper gasket like one version of the manual said. If this was a bad move and it fails, it doesn't seem like it'd be hard to redo using another method. I then got all excited and re-polished the rocker cover lettering (the wrinkle came up fantastic), attached the new rubber gasket, applied ultra grey in the corners, got the final piece of the front cover attached and made me a long block <3
    15 points
  2. Got this going yesterday, after spending way too long making a new throttle linkage /pull this is the most ive made on stock cams - 125kw, the 129kw blue is uncorrected. the dyno over corrects a bit. so on a cold day the corrected power is lower than the corrected power on a hot day. so probably around the 127kw mark. which is pretty silly on the little stock cams. head also has pretty much stock exhaust side, i just zing'd a couple bumps off. still has the og toyota valve job. So looking good to do the same to big valve head
    9 points
  3. Spicy(ish) noodle time! Its easy right? Just install one fuse at a time and clear each circuit one by one... Except it aint, I got the engine running but as soon as I looked at the light switch its all over with multiple fuses poping, some times. When things started to go better the new front indicator/parklight buckets had no light, no worries, I bet they cheaped out and ship with no bulbs, install bulbs and still the same but the fuses now aren't blowing, eh wot? so open up the new buckets to find not only did they ship with no bulbs, no one bothered to connect the wires either! Yeah that'll do it. So easy job just hooking up and going for it right? 3 wires, park light, indicator and ground, except the new buckets needed two ground wires, eh wot? Original left, new right. In original form, the aluminium housing only needs the one ground connector. So new plan, polish up original units and combine them with new rubbers and lenses. Goodness, driving must be getting close now!
    7 points
  4. I have snuck an hour or so here and there to fiddle a wee bit, ie removed and labelled all of the loom stuff still attached and took off the massive intake. This morning I printed a plate to bolt onto the intake ports and cover the holes. Forgot to take a pic tho. Also today I modded the shift tower to be 90 deg rotated, and now points to the front of the engine. This was pretty trivial IRL, the forwards/backwards lever was held on the shaft by a roll pin inside another roll pin, so all I had to do was knock those out and drill another hole 90deg around. Then I chopped off the pivot for the left/right lever and fabricated a new one that is held by the tower bolts; Ill obviously need to set up a new cable holder bracket but that should be easy. Some mental gymnastics took place for all this and one part of that is that now the lever directions are flipped, which means the shifter will work as per the normal pattern but spun 180deg with the cables poking out what will now be the back, so it can go in the cabin probably unmodified. It will probably still need some loving but in principle that is sorted.
    7 points
  5. Another huge update, Backs broken, tired asf. But it’s all one colour (primer) and 98% straight, just needs a tickle in places with fine filler, not long to go now before hitting the booth 😌
    6 points
  6. Yeah it was still running terrible 🫠 I’ve brought myself a vacuum gauge and watched a few YouTube videos and set about going over the basics, one thing at a time. I’ve never really played with carbs on a car before and only gone as far as setting the timing. I rechecked the timing, and tested the new vac advance unit to make sure it was working. Doing that showed up the first issue, I had clamped the hose to set the timing but it either already had vacuum, or it sneaked by anyway, so instead of 12deg base timing, it had 2deg… So I fixed that. Then I checked the float levels, the front was spot on. The rear had the screw wound in to the point the adjuster hex wouldn’t pick it up to wind it back out. I pulled the bowl off (which was dry), adjusted it out to what looked reasonable and refitted it, but then no amount of adjusting was getting the level up to the weep hole. So I gave the bowl a tap with the screwdriver handle, which freed up the stuck float valve and then sent a fountain of fuel out the top. A few more taps and it seemed to be working properly, so I adjusted the level and suddenly the idle smoothed out quite a bit. Next I hooked up my vacuum gauge and set the air idle. At the end of this I had a beautiful smooth idle, and really nice snappy response. It had a nice 20in-hg vacuum and I was a happy boy. So I shut it down, and came back a few minutes later to find a puddle in the manifold and one of the secondary throttle shafts dripping a teensy bit. Bugger. I was hoping that it might just be that I had left the rear bowl a little high, and was planning to take the kids for a drive, so I fired it up, brought the rear bowl down to where it should actually be and set off for town. Now my beautiful smooth idle is utter shit again… But it does all drive much better with proper timing stuff happening! My current working theory is that it probably has a vacuum leak at that throttle shafts, and that my nice idle was probably being supplemented by the bowl level being high and feeding it extra juice. In driving, it really feels terrible in light throttle (high vac) cruising, like 70km/h slightly downhill. Ill get a can of carb cleaner to squirt at it and test for leaks tomorrow. It is nice to know that several problems are now solved though, and hopefully I’m nearly there… I don’t have any photos with sharing, so here is the mockup my kids and I did today of our trolley derby racer.
