Showing content with the highest reputation on 02/07/26 in all areas
  1. I has been a few years since I had anything classic, since the departure of my XJ40 (which unfortunately became too much of a hassle for me and didn't realistically have the space to work on it properly - I had ended up losing that lovin' feeling). 5 years ago when i got a 1990s Royal Enfield Bullet for shits and giggles, this got me back into bikes, which is where my original passion for vehicles began (I sold my last bike when we left Auckland in 2013, which also helped with the house deposit - how times have changed). As much as fun as it was, I decided that I liked riding into work (rather than the loser cruiser), so decided that I need a modern bike for that purpose (you know, actually starting when you need it to etc). So off went the Royal Enfield and then I got a BMW G310GS, to ease back into the game as it were. That scratched an itch for a while, but around 2 years after that, I wanted to get back on a Triumph (last bike in Auckland was a Bonneville). So off went the BMW and in came my current daily, a 2008 Bonneville. But still, 2 years later, I had the itch for something to spanner on (wife could see this too). So I decided that I needed a classic bike and a daily bike. I had been pining for a Meriden Triumph, BSA etc, but then came across a 1987 GPZ900R. Now being a child of 1986 and a fan of Top Gun......well.....I just kinda had to go for it. So anyways, this has landed at my place: The current plan is to get her back onto the road (rego is on hold) and give her a Top Gun style. Also came with essentially a second bike, minus the engine and fuel tank. No doubt in the coming weeks, I'll realise the suffering I have brought upon myself, but fuck it, we'll have some fun......
    9 points
  2. Yay. Got that done. So that’s the ‘frame’ I guess you’d call it, done on this side.
    8 points
  3. So I found a fairly serious corrosion pit in that bore, enough to make me think it would need proper work to be good again. Hence I furthered the search for a Suzuki M16a and manual out of a Swift Sport. Tonight then; Naturally I scanned that bitch right away and put it into my engine bay scan; I can probably make that work.... There are a couple of issues, the axles are not particularly well lined up with the hubs, but CV's so whatevs. They would end up a bit shorter than the standard suzy ones so I would have to make sure the CV's could cope with the travel required. That axle alignment is not helped by the exhaust, which would probably need to be redone a bit tighter to the block so the engine can move forwards a bit. There is also some weird big disc/diaphragm thing as part of the oil filter housing that kindof gets in the way; Fuck knows what it does but its in the way. Also the gearshift tower looks pretty easy to mod to point towards the front of the engine, and if the lever actuation direction can be swapped at the same time then I can use the gearstick/shifter unmodified. Nice. The intake wouldn't fit either so I guess that means ITB's, oh no what a drag
    6 points
  4. Last post November 2024!! Since then well, its been for lack of a better word - expensive 🤣 Car was tuned, and made its debut at the Mad Mike summer bash, car went ok but a few issues surfaced as expected. Notably the 4 litre water meth tank emptied in 3 laps of Hampton international circuit. I have fitted a 20 litre tank in the boot, but for those who know Auckland, will only last a casual drive from Kumeu to Ellerslie and back without much fanging. Not exactly street car friendly. Somewhere along the way I hurt the motor too, and after a strip down found all the corner seals broken, and a dent in one of the rotors - detonation...... The old Microtech was very basic, it didn't even have a wideband, so it all went in the bin and I now have a Haltech Nexus R3, IC7 dash, Knock sensors, EGTs, and Dual WIdebands to monitor everything. Went the the Dyno and found the exhaust just doesn't flow well enough, the power flat lines at 6500rpm, which for a rotary is pathetic, A pressure sensor fitted to the exhaust saw a 12psi backlog and climbing, so for now we have rev limiter set low until a big single 3.5 al the way through is fitted - more $ 🙄. The car is all certed and road legal now though, but before I could do that I had to replace a front chassis rail which was bent, if you read back to my previous posts about the f*ck knuckle who sold me the car, I even questioned him before I handed over the cash about the chassis, he straight lied to me and avoided taking pics of that area instead showing me all the good bits (i only saw the car for 25,mins initially, easily missed, but in many conversations afterwards he had every chance to be straight with me when directly asked about it). Anyway Choppers Autobody handmade a new one and its perfect! onwards and upwards. With a blower you have boost at idle so the brake booster has no vacuum to operate brakes, even though they are pretty big, they were shit, so I fitted an electronic vacuum pump and tank and now she pulls up hard, She goes really well even with the rev cut, drives beautifully, took it to the Rotary REunion earlier the year and took best RX4 trophy which was nice and its in the current issue of NZ Performance car magazine which these pics are from. I need to sort the exhaust/tune but already have my eye on another car to build so who knows if ill keep it......
