Showing content with the highest reputation on 11/25/21 in all areas
Two weeks I waited to hear the verdict on the case. Before I took the car off the road for the rust and paint mission, the oil leaks had pissed me off enough to pull the engine out and take it to a local mechanic for new pushrod tubes and any other seal he could bung up. I remember him telling me the case was cracked behind number 3, the thinnest part and hottest running cylinder, and the heads were toast. We he was fuckin wrong about the case! Unbelievably it's only on its second over size now, so happy as finding a good base to build is getting hard these days. Even more amazingly, the crank is still within standard spec and even the center journal with the munted bearing only needed a light polish. The dude even said " he can't remember the last time a crank came in,that didn't need machining" guessing lucky! But I do always change my oil regularly, every 3000miles or six months as you should on these old clankers. I set about cleaning up the case. Using a small brass wire brush and turps. Will need to make sure all the galleries and shit are clean before it goes back together. Also go as well as the crank bearings, which are machined to fit, new big end bearing in the rods, new cam bearings and a full engine seal kit. These however, have been quietly waiting their turn under the bench for a long time. Soon my pretty, soon.13 points
And laid down some black. Gave all the bushes, which I replaced earlier in the year, a clean and fitted with fresh grease. Also spent some time cleaning up the threads on the shackles and lower shock mounts plus the fasteners to suit. Some of them were pretty manky. Got it all back togethor and threw the has tank back in too. Good way to finish up a nice evening. Excuse the wheel nuts on the shock mounts, I had no m12x1.5 nylocs at the time.12 points
Here’s what a weeks wages before tax looks like. At least I’ll never have to touch it again I guess10 points
Massive thanks to @fletch who came up with the goods. Trip to NP this weekend to pick it up!6 points
6 points
5 points
I forgot to readdress this. I did speak to the individual last week, and from what he'd explained, was that he was residing outside of the Waikato boundary, but had travelled to his personal property inside the Waikato boundary to tend to it, adhering to whatever rules or permits applied at that time (I don't know). Probably redundant now regardless, as I understand there is no Waikato boundary any longer? I'm unsure if anyone was particularly concerned by this whole thing or not, but there it is, as I know it anyway.5 points
Put the ps box in, it bolts up just fine, just needs some panel work done in the cabin to bolt column housing onit is now adjustable got me a rivnut gun and some steel rivnuts, this van diddnt have a swaybar from factory, but it had the holes in the chassis and it so happened they were the perfect size for m8 rivnuts, so i put them in and it bolted right in, bushings are new too so thats an upgrade. Also went through and swapped out bad ball joints with good ones, and greased everything up..3 points
Bit more progress on the B2000 over the past few weeks. I had a bunch of stainless tube and bends lying around, but havn't had the hoist free or the time to make a system, so when I spotted this setup that a guy was selling I thought I'd better jump on it. He was parting out his bagged truck for some reason which never actually made in on the road. He had the system made to tuck up above the chassis rails but still fit the stock chassis mounting points. Has an AdrenelinR muffler and reasonator fitted so wouldn't have been a cheap setup to get made. Can't complain for $425 shipped from Timaru to Akl... He even made this sweet crate to send it up in. My shifter bush kit finally showed up from Aussie, so I swapped out all the worn shit and fitted a new non-split boot then got it installed. Tight boxes are gooooood.3 points
Well I got back into this and finally finished building the box and have now filled it with tools. Very happy with the finished product. Continuing on from my first post I added a few more bits. First off was a lid that covered the stainless tray. This was 18mm plywood left over from the shed build. I hinged it off from one side and made a swing out support to hold it up when its opened. Then I build a lift up section along the back to hang spanners and screwdrivers off. I added a lid to this bit. I ripped down some bits of eucalypt timber left over from the coffee cart we recently built for a customer ( that's another thing I must put some pics up of because it was a cool project!) These bits of timber were then profiled into corner cappings. With them attached Hannah then oiled it all and varnished the flip back lid. I made some handles. One main one for shifting it about the workshop and then a swing up one with more leverage that is for moving it offroad. I found a little handle we have had for yonks. Ideal for the lift up section... Finally a little box on the side for a few often used cans- wd40, spraygrease, zinc it black etc. I took no photos of all this because I was just absorbed with the build. Now complete I filled it with all the tools I use on car jobs etc. This was super fun because it meant I could shuffle loads of stuff about and off the walls. I could also move my old toolbox that took plenty of useful 'Flat six' sized space and put it under the bench. The bench area became a bomb site with stuff all over the place as I did a workshop bench spring clean. Got rid of lots of crap and re-organised a load of stuff into new trays I'd bought from Bunnings. This satisfies me no end. Anyway- back to the toolbox. Which now has a very catchy name. The 'Wheelybox 2000' pics. Closed up and ready to move... and opened up (a pic sort of like a toolbox equivalent of 80's Lambo poster with all the doors/boot/engine covers open).. In action... on the move.. detail shots... ( should have done a narrow depth of field shot of the cans through an open window...) the tray.. and for your amusement - this is what happens when I do a spring clean... So happy with it. It going to be a bloody useful asset to the business and save a lot of walking back and forth to the bench, especially when doing jobs on cars, trucks and tractors etc outside. Should have done it ages ago! My next plans for the bench area are to paint the plywood walls a bright colour and probably add a window over the bench - especially as we have chopped down loads of trees and we would now be able to watch the sunset through it as I tinker with Goldwing engines. I'll update the bushblock thread with that sort of workshop tinkering though. Better get back onto the Micras and the Imp 911 first eh....2 points
