Showing content with the highest reputation on 30/06/26 in all areas
We've been rego & wof'd for a few months now, and still really chipping away at working through a few little issues. I haven't ventured far from home yet, but was finding that when I got out into about 80km/h it would start running like an absolute bag of dicks. Popping and backfiring and running terribly. I cleaned up the points, checked some voltages and found that the coil was not compatible with the balast resistor, so bypassed that. Still a bag of dicks. Went to double check the timing, and when I clamped the vacuum line to disable the advance I discovered that a hissing noise I hadn't noticed, stopped. The diaphragm on the advance unit was stuffed. So I've put a new one of those in, and am yet to venture back onto the open road, but have my fingers crossed. I also need to do some carb tuning, I think it is super lean just off idle, or the accelerator pump isn't working properly. It is sooooo flat pulling away from intersections, but comes to life if I feed it the beans. Aside from that its just been typical wagon stuff. So much to do and so little time.12 points
Then we have similar tuning challenges with the head sails. Listening to a smart mans podcast, he said a common mistake is to have everything pinging tight to get the best airflow heading into the wind... But you just end up with flat sails and no power. Need that sweet curve to generate some aerodynamic lift. So now we have started leaving things a bit looser and only flattening the sails to reduce power when there's too much wind. Also FINALLY getting sick of using the gennaker because it's safe and easy. It sucks except in a very narrow wind angle. My goal for the rest of the winter is to grow some balls and get the symmetric spinnakers out more often.10 points
Rear brakes all reco'ed. Honestly didn't need much, AGAIN everything looks like it's near new. The pipes came out without drama, the shoes look great, the drums are perfect. All the wheel cylinders needed was a clean, a quick hone and put back together. The seals looked new. Only thing is the auto adjuster cable on the drivers side was missing and i can't find a spare. I probably do have a spare one i just can't find it right now.....9 points
I think I've said multiple times that this is rust free now, but there keeps being more pop up! After blasting showed up these holes in the lower a-pillar/cowl area. Was a bit worse than expected once I cut the outer off. That's the backside of the lower hinge mount, so had to be fixed to a decent standard. 3d scanned, cad'd and 3d printed a press die to punch out a new panel to repair the hinge pocket backer. A bit of prestretching and shrinking and it worked really well. All repaired and painted in KBS. Outer repaired and welded back in. Otherside was a touch worse on the inside compared to the outside. The heater core needed repairing and would of set me back at least a few hundred dollars, so went though Rockauto and found a Toyota Camry heater core for sub $100 that would work with some slight modes. Had to lengthen the core housing for it to fit and then drew up a new front mesh to suit. New heater mounts welded in and a 3d printed outlet or some adjustability on the vent. Over Easter I got the front panels blasted and all in epoxy primer. On to getting the panels all aligned best I can and gapping it right. Made up a battery mount for in the boot behind the r/h rear wheel tub. See you in another year for an update haha7 points
So, after getting rather waylaid with other projects/life etc we do have some progress here.... got it running as good as its going to be... sorted out a bunch of minor stuff (wipers, lighting etc). Then gave it a much needed clean... Very soon, the long awaited 'WOF-day' was upon us, and despite the looks of the list it came off pretty good... a set of minor stuff to tick off, do some tidy of the seatbelts and one of the rear brake cylinders looks to be leaking. Biggest drama of the whole lot is to 'return to original'/ignore declaration papers I need to pull off the Series3 brake assembly and return to non- boosted brakes. Most of the way through the list, ideally I get back to a re-check soon.5 points
I had to get the E36 valued for insurance purposes. The valuer asked me to list out what I’d spent. Just big ticket items got to 85k, and that’s not including the first LS that died on the dyno, or any small things (oils, heat shielding, lots of other shit) So I’ve spent over $100k on a $2k poo spec auto e36, and now it’s insured for 40. E30 probably owes me $30+ at this point, but I won’t add up until someone makes me. Cars are a great investment.5 points
5 points
With a bit more tidying up of the wiring, I mounted up the modern motorcycle company headlight and Speedo that came with the bike. I found an old motorcycle guard I had laying around and trimmed that down, drilled and tapped the fork brace for Acouple of mounting hole bought a polished aluminium guard off aliexpress for the rear which was actually good quality, welded acouple of tabs on and mounted that up. went and took acouple of beauty shots of it.4 points