    5 points
  5. 80s synth and electric drum beat intensifies
  6. We've been rego & wof'd for a few months now, and still really chipping away at working through a few little issues. I haven't ventured far from home yet, but was finding that when I got out into about 80km/h it would start running like an absolute bag of dicks. Popping and backfiring and running terribly. I cleaned up the points, checked some voltages and found that the coil was not compatible with the balast resistor, so bypassed that. Still a bag of dicks. Went to double check the timing, and when I clamped the vacuum line to disable the advance I discovered that a hissing noise I hadn't noticed, stopped. The diaphragm on the advance unit was stuffed. So I've put a new one of those in, and am yet to venture back onto the open road, but have my fingers crossed. I also need to do some carb tuning, I think it is super lean just off idle, or the accelerator pump isn't working properly. It is sooooo flat pulling away from intersections, but comes to life if I feed it the beans. Aside from that its just been typical wagon stuff. So much to do and so little time.
  7. Wooho have working indercators. Hoping I get lights working next Gota do some rust in the lower sils also I need to stop buying random stuff and save for some new tyers as these are very old and cracked and poor tread as well thinking white walls
  8. It’s a rabbit hole. i found that once you’ve read about one thing, something else will contradict that with something else. 6 weeks later and it’s still confusing. We have a great laser cutter near home , if I drop him some chicken scratch drawings showing measurements, he will pop out some legit pro spec parts. At a fraction of the price of catalogue stuff that often doesn’t fit anyway. im just street use, so I just set my bars up to have the IC around the bumper and pinion angle perfect. lower link bar will be dead level once it’s dropped another 20mm in the rear (soon to be done). cut some concepts out of cardboard and do some chalk art showing range of movement etc. it’ll show what your pinion angle will do at different bar lengths, angles and spread. but don’t take this advice, I’m not trained or skilled in it
  9. Well I have been riding her daily to work and shops and stuff and she is going great guns Lights still work, as does the horn and indicators, however the wee wire bit that clips into the brake light switch has broken so I need to source one of those ASAP I got a rack of @Hunterkiwi01 (on loan) and mounted a crate which really helps with shopping duties It has had an oil change and is about 300km into that. I will do another in 200km or so just to flush it. (it gets up to 63km/h or so on a good day which is good) The more I ride it, the better it goes, however it does have a wee stumble at low revs (Taking off at lights) so I guess its time to pull the jets and give em a clean. It has stopped stalling at the lights though (even on these cold mornings). It does appear to have a bit of a 'shimmy' or 'wobble' at 20km/h so I will investigate this further. Overall stock cub life, although slow is very chill.
  10. And wholly shit it fits Quite fkn pleased with myself. Probably the trickiest panel I’ve made so far. There’s some brackets and bolts to weld on for the guard then hopefully I can get it in epoxy today.
  11. So, after getting rather waylaid with other projects/life etc we do have some progress here.... got it running as good as its going to be... sorted out a bunch of minor stuff (wipers, lighting etc). Then gave it a much needed clean... Very soon, the long awaited 'WOF-day' was upon us, and despite the looks of the list it came off pretty good... a set of minor stuff to tick off, do some tidy of the seatbelts and one of the rear brake cylinders looks to be leaking. Biggest drama of the whole lot is to 'return to original'/ignore declaration papers I need to pull off the Series3 brake assembly and return to non- boosted brakes. Most of the way through the list, ideally I get back to a re-check soon.
