Showing content with the highest reputation on 12/31/20 in all areas
I like this thread a lot so time for some contributions... random stuff I just found on my phone. I made a doll house thing in a little suitcase for my godchild and wire people Check for details... I also made her a dragon like doll to cuddle no pic of it all assembled Other gifts... Lamp for a friend who has bees and just had his first son at that time Rack for spices, one for my brother, one for my sister in law Some deco for my sons bedroom, a lamp... Another lamp And some cut in half dinosaurs For the daughter as a present something to hang and store clothers for her dolls And some covid protection thingy for my wife as she is a speech therapist V1 which was to wobbly according to her And V2 which she and her partner still use That's me for now, not revolutionary or shocking... Thanks for watching.16 points
Better epoxy that floor too incase some english cars turn up my vote for offtopic build of the year i think7 points
today went better. i got the little bit of surface rust of the inside of the scuttle panel and chucked some brunnox on it. poured some brunnox inside the fuel filler flap and then chucked some primer on things. yesterday i primed the car again so only the drivers side needs another coat, the rest of the car is ready for wet sanding. yay, wet sanding. 2020-12-30_02-33-07 by sheepers, on Flickr 2020-12-30_02-32-59 by sheepers, on Flickr 2020-12-30_02-32-45 by sheepers, on Flickr 2020-12-30_02-32-52 by sheepers, on Flickr before priming, 2020-12-30_02-33-43 by sheepers, on Flickr 2020-12-30_02-33-36 by sheepers, on Flickr after priming, 2020-12-30_02-33-29 by sheepers, on Flickr 2020-12-30_02-33-22 by sheepers, on Flickr7 points
Got the body in primer about 6 weeks ago It then took me all that time to get it up to a reasonable state so that it could then be painted. So then a couple days a go we loaded it up on the trailer (only just fit!) and dragged it into the spray booth at work. Sprayed the base and clearcoat on, it turned out pretty good! A few runs around in places, but nothing that can't be fixed. Pretty stocked really! Could of easily gone wrong haha. Gonna leave it in the booth for a few more days to harden, then take it home and get some underseal on the underside. In the meantime get the rest of the panels ready for some paint too.6 points
Well after staring at this in the workshop for the last 3 months while we've been massively busy at work and I've been caught up on the weekends entertaining my son I finally managed to get a couple of days to spend on this so I managed to mount my seats and get my tunnel fab'd up. I had to change my plan for the seats as my original design ended up too low and too far back surprisingly. Also the cert man wasn't happy with me removing the stiffer running the width of the car. So, I went back to the drawing board and came with this Then I made up a cardboard gearbox tunnel. And decided I better turn it into steel Happy to have those big jobs ticked off. I do still have to pull the engine and box to weld underneath but the hard work is done for the tunnel fabrication which is great5 points
We had people coming over for a late lunch so we had to get cranking asap. Let the paint sit for 10 minutes then quickly fitted the vents and assembled it for another burn off. Only had about 2 hours to burn it off and cure the paint before I needed to get some food on. Got it up to about 500f for about an hour and a half the tried to drop it off in preparation for cooking. Random home kill rolled beef roast I found in the freezer. Approx 3kg gave it a blackout rub. Really wanted to get it on the rotisserie but it was too bloody hot to fit it up haha. Got the temp down to 350f and threw it in, couldn't really wait for it to drop anymore. Ran it at about 350f for 2.5hours indirect with stout in the driptray. Combination of Kingsford briquettes, applewood and some Manuka we had lying around. This is absolutely winged and rushed, for the first cook and I had no probe for internal temp. Let it sit for about 20mins wrapped in foil, when served it was about medium, slightly rarer in the middle so not too bad considering (forgot to take pics). Held temp well, I think if I start off with less coals (i.e not doing a burn off) I'll be able to get the temp right where I want it and also vent/damper controls will work a treat. I'll look at cutting the cooking grille so it's 2 piece for access loading up coals. Chur5 points