  7. 50x50x5 angle will be well strong enough There isnt a recipe in the book for what you're doing , as long as the bolts are at least 8mm for each corner , it bolts to the original floor anchorages, and its an unstressed seat, the certifier can just use common sense when assessing it
  8. I has been a few years since I had anything classic, since the departure of my XJ40 (which unfortunately became too much of a hassle for me and didn't realistically have the space to work on it properly - I had ended up losing that lovin' feeling). 5 years ago when i got a 1990s Royal Enfield Bullet for shits and giggles, this got me back into bikes, which is where my original passion for vehicles began (I sold my last bike when we left Auckland in 2013, which also helped with the house deposit - how times have changed). As much as fun as it was, I decided that I liked riding into work (rather than the loser cruiser), so decided that I need a modern bike for that purpose (you know, actually starting when you need it to etc). So off went the Royal Enfield and then I got a BMW G310GS, to ease back into the game as it were. That scratched an itch for a while, but around 2 years after that, I wanted to get back on a Triumph (last bike in Auckland was a Bonneville). So off went the BMW and in came my current daily, a 2008 Bonneville. But still, 2 years later, I had the itch for something to spanner on (wife could see this too). So I decided that I needed a classic bike and a daily bike. I had been pining for a Meriden Triumph, BSA etc, but then came across a 1987 GPZ900R. Now being a child of 1986 and a fan of Top Gun......well.....I just kinda had to go for it. So anyways, this has landed at my place: The current plan is to get her back onto the road (rego is on hold) and give her a Top Gun style. Also came with essentially a second bike, minus the engine and fuel tank. No doubt in the coming weeks, I'll realise the suffering I have brought upon myself, but fuck it, we'll have some fun......
  9. Deezil spam. Funny that ya can't pass a wof because a sun faded or frayed seatbelt might kill you, yet they are fine to sling round a 400+kg lump of iron.
  10. I have been thinking this also as its engine out to replace the clutch and trivia to have a look right now. Good to have a heads up about the fork too, cheers.
  11. You are a visionary, although its probably just the mushrooms.
  12. So, about that pile of windscreens. The original or windscreen #1, last seen intact about the time it came back from the sandblasters, (who took a considerable amount of care to keep protected from blasting) met its end at my fumbling hands when I decided to remove it to be sure a rust patch wasn't creeping into something larger. This really stressed me out as I assumed finding new one may end up being a high dollar import. In a stroke of luck, the local auto glazer got me a new one for what could be considered pocket change compare for what I was bracing myself to pay. Feeling relieved but also cautious, that was installed with new seals and trim. Unfortunately...... while excitedly trying to seat the trim which did not like seating fully in the new rubber I pushed just a bit too hard cracking it in almost the same spot as #1 but from the other direction. #2 seen in the naughty pile over the back got a whole lot worse due my very lack of fucks to give removing it. Queue a very embarrassing phone call to the glass man to ask for another, but yes, they did have another I could pick up, write that down as stupid tax I guess. This made me much more cautious and observant the second time around, what I think happened is the new rubber wasn't shaped to the bottom of the frame like the old was that I had removed a number of times, this meant the screen was pushing hard against the top and in a position it didn't want to be in all made worse by me trying to push a seal into a grove it couldn't fit in. Second time round, noticing this and taking care to seat the screen down, everything went together just like in the youtube videos. Stupid rushed mistakes make for good learning? I did get to enjoy one moment from this episode, windscreens make a wicked noise when tossed into the concrete pit at the dump.
