Showing content with the highest reputation on 29/06/26 in all areas
I think I've said multiple times that this is rust free now, but there keeps being more pop up! After blasting showed up these holes in the lower a-pillar/cowl area. Was a bit worse than expected once I cut the outer off. That's the backside of the lower hinge mount, so had to be fixed to a decent standard. 3d scanned, cad'd and 3d printed a press die to punch out a new panel to repair the hinge pocket backer. A bit of prestretching and shrinking and it worked really well. All repaired and painted in KBS. Outer repaired and welded back in. Otherside was a touch worse on the inside compared to the outside. The heater core needed repairing and would of set me back at least a few hundred dollars, so went though Rockauto and found a Toyota Camry heater core for sub $100 that would work with some slight modes. Had to lengthen the core housing for it to fit and then drew up a new front mesh to suit. New heater mounts welded in and a 3d printed outlet or some adjustability on the vent. Over Easter I got the front panels blasted and all in epoxy primer. On to getting the panels all aligned best I can and gapping it right. Made up a battery mount for in the boot behind the r/h rear wheel tub. See you in another year for an update haha7 points
6 points
I think Dylan will like that.5 points
Over a year ago I stripped the bumpers, repaired the dents, filed and sanded the bumpers to get rechromed. The repro grill guards were pretty average pressings, so made them fit the bumpers better, and smoothed all the harsh grinding marks out too. Have so far sent every fastener, clip and component that'll be going back on the car and not replaced with new or be painted. Made up some radiator panel covers on the pullmax. Also cad'd up a coil/rocker cover and 3d printed. Will get some cast at a later date. Rounded off the top corners of the radiator as they just didn't look right. Made a powersteering reservoir and coolant overflow each side of the radiator also. Radiator shroud done with some rubber flaps. Decided I didn't like how the firewall looked, the heater motor sticking through, wiper motor visible and the seam through it. So made up some wooden bucks and swaged one out on the pullmax. Old firewall cutout. Recessed the cowl drain flange to suit the new swages. Fitted new wiper motor (old Toyota Celsior one) so it would sit in a similar spot to factory but behind the firewall. Screwed it all in place with panelbond between the new panel and the flanges, to seal it all up. Went through and plugged welded up all the screw holes and welded up the outside edge. New wiper motor mount. Backside. The panelbond worked well to seal it up.5 points
Dragged this thing home this weekend, ripped into clearing out all the parts that had been thrown in it and get the car to a decent starting point tail lights - $50 after a quick clean, Also threw the steering column, dash, centre console and steering wheel to give me a little motivation. I found it super weird the lack of sound deadening compared to old cars, I'm not complaining as I hate having to chip that stuff out. I took the car to the car wash for a quick blast off before I got it home and it actually cleaned up relatively good, I threw some tail lights I had in there to make it feel like more of a car. I wish I could have weighed all the stuff I have removed from this but I will get it on scales at some point. next up is moutning the drivers seat, along with coming up with a plan where to mount the ecu, fuse box and pdm, I want to make a nice 3d printed pannel for the centre console to mount all of this. also tossing up weather I need to splash out of a digital dash, or just go with a nice tacho and a link can gauge or somthing minimal.4 points
Some small progress today but jobs I've been either putting off or just not having the time. I got a brake and clutch lever from trademe as both of them were missing from the bike when I bought it. Bought from different suppliers, one was polished silver the other satin black. So I threw the satin black one in the blast cabinet and gave it a quick polish to match the other one. The clutch perch doesnt have provisions for an adjuster and the cable for the lifan would have heaps of slack so I made a spacer out of some stainless, Luckily theres adjustment on the cable at the engine side. I want to try and keep the switch gear as original as possible and the throttle cable uses a 6mm cable adjuster going into the housing. Most common universal/aftermarket cable use a M10x1,25mm adjuster. so I turned up an adapter on my lathe using some aluminium I had spare and some 6mm threaded rod then modified a throttle cable I had kicking about. So thats the cables all done. When I looked at the chain alignment I thought the lifan motor was mikes out and thought about using an offset sprocket, easier said than done. Nowhere had any in stock, so I thought about using c50 rear wheel so pieced one together from parts I have as spares. Before I swap wheels over I thought about putting a mock up chain on it and checking alignment. I t was actually spot on. I'll get a new chain for it either this week or at the weekend inbetween kids sports on Saturday. The last major things to top off the list are the seat and the electrics to finish wire up.4 points