So I took the case and crank over to Qualitat for their air-cooled guy to check if the it was viable to rebuild. Wasn't holding out much hope as this is 40-50 year old chunk of alloy that I abused on a daily basis. Took the opportunity to clean up the rear wheel well. Made these from some scrap alloy I had. Marked up a that's about right spot. And cut some massive triangles out of my nicely painted engine bay. Drilled hole and popped rivnuts in. Left the edge rough to hammer over the frame to strengthen the panel up. Both bent to shape and countersunk for mounting, the plan was to drill and tap the frame for the covers to attach with but was thinking about using VHB tape. All this work is to make installing the carbs and manifolds easier, it to about 10 minutes to put the engine in last time, and two hours to tighten the four nuts that hold the manifolds on.2 points
Having never done this before, I took it easy and did my best not to damage any mating surfaces. My vintage schadek oil pump cover. And 26mm heavy duty pump, which needs to be pulled out as it bolts to both half's of the case. All the bolts, nuts, seals removed. Amazing there isn't a rubber seal of anything between the half's or even any sealant I could see. The middle bearing has seen better days. Crank it.2 points
Decided I should allow some time to have fun with the car before considering Webers. So I got a new Holley Double Pumper. Looks the business. Went with an old 50s Cadillac air cleaner. Not a fan of the normal round ones. Its quite dangerous having Summit Racing, Original Parts Group, Classic Industries etc on your door step! Next day delivery on anything!2 points
With the rear suspension done, and reinstalled the handbrake cable, i started to unpick the front end. I want to clean all the greasy dirt that is still caked on everything (and has actually done pretty well at preserving stuff) and then i can clean, paint, regrease and reassemble. Im very pleased to say, the rust is all on the 'outside' of the van in the panels, and not the chassis structure. Took all the brakelines off first, including the lines from the reservoirs (they are up behind the drivers seat) to make later, they all unscrewed easy. I didnt have the right spring compressor so just used the jack under the lower control arm but i think ill need one for putting it back together! Some before and afters Drivers side after dropping the wishbones out, and then after a scrape and waterblast Same area immediately after dropping the suspension and after a scrape and a waterblast. The light brown is a mix of oil, grease and road dust that is anything from 1mm to 20mm thick. Usually clean paint or metal under it, so could be worse! Only surface rust really is where the greasy smeg wasnt - a lot of cleany shiny metal where the paint came off with the waterblaster. This pic show where one of the main bolts comes thought, the inside of the rail is minty mint mint The two wishbone assemblies and the steering rack. ALL of the tie rod ends! One of the suspension assemblies, give a good idea of the crust on everything. Ive water blasted under the van about 10 times. After a clean, still has factory (?) shim count stamps . I got some new CRC degreaser for the parts washer, stuff is magic, seems to have a slight derusting action too. The gear change linkages came lovely, and have no discernable wear which is another sign of low milage Pretty sure these would have been factory fitted (CKD built by Torino Motors in Otahuhu), but cant believe how clean they came up! Pretty sure thats a manufacturing date stamp, which also makes me think this van is also a later (66 on) one. I re-found this service sticker that was in the cubby in the van that i thought id lost put somewhere for safekeeping . Along with the Kelso address painted on the Hubcaps, I reckon she is a Southland Van Place is still going Im going to get some paint made up soon (i have lost my paint swatch) so i can make a start respraying the shock mounts and engine bay etc before bolting everything back in. Still a lot of cleaning and stuff to do first. Head is off at the machine shop getting looked at, and i have the rims in the back of the daily to get the tyres stripped and then off to the sandblaster, so progress is continuing.2 points
Rubbish update: I plucked the exhaust out of the garden and gave it a quick flick of paint. The can was naffed so i pierced it and brushed it on.. It’s purely to keep them uniform. I’d love to do headers one day so wasn’t mad keen to detail these manifolds. The pipe work is practically new, like I’d be surprised if it had 100km. Can read the part numbers stamped into it. Mufflers I think are on their second life but I have some spares.2 points
As I was reading I was dreading that it was going to get to, 'I sold the rotary and the datsun'. Sweet ride! Look forward to more pics1 point
I had a hilux in a few weeks back that stopped and wouldn't start again. The fuel gauge had stopped working and was stuck on half, but the tank was empty. Had just enough in the tank to make it seem like it had fuel when you prime it with a hose off1 point
Ah she has since found one in AKL with a prettier colour, belay that order... But cheers1 point