On the subject of learning, I think it's paying off. The last few months have really been all about learning to keep the boat sailing "in the groove". Part of that is steering the right way to keep all of the sails in their performance window. Part of it is learning how to trim those sails to get the performance window wider or at least where you need it to be. The groove feels like being in the right gear. It's a delicious brain challenge trying to understand whats going wrong and which rope is going to fix it. We're not playing with bags to catch wind here, these are finely tuned airfoils which need the right angle of attack and camber for the right wind speed. This new learning has been made possible by a great crew turnout this winter. For example, I've been able to have someone dedicated to trimming the backstays - helping flatten the shape of the mainsail as gusts come through. Another person changes the angle of attack using the traveler and then there's twist adjusted with the sheet, the cunningham, halyard tension... There's a lot going on. Get it right and you get to go fast.4 points
I guess all my old holden shenanigans were in the west island so the 3.2 days of winter a year werent really an issue. I'll get the thing running first and if it becomes a drama later. Land Rover heaters and I havent had the best relationship plus I dont have a roof yet so that can go on the back burner.3 points
My strategy is Grow weed Sell weed for $ Spend $ on cars. No records kept cos that would incriminate3 points
The rotary conversion. I had owned the car now from 2021 and had got plenty of enjoyment driving the standard motor around Canterbury with my young son. It was around 2024 I got the rotary itch so started to make a plan. Tim Wood put me onto a motor that was destined for his blue coupe - it was a 10a rebuilt to factory specs by Grant Munro so I knew it would be well built. With everyone going for triple and quad rotors I thought I would go the other way like the flat head guys of the past who at one time were pretty unfashionable. It also meant with an r100 crossmember which is a straight bolt in to this chassis meant I could get the 10a to fit pretty easily ( more on that later). The first stage of the rotary conversion was to sort the suspension. Xd falcon shocks bolt straight into these in the rear so I ordered a set of koni adjustables for the rear and put new springs and inserts in the front and ordered a kmac camber kit, along with a mini me willwood front brake kit from pac performance that is designed to fit inside factory 13” steel wheels. I also sourced a pwr r100 radiator and oil cooler and spal fan. The other main thing I got at this time was a new brake master. The owner of the mayhem 1200 gave me some great advice here and I went with the jb1133 its a duel circuit option but has the benefit of looking a bit nicer than the 1” duel people favour and gives you a nicer pedal feel.3 points
Over a year ago I stripped the bumpers, repaired the dents, filed and sanded the bumpers to get rechromed. The repro grill guards were pretty average pressings, so made them fit the bumpers better, and smoothed all the harsh grinding marks out too. Have so far sent every fastener, clip and component that'll be going back on the car and not replaced with new or be painted. Made up some radiator panel covers on the pullmax. Also cad'd up a coil/rocker cover and 3d printed. Will get some cast at a later date. Rounded off the top corners of the radiator as they just didn't look right. Made a powersteering reservoir and coolant overflow each side of the radiator also. Radiator shroud done with some rubber flaps. Decided I didn't like how the firewall looked, the heater motor sticking through, wiper motor visible and the seam through it. So made up some wooden bucks and swaged one out on the pullmax. Old firewall cutout. Recessed the cowl drain flange to suit the new swages. Fitted new wiper motor (old Toyota Celsior one) so it would sit in a similar spot to factory but behind the firewall. Screwed it all in place with panelbond between the new panel and the flanges, to seal it all up. Went through and plugged welded up all the screw holes and welded up the outside edge. New wiper motor mount. Backside. The panelbond worked well to seal it up.3 points
It must have been the years of parking outdoors which did that to them, not me playing them too loud. I figured it must have been you who originally installed the stuffed speakers, because they were Mitsubishi branded but they clearly didn't fit the mounting points. I also had to employ dodgy means to hold the new speakers in place (fit for the random rough-as-guts bodges thread?) because the mounting points are too far apart. I checked the wagon's rear speakers but their cones are still intact. It's weird that they're mounted in the roof. You could hear the control board start chattering each time I folded the mirror back out, so I was able to locate it by ear! I wouldn't guarantee that replacing the control board would necessarily get both mirrors to fold in and out again, but I also don't think the mirrors are top priority any more. Have you got any other left front struts? Is the car still using the same model struts it came out with?2 points