The combination of the auto-folding wing mirror and the window tints were making the car too hard to reverse at night. I tracked the problem down to this module, which lives above the glove compartment: Whenever the module and the mirror were both plugged in, they'd start conspiring to improve the car's aerodynamics. I could hear the module making random relay chatter until the mirror eventually folded. I opened it up and found that both black capacitors seemed to have spilled their guts: After replacing them, the functionality is not back to 100% (only the left mirror folds on command, and only inwards), but at least the mirror no longer folds in by itself. While I had the door cards off, I noticed the front speakers were absolutely wrecked: No wonder they sounded like arse. I replaced them with some $100 6.5in Pioneers, which can at least make a little bass without buzzing. The car passed its warrant prior to the electric window fix, using Camel's tactic of pulling the mirror fuse. The warning items were oil leaks, tyre tread and another stuffed LF shock. Diamunty rides again.4 points
Hey guys long time reader here. I have owned this 1300 twice since 2019. It’s my 4th 1300/1000. My interest in 1300s started around 2001 when I saw the sik13b narrow body at meremere. There is something about the 1300 that does it for me from the proportions to the squared off wheel arches. Cars like Loexit also inspired me. i purchased this narrow body in 2019 off photos (yep i know should have known better). Anyway the car turned up in a container and was confronted with a car that had not been blocked and had a skim of bog and a flick of thick enamel paint and some rx7 wheels. When I got into the car I found quite a lot of visible rust. So I started making a plan and getting quotes. What had shocked me when the quotes came rolling in was how much panel paint and labour costs had moved since my last panel paint back in 2011 on my narrow body 1000. I asked for advice on this forum and the general consensus was to sell it. So I did…… The first panel and paint done in 2011 is the white car this was a very unique spc 1000 chassis 1 owner imported from Japan2 points
This is easy to correct, you can enbiggen or debiggen the needle hole via watchmakers block2 points
I was interested after seeing Top Gear USA decades ago probably do "project sipster" https://motoiq.com/project-sipster-part-7-sipster-indeed/ the goal was 7 seconds 0-60mph, 70mpg fuel economy for under $7000, and they did that but the fuel economy was over 80mpg (3 Litres per 100km ish from memory) I never looked into it further, was cheaper just to buy a car with that engine if wanted (I'm in Australia, and the gearbox conversions were in USA) there are kits to bolt them to various gearboxes, I considered one using a hilux 5 speed (W58 or similar) but Robot Cantina has an early VW diesel bolted up to a T5 (kit available) in a Chev S10 pick up in USA (current project, will be turbo'd supercharged etc later)2 points
No, toolscome out of the tool budget. Thats what I tell the wife.2 points
This cunt of a thing fought me the entire way. Could not get it to bolt up for love nor money. Got so bad I even pulled it all out and re-aligned the clutch disc again. No idea what happened but something clicked and it settled in. Every minute spent on this POS is one stolen from a project car I enjoy working on.2 points
Trailer has been welded up, just been put to the side for now waiting a tidy up and paint, Started the 4 door now, gotta make that mint, most the small spots of rust are sorted, gathering the energy to panelbeat and paint but going away for awhile for work, will be back on it when I get back for sure2 points
I did end up finding the 808 steering wheel but sold it when I found a more period correct wheel out of a Japanese Luce. In terms of the retrim I asked the trim shop to match it to an L10b cosmo. The finished results were awesome. Around this time I sourced a coupe speedo and had this rebuilt at parrot instruments who did an amazing job. The tacho needed a new drive unit. When you turn the car on now it does a cool sweep.2 points