  12. I think I've said multiple times that this is rust free now, but there keeps being more pop up! After blasting showed up these holes in the lower a-pillar/cowl area. Was a bit worse than expected once I cut the outer off. That's the backside of the lower hinge mount, so had to be fixed to a decent standard. 3d scanned, cad'd and 3d printed a press die to punch out a new panel to repair the hinge pocket backer. A bit of prestretching and shrinking and it worked really well. All repaired and painted in KBS. Outer repaired and welded back in. Otherside was a touch worse on the inside compared to the outside. The heater core needed repairing and would of set me back at least a few hundred dollars, so went though Rockauto and found a Toyota Camry heater core for sub $100 that would work with some slight modes. Had to lengthen the core housing for it to fit and then drew up a new front mesh to suit. New heater mounts welded in and a 3d printed outlet or some adjustability on the vent. Over Easter I got the front panels blasted and all in epoxy primer. On to getting the panels all aligned best I can and gapping it right. Made up a battery mount for in the boot behind the r/h rear wheel tub. See you in another year for an update haha
  13. Introducing my 1980 KP60 Toyota Starlet. Got this off a friend, swapped 2 paint jobs for it, chur. Been off the road since 2006. dereg unfortunately. overall a very tidy car. very honest car, was briefly in the works for a fully worked 2zzge, dry sump. which is now removed and in possession of previously mentioned friend. I absolutely love these bugeye starlets. always wanted one since i first saw one, so wanting to keep this one forever. The plan is to just do a simple lumpy cam 4k with gillies, low and nice wheels. but i do have a fwd 4age sitting in the back of the shed, and naturally i recently bought some 4age to KP engine mounts to tempt myself towards that. ill see how it goes..
  14. Well well well, the title should hopefully explain this well... This is my baby, the car that holds far too many memories, the car I could never part with, yet it's the car I neglect and leave sitting in the corner of my shed and never work on.... This journey started around 8 years ago when I had a 12a Bridgeport motor and box in my shed and I was on the hunt for a rolling body to drop it in. I was fixed on a s1 rx7 body I found until a mate sent me a trademe link to a near immaculate, completely factory green gsl ex lancer, him doing this knowing I had always wanted an ex lancer. And so it begun The 12a never ended up in it, it started as a 1600, then had a 4g63 sohc, then probably a few more until I dropped a 4g63t dohc turbo vr4 block in it. Unfortunately money got tight and I sold the motor to keep the mortgage and mrs at the time happy, so it went back to a 4g63 sohc carby. This did have a thread from the early days but its goneburgers now so we will play 8 years of catchup
  15. Hey Chch crew, looks like I'm moving up! I have a new job starting in just over a month's time at Kelford Cams and will be moving my whole life up there. That means I need somewhere to keep the racecar, a couple of motorbikes and a small collection of garage bullshit... And also somewhere to live (I guess). Do any of you have hookups for storage/workshops, know of decent houses available to rent, or have a room available that I could slot into in July? Leave a comment here or flick me a PM if you have any ideas. Churr! Markku
  16. Just placing this here for future reference: Have done a quick assessment of what I have on my hands: One bike that's pretty much together A bunch of spares slapped together into the shape of a motorcycle (akin to the Titan submersible) A box full of bits from the main bike and the spares bike (at face value, I have two of everything, save the engine and fuel tank). I knew the carbs were off the motorcycle, but was surprised to find that the wiring loom was not installed - Don't worry, as mentioned above, it's there, it just needs to be installed.......this should prove interesting. Some 'perks/bonus/glitter in the turd': Haynes book of lies: Complete with Barry spec mag articles: What appears to be a brand new screen: Rebuild kits for brake and clutch M/Cs as well as calipers: No doubt further investigations will happen over the coming weekend, but the general plan of attack / first things I need to do are: Install wiring loom Connect battery to test said wiring loom rebuild carbs (after ordering rebuild kits) Inspect and connect up cooling system Replace spark plugs Replace engine oil and filter That should hopefully get me in a position to see if I can get her fired up. ........so check back in around 9 months.......
  17. Ha! Loving the scope creep going on here.
  18. Had to search to find this thread. (The cool kids have a link in the first post of their build thread) Just wanted to say, Please post lots of pics of the frame etc for.you flip front.
  19. Okay a quick Google, (I don't want to learn, just give me the answers) reveals a whole heap of reading which I'll have to struggle through when it's not an hour past my bedtime.
  20. Lifter tick, i speak fluent car seller, probably 2km away from a rod out the side
  21. Eh. Someone should see if there's new owners at the camp yet
  22. Found a way of shutting it up NA when im tinkering on driveway old supertrapp off the V-twin moped jammed up the 89mm exhaust.