  13. Thought it would be a cool idea to start documenting my build with more people than just my friend circle. About a year ago I bought this 1978 Nissan Skyline C210 from a guy in the South Island. Progress has been slow as I've had to juggle work family time and friend time while still trying to find time to work on it. But the majority of the rust has been cut out and welded, I've almost finished panel beating the car, ready to be primed up, engine bay is prepped, underside has been stripped and painted matt black, interior is next to prep. I'm planning on painting it the modern(ish) Nissan KR4 Sonic Silver, still a skyline colour, just not a colour that was available when this car dropped but true to the skyline spirit Originally I purchased an L20ET to put into it but made the decision recently that I'm instead going to go down the RB route and have purchased an RB25DE, the power figures from the factory setup of the L20ET just didn't quite cut it for me. I'm torn between going for ITB's on it as something unique or doing the tried and true +T. Thankfully the previous owner of the C210 already did alot of the work for the RB swap, RB Subframe with adjustable suspension, RB bell housing on the gearbox and steering rack out of an R33 so this RB should be a straight drop in for the engine anyway! (still gotta organize wiring and ECU)
  14. It looks like the software was a fancy Excel sheet that could run a macro and pop a solenoid. You can probably get Claude to vibecode something similar if you can figure out the signals
  15. Hard drive is totally missing unfortunately my hope was some attempt at data recovery. It has a windows 7 sticker on the side of the pc so might a replacement pc from the og xp machine who knows Will plug my laptop in and see if it recognises any of the usb devices and go from there Why limit it to just the pantry! One stop automated password controlled vending machine. Shitty nuts and bolts, beers, rums and snacks at the push of a button
  16. Awesome, it will run a POS (in every sense of the acronym) XP build You might be able to recovery some of the data on the drive even if its mostly dead? It would be cool to set those trays up with all the sizes of nuts and bolts, and just dial in the ones you need and BING they pop out hot and fresh
  17. Once you get it working, you can fit it into your daily life as a high-security pantry with inventory management and automated online reordering, while you work your way up to building a Rube Goldberg breakfast machine.
  18. I'm a qualified personnel Took the side off Look at all the storage possibilities I'd wondered how it knew the positions of the bins/stacks. Got a wheel on the bottom with various holes for the positioning The seller advised me that the hard drive had died. I extracted the pc out of it and the hard drive was indeed dead and buried A friend has a old hard drive I can have so I'll collect that at some point, reinstall windows and see if I can track down the software for it
  19. May I present the latest in procrastination. The autocrib, 2 meters tall weighing in at 350kg. It is(was) a automated vending machine (automated and vending does not apply at this point in time) Slightly sketchy unload with lots of puckering Me to myself. "it'll fit in the carport" Yeah just
  20. What are you going to put it in? A 1kz isn't going to win any races in stock trim but can make plenty of power pretty easy
  21. Welding is fine if done by a competent welder The design of the bracketry is probably more important than the welding , ie gussets on flat bar sections A bit like engine mounts, if the design of the bracketry is correct then you can use thinner materials
  22. Fucking legend! I'll be a gc and print him a copy and laminate it
  23. Engine looks great, I do love a good wrinkle. Now you just need to get a new oil cap to match the new hotness 😛
  24. If it's just for testing, can't just hook it up to a car battery with the car running? Amp / sub would be more than a PSU (cheap, old one) would handle so flag that idea. /Just install them in the Datsun already, we won't judge.
  25. I should have a few of those pipes in my stash. Will have a dig this afternoon. I need to chop one up for my dohc motor so I'd rather kill a rusty one
  26. Probably correct, but 1.9tdi are common enough in NZ. Absolutely massive aftermarket support for them, or mix and match from the VAG parts box. PD100 would be the most common flavour over here, a new set of nozzles and you're away laughing. PD130 builds on the above, bonus points if it's a BLT code from a Fabia RS as that gets all kinds of nice goodies like a forged crank, titanium fracture-split rods etc. PD150 is the garden variety version of the above, but has longer head bolts which are handy for winding the boost up. If you get your hands on a BLT, they do much better than they should (PD130 means Pump Duse 130hp - Unit injection, so one injector pump attached to each injector). Darkside in the UK tested as many bone stock Fabia RS as they could get their hands on and not one produced less than 140hp at the wheels, with the highest being close to 180hp. Get thee to a wrecker, ASAP!