The interior before: this was the next element of the project I wanted to sort. I needed to find a radio blanking plate with the Mazda emblem and some fan controls. These parts were sourced from a wreck in country Victoria. Plan was to source an 808 coupe steering wheel as I love the centre emblem and retrim the interior including new headlining and source a 1300 coupe speedo which has the factory rev counter. During this period I had managed to find a pair of nos taillights and centre finishing panel so I fitted them.2 points
I ended up selling the car locally to a panel beater. He kept me in the loop as the car progressed and unfortunately the rust is always worse than you can see. These cars have a flat panel along the top of the firewall and it was completely gone under the blower for the heater. A 1200 Ute was sacrificed to help the cause. It was around this time that the new owner and I did a deal to buy the car back painted and complied. So on my birthday in 2021 I got the 1300 back painted in Grenada red and fully complied. It was a happy day for me and nearly 10 years since I had owned the white car. During the rebuild I sourced a set of rx4 rims. I think they look great on the 1300 as they give it a slightly more aggressive look.2 points
LSD showed up. Tore it down as you should. Lucky too cos more than half of the LSD cap bolts were loose. I was confused about missing preload springs (in the form of belville washers) but googled the shit out of it and turns out that some of the diffs don’t have springs. The diff has 4 clutches (some only have 2) but I won’t know how well it locks up until I try for a donut. Will install over the weekend but I don’t have oil for it, so waiting on my Redline 70W-140 GL5 to show up. Supposedly BMWs recommended fluid for LSDs. The E30 small case diffs are notoriously weak, specifically the LSD cap, but this is actually a Z3 (still small case) diff which has a much stouter cap design. Still a weak point but less weak! You can buy billet caps, about $250, but it means rechecking lash and shims and contact patch on gears and that sounds like more work than not doing it. Might do later, will see if it needs a clutch replacement first. fuck it’s cold down here at the moment. Harder to find motivation to get out to the garage. This is just up from my house: I pushed the car outside to work on the diff on garage floor, and by the time I pushed back inside bonnet was covered in ice. Moist2 points
This is about where I bought another '60 Chevy. I was originally after some sort of 59-60 GM wagon before I bought the flattop, and this came up as a good deal after multiple price drops. Long story short, spent 7-8 months cutting out rust, welding new bits in and getting it ready for compliance. At the beginning of the year it finally got complied, wof'd and reg'd! Might start a build thread for it sometime.2 points
Over the Christmas break a year ago, I built some stainless headers for it. Pretty sure they were very close to equal length on the L/H side, but to make the look symmetrical-ish they weren't quite so close on the other side. Made an aluminium 4" tube intake pipe to adapt to the biggest K&N filter I could find. This was the point where this car was the last it's going to look like a car for some time. Looking back, probably should of just kept it how it was, got it going and enjoyed it for a bit. But then one day, I decided to strip the paint off.2 points
So after abandoning my ke70 race car and still having the itch to build something. I took awhile and hunted for some good candidates and ended up picking up this cheap gt86 with minor front end damage not old, but cheap, and parts abundant which is a nice change... and no rust. I purchased it non rolling so first port of call was to scour market place and pick up some parts. what ive found is the the best part about gt86's is how cheap parts are. really trying to build this thing on a tight budget so will keep track in this thread. - gt86 shell - $700 it was lookin pretty rough and bare when I first went to look at it but the main damage is very minimal, will most likely end up with a tube upper radiator support/headlight mounts to keep it simple1 point
It must have been the years of parking outdoors which did that to them, not me playing them too loud. I figured it must have been you who originally installed the stuffed speakers, because they were Mitsubishi branded but they clearly didn't fit the mounting points. I also had to employ dodgy means to hold the new speakers in place (fit for the random rough-as-guts bodges thread?) because the mounting points are too far apart. I checked the wagon's rear speakers but their cones are still intact. It's weird that they're mounted in the roof. You could hear the control board start chattering each time I folded the mirror back out, so I was able to locate it by ear! I wouldn't guarantee that replacing the control board would necessarily get both mirrors to fold in and out again, but I also don't think the mirrors are top priority any more. Have you got any other left front struts? Is the car still using the same model struts it came out with?1 point