Epic to see another 64 here! Sing out if you need any bits, iv got a few 64 bits lying round still from my build1 point
Shizer it's been a while and cringe at my old posts. Anyways, I chucked a blanket over this and shut the garage while I did other things for a couple of years. Lockdowns meant pulling the blankets off, I got it running on the factory intake so was motivated again. Rear screen rubber in, stainless trims fresh and polished, random clips from russia and its now airbagged using accuair control with airlift struts. It drives well around the hood and I'm slowly getting more confident on going further. I never drove this car so was a big moment. Next on the list is sorting my rear wheels as they are a bit wide for frame laying and then a bespoke itb manifold from Mr Whitley tune. Pic courtesy of Simon when it was picked up a few weeks ago. Il take some when I get the trims back on.1 point
A huge update for the car, but a shitty update when I try and write about it. theres only so many pictures you can take of an axle. I had the 3.54 gears and blackline Lsd sitting in the house since august. the supply chain is wrecked as we all know. so I had brake shoes, springs and wheel cylinders brand new ordered but they never arrived. got all the way to Auckland, sat there for 3 weeks then got sent back to the uk. go figure. so I fitted the old shoes, used a mixture of the best springs and clips I could make of the 2 sets and bought wheel cylinders again. I pressed new bearings onto the axles and bolted it all together. I just needed to get it done the old diff was knackered. I took the car out today to a motorkhana with a mate with the MG club today. had great fun and it was also a great test of the car, suspension and diff etc and I got a few hrs cruising to tweak the carbs and keep an eye on the wideband. I need to do more research. when the car runs best it reads about 12.8 cruising and 12.2 on full throttle. from what I've read so far that's too lean but I need way more reading up on it. anyway.. few pics. old new.1 point
Rewinding a little, I stripped the spare engine. Remember how I had written earlier that the vendor had stated it had “good bores”? It seems my scepticism was well founded! mhmm.. Ooh, nice. Clearly well maintained. Won’t turn, so soak them pistons Three days later, 3 pistons out, one still firmly in. I tried all sorts of brews, heat etc. Hammering with a wooden drift did not work at all, the drift was absorbing too much force. In the end I smashed it out with a steel drift. During this pounding, the head flew off my big ball pein hammer and of course it landed on the CAR!! Bounced twice, and luckily missed the boy, Anyway, check out the mint bore And piston I will scrap this piston due to the loads I imposed on it during extraction. So I have a usable crank, head and some pistons and rods and of course the block could be used if bored out, but since pistons are unobtainium that’s academic. The cam lobes are rusted to buggery and the intake cam is rusted into the cam box and I’ve been unable to extract it.1 point
Over time the poor old Thames has turned into a bit of a storage shed the biggest items being our pool loungers which is a pain in the arse. Being red there is just no way that we can leave them out in the elements, so muggins here has to lug them out and back in every time we feel like lying by the pool.1 point
Working on Sundays. It's exhausting work. So I decided to pull the headers and make them tuck in a bit more. This has given the steering arm an extra 15mm clearance. I wasn't happy with 10mm clearance. Then set about making the rest, to include a flexi and 2 three bolt flanges. I have 2 cotton reel mounts in there at the moment and a hanger on the dumpy. About to make a 3rd cotton reel mount for just behind the resonator/flange to carry that load. Then I'll drop it all, finish the top welds and then spray it in high temp paint. I'm pretty chuffed with it so far, will also check for knocking and clearence issues, but so far it all looks good.1 point
Picked it up, took it home. Then retired back down to Wellington. 20211106_153031 by phillipbaines, on Flickr 20211106_153045 by phillipbaines, on Flickr 20211106_153105 by phillipbaines, on Flickr 20211106_153117 by phillipbaines, on Flickr Next on the todo list: - Tidy up all the panel gaps #1 priority - Purchase an MRP coil over kit all round - Purchase some semi slicks - Get a wheel alignment - Replace inner and outer rack ends Potentially on the todo list: - Price up a full suspension kit minus coil overs from T3 (LCA's, RCA's etc) Discussion:1 point
Thought I may as well get the shock mounts done before pack up time too. Flipped one of the stock upper shock mounts and used that on drivers side, then used some lasered brackets I had left over from another job on passengers. Shocks sit nice and more upright than stock so should ride a bit better. Can almost see the light at the end of the tunnel now.1 point
Lame updates: fizzed some metal back into the battery tray and painted it with nice thick paint! Also stripped the pinstripes off the bonnet in preparation for sanding and some satin black 2K both sides. Hit the wiring loom with a thinners rag and wiped everything, cleaned up the terminals etc. sucked! Will tape it again as I put it back in. Blasted more clips and speed-nuts + painted, spend some time on the bench grinder wire wheeling nuts and bolts, painted inside the dash where it was a bit crusty from rodent piss. Cleaned up and painted the bonnet striker catch and voltage reg bracket. Made some gaskets for the inner guard splash guards, more to go. And in fantastic news, I jumped on some wheels for the back! Just the size rim I wanted and the BFGs are pretty perfect..hard to get used to these old man profiles but they will suit it wicked1 point
Looking good. The wheels suit it. Like that you've retained the factory 'special' badges. It certainly is.1 point