  23. Keep an eye on this area and we'll post something up in the coming months
  24. The outer panel, well…. So after some umming and ahhing I came to the obvious conclusion that I knew from the beginning. Gotta make a new one.
  25. So I’ve already done this area on the other side so I kinda knew what was coming. The inner panel is in pretty good shape. Or was until I tried to get the weird little bracket thingie out Oops It’s was rooted anyway. So I made another new one.
  26. With a bit more tidying up of the wiring, I mounted up the modern motorcycle company headlight and Speedo that came with the bike. I found an old motorcycle guard I had laying around and trimmed that down, drilled and tapped the fork brace for Acouple of mounting hole bought a polished aluminium guard off aliexpress for the rear which was actually good quality, welded acouple of tabs on and mounted that up. went and took acouple of beauty shots of it.
  27. So next up was to get rid of the horrible seat. I would generally make a new subframe and fibreglass seat base and get the seat trimmed. I wanted to get this bike done quick and found out some people use a sr400 nitroheads sest that fits on the stock subframe and luckily some en in Nz had one they never used on a project. I shaved all unused brackets off the bike, made a new number plate mount, mounted a nice billet tail light I had laying around and also some aliexpress led indicators for $15 they are billet and quite small/bright and mounted them up under the subframe. Slapped a coat of flat black on and mounted it up ended up getting a set of mid rise renthal tracker bars, whipped the fork legs off and chucked new seals in them as they were leaking. I also wanted to mount the battery somewhere different, on my last bike I mounted it under the bike behind the sump, it looked clean but my exhaust plans for this bike didn't allow that location I went with a power road lifep04 and made up a quick bracket just under the seat. im terrible at taking progress photos but in the last photo you can see on the right I also have an ignition tucked up under the fuel tank pit of sight
  28. So, to get up to speed on this rig, it was bought to be a quick flip but now I'm attached soooo I'll keep it. my main goal was to get in a month or so of riding in in summer... that didn't happen. slapped some more bog on the tank and gave it a prime and painted the underside black. Then had to decide on a colour, I ended up going with Toyota 033 which is a nice off white/eggshell colour, got it mixed up in a proper 2k aerosol can from RJP here in Christchurch, quite cool has a little button on the bottom to activate the hardner and only around $40 a big can. paint ended up laying down half decent it just needs a bit of a wet sand but looks good enough for me. also managed to track down an air box cover from a guy in Wellington who use to cast them out of aluminim, luckily i got the last one as he is no longer producing them. before after it tidys the motor up a bunch, also slapped a quick coat of paint on the rocker covers while I was there.
  29. Hi mate yep you are correct ! SA import. Based on what I saw with this car South Africans should keep their hands off early Mazdas and spray guns! Keep at it mate - I’m glad you have held on to your 1300. They are special little cars. Where it all began for my love of 1300s!
  30. Over a year ago I stripped the bumpers, repaired the dents, filed and sanded the bumpers to get rechromed. The repro grill guards were pretty average pressings, so made them fit the bumpers better, and smoothed all the harsh grinding marks out too. Have so far sent every fastener, clip and component that'll be going back on the car and not replaced with new or be painted. Made up some radiator panel covers on the pullmax. Also cad'd up a coil/rocker cover and 3d printed. Will get some cast at a later date. Rounded off the top corners of the radiator as they just didn't look right. Made a powersteering reservoir and coolant overflow each side of the radiator also. Radiator shroud done with some rubber flaps. Decided I didn't like how the firewall looked, the heater motor sticking through, wiper motor visible and the seam through it. So made up some wooden bucks and swaged one out on the pullmax. Old firewall cutout. Recessed the cowl drain flange to suit the new swages. Fitted new wiper motor (old Toyota Celsior one) so it would sit in a similar spot to factory but behind the firewall. Screwed it all in place with panelbond between the new panel and the flanges, to seal it all up. Went through and plugged welded up all the screw holes and welded up the outside edge. New wiper motor mount. Backside. The panelbond worked well to seal it up.
  31. When we had the Fabia RS during the period it was still going back to the dealership for servicing, I'd often see the younger techs getting all excited when it was up on the hoist and invariably someone would have given a front wheel a spin... One of the senior staff members would come out and explain that "No, that diff's as open as your mum". That car in particular had a very high breakout force though.