Bought a couple 10.5kw, 30" fans 2nd hand, which should be enough to suck the nasties out. These are 3 phase so I really need Mr sparky to come and wire them in. You read my mind. Except more just to keep noise down a little for the neighbors in general and get rid of the tin can feeling inside. I had some left over noise batts at home and some normal batts I scored from work for a box of beers, so I banged them in the walls and threw up some noiseline gib for now. Built a false wall to enclose the fans as well. I bought some sheets of 60mm polystyrene for the ceiling too, but will wait for mr sparky to do his bit first. Also finishing off 2020 with a quick hit in the gem.4 points
Doing the practical thing and hiding my wiring, so if there's a problem its impossible to get to it...oh, fuck...yeah...ummm...why do we do this again??? I googled and googled and the general consensus was that upto 1/2" (12.5mm) hole is fine, people have been doing that for years without any issues. I decided that 3/8" (10mm) was enough to get the job done and would leave a little bit more meat on the bone, so thats what I did. Offset slot to the left. Everything is going to run down the clutch cable once done. I spent ages sanding everything down so there's no sharp edges to cut the wires. Now I've just gotta heat wrap this mess and shove it down the inside of the bars. Oh and the other side has double this amount!! Ummm... for want of a better phrase this was my "first pull". Hey, sounds better than "tug"?? Boom, both side done. New loom pops out right by clutch cable, I'll cable tie it together and run it down to my new wiring under the transmission. So that's a good start on something I've been very much procrastinating. Winner, winner...chicken dinner!!4 points
4 points
So yeah, as seen above, took it back to the water yesterday and it does run a lot better when its not breathing its own fart cloud. Picture of failed engine mount and V band that needed toightening. IMG_20201228_170634 by John Bell, on Flickr I'm not completely happy with its performance though now its making full more power, it doesn't 'bite' the water like I would expect, if you feed it more power than it can shift water, it nangs out and feels slower than if you were to nurse it up to speed. You can see/hear this in one of the vids. It handles a quite loosely, but I don't have much reference to compare it to, aside from the donor ski which carved corners like a water-skiing cut cat, comparatively. If you do manoeuvres that are too aggressive or any spins it comes off the plane pretty easily and doesn't pop out of the water like the motor seems capable. So next step is to look at the spare jetunit, if its any better pop it on for testing, and I feel I'll probably wind up giving one of the pumps a birthday. Cute IMG_20201228_182945 by John Bell, on Flickr4 points
Burn off the other night went well. Got it to 500f and it held there for atleast 3 hours without adding any extra fuel. Left it going when I went to bed. Had a look in the morning and it looked like this... Emptied out the ash and gave it a good clean to prep it for seasoning and paint. Just used olive oil on the inside as that's all I had and Mangawhai shops are shit to go to this time of the year cause of all the jafas and northern bass homies.3 points
Awesome. What a cool project, and it looks like quite a pro setup for someone building it in their shed. OS Dyno day at your place?3 points
Wiring is for dicks!! I wish I just kept my "Bluetooth" Wiring as it looked much better without real Wiring... Anyway, reality dictates I will actually need to do it, despite how much I want to avoid it. Take 1: Relays in the battery box. Seemed like a good idea, and was reasonably tidy. However I was unable to run the wires internally up the backbone of the bike as I envisioned, as the loom has too many wires to all fit in there with other stuff going on like fuel tank threaded inserts and the way the saddle tube connects and blocks the spines opening...arghhh...grrrr!!! So, take 2: Try shifting everything under the transmission. Sweet, rear wires = very tidy, I can easily hide those. Front wires can be run alongside the clutch cable (heat shrink to keep it all coved of course). I can even use OEM fittings for connecting everything up, which was always my plan if possible. Yip, standing back it looks fine. 100% better than my first attempt, which was just fucking ugly. This is much better, no ugliness along the backbone distracting from the clean lines. The naked spine and tank are this bikes main feature and cable ties and a honking big wiring loom there would have looked shit!! Calling it a win.3 points
Found what was causing the intermittent wire feed when I used 0.6mm. Turns out the drive motor can move a little on it's mounting bolts, 10 or so years of tightening the roller had shifted the drive wheel down a little bit so the mechanism bottoms out before it's tight enough for the thinner wire. Fixed now. YAY! It was so frustrating. Zip zap. Got rid of the ugly seam flange thing. Welded inside first. Then cut off the flange and welded the outside. Then linished and used the knotted wire brush to show up any gaps I missed. Then weld and repeat until no gaps. I also welded up some rivet and bolt holes that are no longer required. I need to cut some round patches for the original heater pipe holes because I've relocated them. I've also welded in the modified cross member, but the photo was blurry. I still need to make some filler bits for the 'corners'.2 points