  27. Had a similar situation on the Imp and the engineer wasn't sure about it and kept saying he'd get back to me. What I ended up doing is giving the completed half shafts to a machine shop who spun it in a cool old machine that measures deflection and wrote me a short report/permission slip which the cert man glanced at.
  28. Maybe a winter 27 meet might be more feasible? Hanmer could feature in next ywars moped melee yet. That's usually a good time to grease up the camp to let us stay there again.
  29. My mrs & I stayed at Takapuna Beach Holiday Park over the last weekend in the Lilliput. I lost count of the amount of good folks that happened to walk passed and shared a nice compliment about the van and even the truck too.
  30. Atleast this has aged better than Kelly McGillis
  31. We've found a great house in Spreydon - move in date is August 8th provided nothing silly changes in the next wee while. I'll be moving things up from Qt to Chch between July 13-27th. Thanks for everyone's help so far! I'll be in touch about storage / beds that have been offered once I work a few more things out. It's all starting to feel real now.
  32. And thats the second time this week I can confidently say that.
  33. The more I look the more suitable it seems. Like when I overlay the engines, ie where the X actually sits and where the suzy wants to be, the axle position is pretty much exactly the same. And the existing engine support crossmember will only need a couple of tweaks to clear, but still leaves heaps of room for the exhaust to run beside it. I will strip some more shit off the engine this weekend. It sucks I have so much other shit i really need to finish before I can really sink my teeth into this, I am fizzing for the fun to start....
  34. Well thats interesting, I put one of the scan pics up on a X1/9 fb page and this got posted; So that is extremely promising..
  35. Those CV angles, could you at least use the opportunity to create something with portal axles? (Sorry for the AI, no one appears to have made an overland X1/9 yet...).
  36. It’s a rabbit hole. i found that once you’ve read about one thing, something else will contradict that with something else. 6 weeks later and it’s still confusing. We have a great laser cutter near home , if I drop him some chicken scratch drawings showing measurements, he will pop out some legit pro spec parts. At a fraction of the price of catalogue stuff that often doesn’t fit anyway. im just street use, so I just set my bars up to have the IC around the bumper and pinion angle perfect. lower link bar will be dead level once it’s dropped another 20mm in the rear (soon to be done). cut some concepts out of cardboard and do some chalk art showing range of movement etc. it’ll show what your pinion angle will do at different bar lengths, angles and spread. but don’t take this advice, I’m not trained or skilled in it
  37. I couldn't find the 4 link design thread, so I'll post up here instead. Thinking about the back end of one of the cars I own. The guy who started building it four linked the rear. But when he sold it to the guy I got it off, he kept the 9" link bars, and coil overs . Since whichever axle I use will need to be extensively narrowed, I might as well run the mount plates which completely encircle the axle tube. I was thinking it's no biggie to have something laser cut, or plasma cut them myself. I'm literally the worst drawer who ever lived. But imagine this is a plate with an axle tube hole in the centre, and a pivot bolt top and bottom for the links. seeing what already exists in the market, I found these for sale for way too much money. You can see that this one has the pivot point where the arms attach forward of the axle centreline. Is this done to reduce the instance the arms/rod ends contacting the axle tube at the extremities of travel? Or some other rationale? (Better transmission of forward motion to the chassis, or superior ability to resist the rotational forces of the differential? You tell me????) So back to my truely incredible technical drawings, I could do a plate like this, (Yes, making one with a row of holes top and bottom would be a lot smarter. The hole options in the mounting plates on the chassis have already been drilled Assuming they're at uniform centres, the centre to centre measurements of the arm mounting holes would need to mirror this pre-ordained distance to maintain the top and bottom remaining parallel through range of motion. (But this drawing is just for the sake of trying to convey the guts of my query) So far, it's all semi straightforward. But as for the coilover mounts on the diff, (there were coil overs on the diff the builder had in there) it seems to me like these could similarly be integrated into the same bracket too. (Mounted to the rear of the axle tube) More CAD quality draughtsmanship from me, Now as this is one piece, the shock mounting ear could be sited pretty much anywhere through the 180-ish degrees on the rear side of the axle tube. Depending on the size of the bottom eye of whatever coilover was used, there could easily be a spacer (if it here narrower than the width of the ends of the link bars) or a crush tube could be employed to improve the strength. (Additionally a Brace could welded across the two plates along the bottom side to aid rigidity too. If you're still following, my two questions are, Is there an ideal offset from the axle centreline to the centreline of the link bar mounting points? (Or does this matter?) And, is there a preferred offset from the axle centreline back to the centre of the coilover mounting point? My time fucking about with cars has taught me that such things are never left to change by the OEM. And the blokes who design this shit are a fuckton clever-er than me. Ta.