Trailer has been welded up, just been put to the side for now waiting a tidy up and paint, Started the 4 door now, gotta make that mint, most the small spots of rust are sorted, gathering the energy to panelbeat and paint but going away for awhile for work, will be back on it when I get back for sure2 points
I did end up finding the 808 steering wheel but sold it when I found a more period correct wheel out of a Japanese Luce. In terms of the retrim I asked the trim shop to match it to an L10b cosmo. The finished results were awesome. Around this time I sourced a coupe speedo and had this rebuilt at parrot instruments who did an amazing job. The tacho needed a new drive unit. When you turn the car on now it does a cool sweep.2 points
Another job to tick off the list was to replace the new front brake pads with some Winmax. I had purchased some pads from BNT and really didn't take much notice of them until it was to late to return them. They were a softer compound which I thought would help with less pressure needed to make them work. But when I finally opened the box I discovered they had a bevel on them that reduced the contact area but will increase with wear over time. Go figure because it doesn't make sense to me. With the Winmax you can get different types of compound depending on their use. These are for performance street-track day pads. so out with the new and in with the newer.2 points
LSD showed up. Tore it down as you should. Lucky too cos more than half of the LSD cap bolts were loose. I was confused about missing preload springs (in the form of belville washers) but googled the shit out of it and turns out that some of the diffs don’t have springs. The diff has 4 clutches (some only have 2) but I won’t know how well it locks up until I try for a donut. Will install over the weekend but I don’t have oil for it, so waiting on my Redline 70W-140 GL5 to show up. Supposedly BMWs recommended fluid for LSDs. The E30 small case diffs are notoriously weak, specifically the LSD cap, but this is actually a Z3 (still small case) diff which has a much stouter cap design. Still a weak point but less weak! You can buy billet caps, about $250, but it means rechecking lash and shims and contact patch on gears and that sounds like more work than not doing it. Might do later, will see if it needs a clutch replacement first. fuck it’s cold down here at the moment. Harder to find motivation to get out to the garage. This is just up from my house: I pushed the car outside to work on the diff on garage floor, and by the time I pushed back inside bonnet was covered in ice. Moist2 points
you can use negative hydrostatic pressure to push oil into the pump. just fill the sump over full then lower the engine into the sea at your local marina. then walk away.2 points
Bro I have read this entire thread, only because I did not know what a Ross35 is I have years of Coastguard Volunteering, was a commercial fisherman, even driven a paddle boat, recreational fishing and boating but have never been on a sailing boat. I have learnt lots, Thank you2 points
the original front struts are long gone and they were toast - the struts in there now were given to me a couple years ago (earlier in this thread) and were supposedly near new KYB's meant for the V3000 (though I checked part number and it seems the same strut is used for both 4cyl Magna and V6 V3000, at least as far a KYB's parts catalogue goes). I eventually want to convert to air suspension using struts from a parts V3000 SEi I have access to, though am hoping they still work haha. They were replaced brand new about 15 years ago but the parts car was then involved in an accident shortly after and it's been sitting ever since.1 point
Thanks oldrx7 you have a good memory there are a few cars I definitely regret selling and I never predicted prices were going to get as mental as they did. The white familia was sold to a guy in Dunedin and is still down there as far as I know. I sold it to build a 20b jc cosmo. I regret selling that car as it still had delivery plastics on its seats and door trims and is virtually impossible to find - the green rx4 is also another one I really regret selling. I sold it to a guy who didn’t respect the car or the care Ben the 2nd owner showed it when it was 2tempu. Both the green rx4 and familia wagon were sold to settle relationships - my taste in Mazdas is better than woman!1 point
Only the eagle eyed among us can tell which of the upper and lower housings is the new one. Had a look in the old water pump and tbf it could have been used. I just figure why bother when they are so cheap. Now to figure out where all the small lines go because I doubt Ill use the heater but it might actually be easier than looping. No idea what this casting woke nonsense is down here.1 point