Hopefully that sorts the issue out with the miss firing, gotta love the Chinesium quality see problems all the time with the ls1 o2s and knock sensors2 points
Well yeah But nah Not sure what i ran this one on, possibly my falcon when it had the single barrel stromberg? Or i swapped the weber base with one of the guys and got this in return. Oh well, best be ordering a new one next week. Already loving how much freeer the engine feels, haven't messed with timing yet just warmed it up and set mixture by ear. When i get back to work i will play some more, but for now ooohhh boy i forgot how the old webers sound with no airbox.2 points
Now to track down the ramflo off my old cortina, only lived in a dozen houses since then..... think i know what nail it is on in the shed2 points
Just brought a banjo bolt with inbuilt pressure switch, this will send a signal to indicate that the rear brake is applied. And a nice little ignition switch (key). I realised I would need these parts after reading the wiring diagram fror the 50th time and wondered how to get a brake signal to the rear, I figured there'd be an existing solution for this problem, so happy to pay the money for it.2 points
The more I look at this thing, it never stops looking awkward as shit. Luckily you can't see much boat when you're sitting in it I guess. God its ugly.2 points
Thread dredge from page 6 haha. Progress has been very slow on this. Lack of room is just a killer. Tonight I pulled the 2l out. One step closer to pulling the cab off the c notch chassis . At least with the motor and box out it will be a little lighter to push in and out of the garage. That's all the progress for now. So here's a boring pic for a boring build2 points
Upper and lower racks sitting in place. Then set it up for it's first burn off to kill off any nasties from the paint and stripper. I added a few more similar size chunks of Manuka and got it cranking. So far it has been sitting at 500f for the last 2 and a half hours with no extra fuel. Seems to be going well enough for something that owes me about $130 and about 10hours. Yeah a Weber GA is only $150 but this is far more rewarding. I might give it another burn off tomorrow morning then I'll be seasoning it, throwing some paint on the outside then throwing in a rolled beef roast. Keep. As to see how it turns out. Will get a picture of the rotisserie tomorrow. Chur2 points
A few months back I bought the 4 items in this link to make it all work https://yourdyno.com/shop/ - I had to wait a couple of weeks for it but it was perfect timing as they had just released their own eddy current power supply. After checking out his youtube and forums it seemed like a good option for a reasonable price. I then bolted some tie down points to the concrete, hooked the speed sensor up to the YourDyno controller and connected it to the laptop. I set it up for inertia mode with a moment of inertia number based on some weight calculations of the roller (educated guess for now). Strapped the trusty old NS250R to the roller and just eased into to things to get an idea of how it was all going. I popped it in 3rd and did a run right out to 10,000 rpm or so. This was a pretty epic moment for me honestly. Everything felt smooth and nothing looked out of place, so the next day I mucked about shimming bearings and coupling the retarder to the roller. Still in inertia mode, I strapped the paddock basher MX5 to the roller and did a test run in 3rd. Once again everything looked pretty good at this stage so I am very happy. Here's a video.2 points
Finished up what I think was all the fabrication and welding on the body. So gave the inside a good clean, sand and then sprayed some epoxy primer down. Came out really nice and smooth! Scuffed back the bits that need to be nice as they aren't being covered up once the interior is back in; wheel wells, strut brace and the b to c pillars. Also went around all the seams and applied some seam sealer, matched to the factory look. Then it was ready to spray the base coat and clear on. Really happy with how it turned out, got all the visible bits nice and glossy! Got some basecoat matched to the brown colour of the dash and spayed some on the dash top piece. Sprayed some flattened 2k clear on top. Got the outside, underneath and engine bay mostly sanded back, hopefully done by next weekend so it can be epoxy primed. Not really too sure on what order to do things from now though. Would like to try and avoid having to mask it up multiple times and having to sand the whole thing in-between each process.2 points