  38. As mentioned in June spam our youngest and one of his mates have been playing with scrap metal and hot melty things. Pulse jet prototype number one sort of works.
  39. Rear brakes all reco'ed. Honestly didn't need much, AGAIN everything looks like it's near new. The pipes came out without drama, the shoes look great, the drums are perfect. All the wheel cylinders needed was a clean, a quick hone and put back together. The seals looked new. Only thing is the auto adjuster cable on the drivers side was missing and i can't find a spare. I probably do have a spare one i just can't find it right now.....
  40. so the last few days went like this In that order. I found some pictures of that port and that hole wasn't there when i put the head on. so was thin enough, that in the 20 sec the engine ran, vac pulled what little material there was there out. managed to slide hammer the insert out, so could get tig down there to weld the hole. hole was in head not insert. Seemed to have a bit of material around the hole. so just a thin spot in the casting. fun times. but that's why this head is a test run
  41. Fun afternoon in the shed sorting out the Homer Simpson spice rack spec battery tray, was a last minute abortion addition back when the twincam went in that I didn't really want returning and new technology makes it much easier to sort. 3d scanned the left side of the engine bay, engine and carbs on top, firewall to the right, inner guard bottom with the front diff and engine mount on the left. Mounting points to pick up are the two studs in the firewall and one bolt hole on the engine mount which is not at all square to anything. Not to mention its bit of a tight fit in there between the engine mount, intake manifold and top wishbone mount. Throw the mesh into CAD and draw up something that misses all the important stuff. Send the pattern over to the CNC router and let a 2mm end mill chomp out a shape. Quick diversion to the bead roller on the way over to the folder, a quick weld on the MIG, fire on some rattle can and there we go Picked up the battery and a selection of oils this afternoon, can't be far off starting up eh?
  42. Yes - stop wasting Clint's time and just buy one.
  43. So I haven't posted in a while but a lot of work has been done in the meantime, I learned that a lot of the RB stuff that the previous owner had done, not only will it not work with this car but on top of that a lot of damage had been done to the underside in the engine bay to fit that R33 subframe in that is taking me a while to fix. The thing is I don't fully understand why as I've done research and to get an RB onto the original L series subframe that I'm putting back in I just need custom engine mounts and sump, so the damage seems completely unnecessary but is what it is, just have to get it sorted now. As for work completed so far since I posted last: The rest of the rust holes have all been cut and welded I properly inspected the RB and it needs a rebuild, however this works for me as I'm doing a resto so am happy to be putting a rebuilt engine in I stripped everything from the underside, have replaced all the old rubber cracked bushes with Nolathane ones and put the underside on. However after doing some research I am somewhat regretting going Nolathane as I've seen talk online about Nolathane bushes disintegrating in classic cars from lack of use. Oh well i'm too deep now, spent the money and installed them, so here's hoping that won't happen to me and if it does I'll just have to cross that road when I get to it The interior cabin and boot rust has been dealt with and top coated with Por-15 Next Steps: Get the front windscreen removed so I can deal with any rust that may be hiding under the Window sealant and prep that area for paint as well Paint the engine bay Start putting things back into the interior and engine bay Really excited to finally be getting into these next steps, as up until now, it's been just pulling the car apart, fixing rust etc. Whereas it finally feels like I'm making real progress on this car with starting to actually put stuff back in and put it back together. Hoping to have the car finished before November of this year