  32. Ok. I can pull off a flange and get the borescope in there, that should tell me. Its just the fucker wouldnt give me any actual information why it would behave like it does. I just went down and checked, its not welded, but acts 100% like an lsd.
  33. More progress. Gotta say having a deadline does a hell of a lot for motivation 😅 because I want to get the car as straight as possible (and am only allowed the booth for a single Saturday) the plan is to do a closed door respray, so getting all non-closed door parts out of the way, ergo door jams are now done 🥳 next up, the insides of the doors so they can be bolted back on
  34. Sooooo the whole no cert thing bugged me. I want it to be wof n reg so the dohc came out (I have other plans for it) The sohc 4g63 from my yellow ute went in. Also swapped in some ae86 springs to try out. Not sure if they'll stay And finally got around to polishing my 13x7 hotwires with some nankang 215/50s , pretty stoked on the look, front might be a little high though Anyway I finally got to drive it for the first time in a while, feels good to drive a car to break the project blues
  35. The car is like 98% complete. off the top of my head only missing carpets and whatever crap that bolts onto the engine bay. warms my bones having lots of little things like the rubber around the jack. the side trims and all the clips for it too. parcel tray and all the wheel well trims. Makes the build so much easier
  36. Pro tip: If you happen to have a hot air re-work station at your elbow, it's perfect for re-doing the hot-melt glue holding that scrap of PCB with the fix-up resistors on that totally proefssionel data collection thingy you're working on ...
  37. No doubt you've seen this. Hopefully some inspiration/motivation - shit it sounds fantastic.
  38. Clean it up, use a neutral shoe cream (natural/clear tarrago is fine, bonus being you can use it on real leather stuff too) I have done some old old fake leather with it recently
  39. So the sump was looking like this So I took a rwd sigma sump and modified it to give clearance over vr4 crank cradle There's plenty of ways to skin cats, not that I've skinned one..... Yet..... But this is how I tackled this task. Had to secure motor to body while I dropped crossmember down to access sump, Exhibit A And unbolt engine mounts and crossmember to body bolts, unbolt and remove sump Exhibit B Made new sump gasket , installed, fresh liquid, started while on hoist to check for leaks Then got the money shots Behold, the latest twin headlight in the fleet Keep it in ya pants
  40. Took this heap along to mitsi owners day 2025, didn't win anything for ruffest car there but had a good day Left dubcity early early as for the trip, meeting the kaitaia boys and convoys our way down to Hamptons Then we met Damien at Bombay and onwards to the track The day went well, I welded the diff for the wet skid pan and bugger me that pad is bad for sledging, was hard with a handbrake that left the chat. Few hairy moments Even drove it off the trailer again. Unreal
  41. So this was the big deadline to try meet, and so that we did. An epic event and good times cruising the back roads with the boys to get there Still a lot of work to do like interior, more low, swap to 14s as I'm not liking the 15s, change muffler the list goes on but I get to enjoy driving it now
  42. Put a new decal on the passenger door And gave it a real quick Wizz over with a buff . while driving it to work the left rear caliper stuck on so had to strip that down and clean it up . Came right with a clean up and some rubber grease on the sliding parts
  43. Shizer it's been a while and cringe at my old posts. Anyways, I chucked a blanket over this and shut the garage while I did other things for a couple of years. Lockdowns meant pulling the blankets off, I got it running on the factory intake so was motivated again. Rear screen rubber in, stainless trims fresh and polished, random clips from russia and its now airbagged using accuair control with airlift struts. It drives well around the hood and I'm slowly getting more confident on going further. I never drove this car so was a big moment. Next on the list is sorting my rear wheels as they are a bit wide for frame laying and then a bespoke itb manifold from Mr Whitley tune. Pic courtesy of Simon when it was picked up a few weeks ago. Il take some when I get the trims back on.
  44. Gave the gearbox a lil clean and made a new gasket for the top cover (it never had one). The selector mech is still a bit sloppier than I'd like it but tough to make it much better with the current set up. Got alot of the sills/box bolted in. These dog legs are notorious for rotting out at the bottom (exposed to mud from the rear wheel). Got most of a repair done and checked the fitment. The b-pillars arent quite where they need to be so may need to be cut/re-welded. I'd love to replace the whole sill/b-pillar but at 3K plus shipping a side that isnt going to fly....