Got some stuff back from zinc plating. Was more of it than pictured but I had already started assembling the bits back together before getting a photo. Still not sure why some comes out really nice and shiny and other bits come out dull. Most of it will get painted anyway so not too worried. Bought some longer trumpets from MRP. Need to get the throttle bodies vapour blasted! Got the Estima handbrake cables remade and lengthened. They didn't work with the original mounts so machined up a new aluminium one, took far too long! Bought an AE86 boot and fuel door lever assembly as I never liked having to open the hatch or fuel door with the key each time. Now was a good time to modify it all to work. Shaved the key hole. Works perfectly!2 points
Project discussion: I bought this site unseen from Hamilton a few months ago. It's @brocky41 old car credit to him getting it going. Turns out it's actually a good thing... Spend the last little while fixing little stuff.. Tuning it up and charging around the country side. Really nice jap cruiser.1 point
It's probably worth looking up the difference between JIS and Phillips screwdrivers, https://www.webbikeworld.com/hozan-jis-screwdrivers-review/ and finding where your 10mm socket(s) have escaped to.1 point
The "full" mark is for when the engine is at operating temp? Is the cap on the expansion tank allowing air back in during cool-down to replace the volume of coolant headed back to the radiator?1 point
Hotcam, (what came out of a)DR125, gn125 Looks like the Dr one has a tonne of duration on it so it might be an old dr200 cam. Should measure it. Cam "bearings" I. The dr125 head got a bit chewed as they all do in these engines, but I should be able to lap a little off the mating surfaces and run a reamer down to remove the worst of it1 point
Bloody hell just looked at the date from the last post, haven't done anything to the ute since october aside from a few runs up n down the street to keep the battery charged. Got daughter outside with me this morning and we swapped the carbs over. Did a bit of cutting and grinding of the factory cable mounts and throttle wheel, drilled/tapped out the coolant port in the manifold and glued in a bung. Testfired and it runs, will fill with water after lunch and warm it up, set mixture etc. Have bypassed the water choke for now, no need for it over summer anyway. Pics to follow.1 point
My Mrs gave me a hand with the prep and paint. Cleaned with soapy water then a few wipe downs with acetone. After that we brushed on a few coats of pot belly black, decided to go with the stuff from the tin as previous spray can efforts turned to shit and flake off easy. 3 coats later and it looks like this. Disregard the handle, it is just makeshift for now so we can take the lid off easy and it's fitted with tekscrews. I'll make another later.1 point
Not really, I'll try and get a photo at some point, it doesn't have many features if I remember right, aside from many scrapes and marks in the plastic.1 point
Do you know what the specs are on the hull? Is it flat or have planing strakes? A lot of fibreglass boats handle loose as the have a shallow v to run in less water, old Jet44s were pretty slippy. Alloy you can get away with a bit deeper v since not as scared of rocks an strakes make a hell of a difference1 point
** discussion here - https://oldschool.co.nz/index.php?/topic/74793-helium-elbows-magical-rx-7-fb/ ** Ok a little bit of progress on the wheel front - I painted one centre silver and reassembled to see how it would look and it came out good, I think the bronze colour is lush but only really suits having the whole wheels painted like Watanabes. And the more I think about gold the more I don't think it will fit in with the existing black and silver the car has right now. In other news I took off the 3pc spoiler to repaint as the top surfaces were very weathered and showing the base coat. Also lots of dirt and crap under the spoiler and even a little bit of surface rust to attend to in spots as well And painted (still needs final wet sanding and clear coat) I'm still yet to do the centre section as I'm modifying it to fit a centre brake lamp as I'm paranoid some c**t is going to rear end me, and I don't want an aftermarket type one hanging from the hatch window with messy wires blocking view and lighting up the interior every time I brake. ** discuss failings here - https://oldschool.co.nz/index.php?/topic/74793-helium-elbows-magical-rx-7-fb/ **1 point
Gave the gearbox a lil clean and made a new gasket for the top cover (it never had one). The selector mech is still a bit sloppier than I'd like it but tough to make it much better with the current set up. Got alot of the sills/box bolted in. These dog legs are notorious for rotting out at the bottom (exposed to mud from the rear wheel). Got most of a repair done and checked the fitment. The b-pillars arent quite where they need to be so may need to be cut/re-welded. I'd love to replace the whole sill/b-pillar but at 3K plus shipping a side that isnt going to fly....1 point