oh amazing thanks for that! happy to reimburse for the speakers - I knew they were going bad but didn't think they were that bad haha. I think they are the original speakers from my Diamante sedan as I ended up putting some 6.5" low profile speakers into that as the original speakers of the sedan (at the time) were fine, while the original speakers of the wagon were kaput. I replaced the rear speakers too but you're limited with just 5.25" ones there. and that's some good investigating with the door mirror control board, never would have thought to look there! incidentally you can still buy that unit brand new, at some $300 though haha. Same unit in early 90's Delica, E1xA/E3xA Galant but I guess even finding one at pick a part etc would be hard these days.1 point
Yeap have ditched the canbus, was eaiser than trying to keep it happy with abs and power steering etc and piggy back stuff I have learnt I can setup the power steering to work in "limp mode" which is what everyone seems to do and have good success with it abs has just gone in the bin too1 point
Dragged this thing home this weekend, ripped into clearing out all the parts that had been thrown in it and get the car to a decent starting point tail lights - $50 after a quick clean, Also threw the steering column, dash, centre console and steering wheel to give me a little motivation. I found it super weird the lack of sound deadening compared to old cars, I'm not complaining as I hate having to chip that stuff out. I took the car to the car wash for a quick blast off before I got it home and it actually cleaned up relatively good, I threw some tail lights I had in there to make it feel like more of a car. I wish I could have weighed all the stuff I have removed from this but I will get it on scales at some point. next up is moutning the drivers seat, along with coming up with a plan where to mount the ecu, fuse box and pdm, I want to make a nice 3d printed pannel for the centre console to mount all of this. also tossing up weather I need to splash out of a digital dash, or just go with a nice tacho and a link can gauge or somthing minimal.1 point
Like my 'free' gsxr project. Sold some parts and made $1072 profit, walked down the road the next day and gave $500 of that money to a ghy and pushed bike home. I see that as free since it didn't come from any money we previously had, not house money etc. Wife disagrees. As for the falcon, 6 cylinder parts are twice as expensive as clevo bits, and i have rebuilt the engine a couple of times over the years with different ideas. Full lpg spec first and now 'screw economy spec'. Have had since '04 or '05, so has been around longer than my wife, and she knows it will always be a money sponge.1 point
The combination of the auto-folding wing mirror and the window tints were making the car too hard to reverse at night. I tracked the problem down to this module, which lives above the glove compartment: Whenever the module and the mirror were both plugged in, they'd start conspiring to improve the car's aerodynamics. I could hear the module making random relay chatter until the mirror eventually folded. I opened it up and found that both black capacitors seemed to have spilled their guts: After replacing them, the functionality is not back to 100% (only the left mirror folds on command, and only inwards), but at least the mirror no longer folds in by itself. While I had the door cards off, I noticed the front speakers were absolutely wrecked: No wonder they sounded like arse. I replaced them with some $100 6.5in Pioneers, which can at least make a little bass without buzzing. The car passed its warrant prior to the electric window fix, using Camel's tactic of pulling the mirror fuse. The warning items were oil leaks, tyre tread and another stuffed LF shock. Diamunty rides again.1 point
No, toolscome out of the tool budget. Thats what I tell the wife.1 point
Just fitted the SDM and its loom (glad i grabbed that as it was different) flashed the dash and holy shit, it works! no airbag light. Going through the list of things i needed for Dragday 2025 Blew the engine up. Fitted another engine (blew that up too) built new engine With real good new parts from scratch! Problem fixed. Engine has a turbo on it wont pass Wof. Removed turbo and intercooler. Cut bumper Bar. (Cleetus advises thats Silly) refitted stock bar Cut front springs, Full set of new lowered springs fitted. hard to start thirsty AF on fuel, Big side quest learned how to tune properly. Had to patch firmware to control big injectors at small pulsewidth better. Side quest 1 fitted Clubsport Seats from a VE causes SRS System to shit bed (the internet said they just go straight in) turns out they bolt in the airbags arent compatible. solution code out the airbags fit correct SDM and wiring to car to run factory