Do you think I am fuckin made of money?1 point
There are a few projects others have done to run the stock cluster from an external canbus, but unless you're really wedded to the idea of the stock gauges, it makes little sense in this application. Great project though, I enjoyed my mostly stock BRZ and would love a project like this to iron out the issues they have and make it better.1 point
A man of your talents would take the speedo head apart and simply slam a toyota/nissan/mitsi speedo gubbins in place. Cut out all the middle men. It's three wires. I'm pretty sure the pip signal is the same from ecu as it is from a gearbox hall sensor. Unless those pesky Italians use some crazy shaft size for the needle?1 point
Yeap have ditched the canbus, was eaiser than trying to keep it happy with abs and power steering etc and piggy back stuff I have learnt I can setup the power steering to work in "limp mode" which is what everyone seems to do and have good success with it abs has just gone in the bin too1 point
My strategy is Grow weed Sell weed for $ Spend $ on cars. No records kept cos that would incriminate1 point
Like my 'free' gsxr project. Sold some parts and made $1072 profit, walked down the road the next day and gave $500 of that money to a ghy and pushed bike home. I see that as free since it didn't come from any money we previously had, not house money etc. Wife disagrees. As for the falcon, 6 cylinder parts are twice as expensive as clevo bits, and i have rebuilt the engine a couple of times over the years with different ideas. Full lpg spec first and now 'screw economy spec'. Have had since '04 or '05, so has been around longer than my wife, and she knows it will always be a money sponge.1 point
Toycrazy ??? @ae25 may have been involved and there was photos measurement of many conversion parts1 point
My exhaust cost me $700 instead $1300 because I built it myself goes down so much better as long as you dont mention the $7000 in welders and gas cylinders........ but now I can do other people's car and make that back was my reasoning. Haha Ive maybe accumulated 11 beers and $300 dollars doing other people's work. But i did build my own turbo and Intercooler for free* using the welder. *actual definition of free may vary depending on who's asking.1 point
I've never been asked to cert one if thats any indication, have done couple of golf's which have been tuned though Not many people do diesel swaps really, have done a BMW 6cyl and a Mercedes om606? in 4wds , and a v8 duramax in something else I assume its because they are reasonably expensive to get in NZ compared to how much power they make?1 point
Been down a bit of a youtube rabbit hole on VW 1.9 TDI swaps. Are they a common swap in NZ or like the 4bt in that they are popular overseas but we are stuck with Isuzu's?1 point
The rotary conversion. I had owned the car now from 2021 and had got plenty of enjoyment driving the standard motor around Canterbury with my young son. It was around 2024 I got the rotary itch so started to make a plan. Tim Wood put me onto a motor that was destined for his blue coupe - it was a 10a rebuilt to factory specs by Grant Munro so I knew it would be well built. With everyone going for triple and quad rotors I thought I would go the other way like the flat head guys of the past who at one time were pretty unfashionable. It also meant with an r100 crossmember which is a straight bolt in to this chassis meant I could get the 10a to fit pretty easily ( more on that later). The first stage of the rotary conversion was to sort the suspension. Xd falcon shocks bolt straight into these in the rear so I ordered a set of koni adjustables for the rear and put new springs and inserts in the front and ordered a kmac camber kit, along with a mini me willwood front brake kit from pac performance that is designed to fit inside factory 13” steel wheels. I also sourced a pwr r100 radiator and oil cooler and spal fan. The other main thing I got at this time was a new brake master. The owner of the mayhem 1200 gave me some great advice here and I went with the jb1133 its a duel circuit option but has the benefit of looking a bit nicer than the 1” duel people favour and gives you a nicer pedal feel.1 point
During Covid I had sourced a replacement parcel tray, door skins, new door shells, guards and a few other bits and bobs. The purple car had a horrible rubber kit. So I sourced brand new windscreen rubbers from the uk and matched English made mk1 escort door rubbers. I also had the car blasted underneath which fortunately revealed a very tidy underside besides the front chassis rails which where cooked. As above it was around this time I pulled the pin and advertised the car. Here is a photo of me clearly a bit gutted to be selling.1 point