Getting the engine started is a milestone I want my partner to be there for so putting it off until the holidays when we have the time. So in the mean time let's take a look at our fuel system. I read that fuel drains slowly so I didn't bother to raise the back of the car to fit jerry cans/buckets under, instead opting to just use a pan and ice cream container and swap them over. This went poorly... But at least I didn't roll a 1 so the garage and everything is intact and I just have to deal with the fact that I need to keep all the doors open for a while. Also poor: my preparation. I bought a 10L jerry can and for some brain fart reason decided that is all I'd need. I had a couple more litres than would fit in it so I threw it in an old container and let it evap outside until I could get another one. 15 year old fuel smells and looks pretty bad. My old container was dirty so I was hoping that the crud at the bottom was already there. Foreshadowing Fast forward to weekend: Partner is over! I want to see what is borked and what can be cleaned and re-used. She removed the wheel and dropped the fuel tank after a bunch of dirt/fuel to the face. What a trooper. I disassembled it and found probably the first truly effed functional pieces of the car. I'm actually shocked at how bad this has rusted. It's like the rust has generated its own cities and infrastructure on these tubes. This float mechanism is truly beyond hope. I was hoping to be able to clean the in-tank filter and re-use it, but it's $15 from amayama and it looks like I'll need to find some other bits too so shrug emoji. I gave the tank a quick zhuzh with a smol brush and left it outside to tackle another day. I can hear debris shift around when I tilt it. A brief shitty look inside is inconclusive - definitely some rusty bois floating around in there but not sure what the tank itself looks like. The exterior has some minor surface rust in places, hidden under the geological layers of dirt. It sucks that the holes are so small, definitely won't be able to get my arm in there to clean it properly, so we may have to wait for some solvents to arrive courtesy of partner's chemistry connections. As a side, the paint around the drain hole peeled off from the fuel. Seems like a design flaw... also the fact that the heat guard can't be removed so treating up in there is going to be "fun".1 point
Went for a drive today, it’s going better than ever apart from the hot start problem witch may be related to the worn out ignition switch witch causes a misfire sometimes. Speedo is working well, 30 MPH works out to be about 58 KPH I can live with that, side mirror blew off but luckily it landed in the car, PCV is wonderful, oil stays clean and way less fumes, I am wondering about slotting the distributor for more advanced, I set it max advance all ready and I am running 91 with no pinging. On the hunt for some 600-15” tires, my front tires are old and hard like they are made from stone1 point
Stripped most exterior stuff off, except for the doors. Have cut off the a-pillar rain gutters after ajg193's suggestion, cleaned up all the rust underneath and plug welded them back on. Found some spots of rust on the hatch after removing the window. Most of it is just surface rust. Got carried away and stripped all the paint off the exterior side. Previously someone has stripped it and gone over all the rust spots and ground them out. Which I wasn't too happy about, but it seemed to have stopped it rusting further. Has a little patch welded in on the lower right as well. This top bit, just below the water squirter had a few small holes. Cut it out and made a patch to weld in, after I cleaned up the rust inside and painting it. All welded and cleaned up. Picked up a new engine! 4AGE 20V Blacktop!!! And a J160 6 speed. It already has the SQ Engineering adapter plate. The clutch/pressure plate and starter is already set up ready to bolt the two together. Pulled out the old 4K. Empty and dirty engine bay. Gave it a steam clean, came up heaps better. Test fit of the J160, definitely going to need to pull out the grinder! Laser cut out a 12mm stainless exhaust flange. Planning on building some high-rise headers at some stage. Ordered some goodies from SQ Engineering. Bought some Cusco AE86 engine mounts. Also have an AE86 water pump set up and some other bits on the way.1 point