code. Side quest 2 Fit VY Clubsport Headlights. Done and dusted after a refurb. Side quest 3 Do a Mafless tune so i can crank the Kpa to moon! 6 months later i've got it working and tunable. (still tuning Petrol cost slowing this up.) Side quest 4 Fit a High Stall converter to trans, Done (and a corvette servo for good measure. Fit HSV brakes, Done Bloody awesome! Fit Really wide wheels front and rear. Done ended up having to remove diff cradle and slide it over 15mm (factory Fuck up) Again used HSV Parts Wheel alignment for said wheels, Done. Theres so much other shit done too that i've forgotten but i think she's ready to go pass a warrant....... then refit the Turbo and go do some passes If you gave me help or encouragement thanks i'd have scrapped this car without it i've learned heaps and am in a position to help others if they want to play with a V6 or even an LS as i also ended up on a side quest there too. Theres a few cars getting around with my Patched operating system running them now.1 point
The following day I ripped into that rot on the radiator support. I cut out far more than expected but its all solid new steel now (nice thick steel too rather than two thin bits to trap moisture as was factory) in pics.. We removed the leaf guard below the windscreen and luckily its very solid under there. Just some surface rust in places. Even the windscreen locating clip seal is intact so no wet carpets.. Car came complete with a pretty little spider.. Next job is to spray bomb the underside with some 'new car in a can' black zinc. Then sort the stuck rear calipers, reassemble and take it for a wof test.1 point
We couldn't resist a bargain 😁 Meet Mavis. She's a PFLBB4DM. A# model with sway bars and disc brake rear end. Picked her up this morning from out near Collingwood so this meant first drive home was back over Takaka hill. I'd forgotten just how fun a manual 1.3 K11 is on the hill. We stopped a few times and swapped cars so each of us got to drive Mavis. Such a great little manual box these have. Got home. No fuss. Needs airing out as she's sat a while. Reason she's a bargain is a rusty radiator X member. I've done a few K11s with this rust now. Only other noticeable bit is the bottom of the front guards where mud collects. Otherwise very solid underneath. Plan is to fix, wof, drive her for a while, probably list for sale at sensible price and enjoy owning her till she finds a good home. I forgot just how tiny they are. Not ideal for 188cm me but still comfy enough. Amazing that the Cube z11, only a touch wider and longer than a k11 was able to carry so much in the back. A boot lid and two doors plus other bits swallowed easily. It really is the sensible 11. Very comfy and a bit quieter but certainly not as fun on the twisties. If only the Cube was a manual too 😞1 point
I put a heap of no more nails on some old roof flashing and weighed it down with scrap timber on my old one. Took timber off after a couple of days and it was sealed sweet as haha. Obviously matt blacked to hide the sinning. Was single cab with 7ft tray, and the mighty sd23. Rolling coal it still got somewhere around 8l per hundy and was slower than my old morris. Tldr... canopies don't have to fit properly! Bahaha Should add mk1, was free so put it on to keep hunting gear dry...1 point
I dont, as it would cause a post in the depression thread/ pending divorce thread/ dating fail thread However in my Firearm Safe is an envelope to be opened on my death so my wife does not sell them for what I told her I paid for them. LOL1 point
I don't keep track other than thinking, can I justify this vs the value of the car and/or how much I like the car and how long I want to keep it. But I also spread project car costs over a long period and don't pay labour by doing stuff myself like most people here, so I can justify (there goes that word again) the big ticket items by "saving" on labour. I have never tracked fuel other than the occasional calculation of roughly how many km's I do in a week, but only when fuel prices were almost $4 a litre. At that point I thought, maybe a cheap leaf makes sense for the work commute, but then what's the point in having interesting old cars if I don't use them?1 point
I started my build by making a spreadsheet of all the parts I need (so i knew what to order), all the costs, and a total. I got all those parts, and since then, nothing has been noted down because I dont want to know, and the scope has gone well beyond creep. I do keep track of fuel costs for all my cars.1 point
The bum on those look cool, and the panel softening is kinda neat too. Gives the body a chunkier vibe. I've always liked the PFL 2nd gen in dark colours (or at least not bright saturated colours) - I think the headlights and body shape give it a vaguely premium/VIP look that bright colours detract from. Of course, all subjective and taste-driven. I am now thinking about buying one, damnit. Even stock they look quite good - gee how car design has gone to the dogs.1 point