Aliexpress techstream cable and then followed this vid to run virtual box on a shitty old laptop with the software Bit slow and clunky but much better than dealing with generic OBD2 readers that work poorly or not at all1 point
While I'm on a roll I've been thinking how to tackle the wiring on this car, with it being modern and having canbus etc. the factory ABS needs the ecu to see the speed and all that data to work so the easiest option in my head is to just CTL+ALT+DEL all of the original wiring and abs out of the car. I had a link monsoon left over from my old 4age that I've had tucked away, a cartek pdm which is a very simple 4 10a channel solid state relay setup which will be good and to run everything else saw KPR run one of these on his ae85 and thought they looked like a tidy way to do relays/fuses, can't beat aliexpress pricing. im terrible at wiring so this is going to be the major learning curve for me wiring everything from scratch and I would really like to do it all myself as a challange. - link - free? Bought with a 4age setup and kept it/sold the 4age for how much I bought it for minus the ecu - cartek pdm - $150 second hand - aliexpress fuse/relay box - $58.60 someone smarter than me will beable to tell me but 10 outputs should be enough, tail/brake lights, ecu power, semister/blower, starter motor, fuel pump, radiator fans, coils. Is there anything else I could be missing. I've been trying to find some nice but not super expensive switches/button pad too. Not something i reallly want to fail.1 point
Annnnnd the last 4-5 months I have been buying unnecessary/necessary things for the car - blacktop itbs on 3sge manifold - $250 - key's racing wheel - $250 - bride zero ms carbon aramid shell and 6 point takata harness - $1500 the bride seat is super co and only 2 years old along with the harness's so still in date!1 point
First thing to do was work on getting this thing rolling so I could get it home. Started looking for some parts on marketplace place - blitz coilover - $150 - black racing n1 in 17x9 +30 - $500 - grb sti rear hubs to convert to 5x114 - $50 - gk tech front hubs to convert to 5x114 - $400 now it's rolling I can finally drag the thing home and start digging into it properly. plans for here are empty the thing out, it still has 90% of its interior so if anyone need anything flick me a dm. I have a j160 and hopefully a spicy 3sge sorted because it's currently the best/most cost Effictive combo at the moment, I did consider ez30... and ofcourse 2zz, 2gr but still went back to 3sge for how simple/cheap they are. a bit of inspiration on ow I would like this thingg to end up looking, the main downside currently is aftermarket body kits are still super expensive and not very abundant at the moment. a guy in Aus has just started making mount kits to throw 3sge's in the zn6 chassis, they look simple enough so I will probably just make my own and try get the motor sitting in a bit better of a position1 point
If it hadn't already spiraled out of control, this is probably the point where it did. Bought a 01 VX Commodore 5.7L LS1. Test fitted it in. Since the trans was swapped to a TH350 the driveshaft yoke and length worked perfectly. Also the aircon pump and alternator just have enough room to make work. Made some engine mounts. Used the same polyurethane bushes as what I used in the rear suspension to make it easy. Will add some more gussets to strengthen them up a little. Transmission mount the same bushes as well.1 point
To make the pivot point for the Watts linkage I started with a piece of 38mm round bar and a twin row bearing. Milled a slot in it for the bearing to slip inside and bolt through. Then I drew up an arm in Solidworks, 3d printed and then got Dad to make a pattern to get it cast from aluminium. We had it heat treated to add some strength to it too. Bent and welded some 38mm rollcage tube on to the ends of the pivot boss. Made up some arms from some pipe, threaded bosses and rod ends. The whole process would of been a bit easier if I hadn't welded that crossmember so close to the back of the diff! This pic is fully laid out. And at ride height. Decided to strengthen up the lower rear arms. Tried pressing in the original style bushes, but gave up very quickly after they kept crushing the c-channel arms. Stupid design really! Welded in some bits of pipe and got some tophat style polyurethane bushes. Way nicer to use and same size as what I used on the Watts linkage. Also replaced the one in the upper arm with same bush.1 point
