Showing content with the highest reputation on 04/04/17 in all areas
I've loved to piss and moan about how I think these are annoying and a stupid idea. But after having a driveshaft fail at 80ish kph on the weekend, Oh boy am I glad I had these loops fitted! My brake and fuel lines would have taken a hammering if not for these - They are a good idea, even in my case where all factory parts were used within factory power levels.5 points
I'm going to suggest you divert this to Hamilton and come to the swap meet here in Hamilton and also come to my annual open day haha. Will not be able to attend now sorry. Edit. Will have free snags.5 points
Longest exhaust build ever! What a stupid idea it was to design it like this haha. So far has 5 pairs of flanges on each side if you include the ones at the end of the headers. Will have another pair after the diff as well. Got some flexi's and welded them in, as well as the rest of it. Need to put the tray back on now and see where the rest of the exhaust can run out the back. Made some mounts, after making them incorrectly to start with. Had the rubber hanging under tension where-as it should be compressing, otherwise it would most likely tear the rubber in half. Also made some gussets for the 4 link brackets since they didn't quite look strong enough. Might make some to tie in the other side as well. Need to make a start on the fuel tank soon. Any recommendations on an in-tank fuel pump to use? Don't really know much about them, 255LPH should be enough? Tank will be about 220mm deep if that matters.5 points
4 points
4 points
All sorted. @427carguy to the rescue! Cheers Hogan.3 points
Yes , I have ef xr6 front springs/shocks in my au , brake hose brackets are the only thing you need to be creative with . Ba/f front rotors & calipers are a fairly straight forward upgrade while you are under there too2 points
Clutch plate arrived and I installed it today. I've found some koni shocks cheap and they arrived last week. I took them into stocks and got them checked, turns out they have been revalved so score on that. I'll need to get new forks and top hats to fit the larger diameter shock bodies.2 points
Yep that's fine. Probably better to get a bit of pipe put in, I knocked the guts out of one once and it was a cunt of a job and it made a mess and there's probably stuff you shouldn't breathe in. I spoke to a cat scrap bloke the other day and I think he pays 60 $ for a cat. Might pay for the job even?2 points
lighten it till it breaks, then make it just strong enough2 points
Thanks mate. Turns out the hobby car manual is actually pretty good (lol)...I wish I'd bought it earlier (being able to spend 10$ per relevant chapter makes it much easier!!!) I was even more impressed to see things like suggested tube and heim joint sizes... Really really important for someone like myself who genuinely has no clue and tends to oversize everything.2 points
Might do something about that if it becomes an issue, That has been shortened about 150mm. The accelerator cable is quite short so need to work out a linkage of some sort to the pedal. In the mean time a spare bike brake lever fits on the end, stick my thumb through the handle bar hole and I have a hand throttle so long as I keep my hand by my side and steer 1 handed. Kids aren't keen to drive like this which is fair enough, move your hand the wrong way and it starts revving. So I had a hoon with the kids trying to chase on foot, can get up a fair amount of speed in the back yard, managed to spin out = happy Dad Couple of little problems; 1 It is quite loud. 2 It needs a chain gaurd so it doesn't flick oily shit up my back.2 points
So its been a long time with no progress on this, those of you in the digger thread will have seen some of the other stuff ive been up to but we finally got this off te truck today, Bit of a fuckin mission since both the big diggers are out out site so we went full Barry n used our bin truck gantry! Next i have to shift my bobcat and fire engine to this yard then we'll start cracking into getting the Kaiser moving under its own steam.2 points
I have been looking around for a while for a new work truck, wanted to go old school and update it to modern running gear and some creature comforts. I didnt have much of an idea but liked the look of older Chev trucks, did some reading and looking and got to this point. Truck will be in the country mid April, it is currently running a 327 and manual gearbox, and pretty much stock apart from that. Plan is to get it complied with existing running gear then modernise a wee bit. I have an LS3 and 6L80 trans and all associated wires and mechanical stuff in my warehouse now (cart before horse) and maybe a front end suspension transplant from a later truck and a diff with a lower ratio. this one will be either a 4.11 or 4.56 ish I believe, so a bit on the highside. While the intention wasn't to start/have another project, Im quite fizzed up about it. Going to keep it stock looking, no fancy wheels or any of that crap. Will get some hand painted signage on it, I want it to look like it was always there.1 point
The Auckland Monthly Meet! Wednesday 19th APRIL the SECOND TO LAST Wednesday of every month. Save the date 7:30pm onward (but you can turn up earlier, no dramas mayte) A chance to catch up with fellow club members, talk with people you may or may not have met before and get your mouth filled with meat. Or not meat if you're that way inclined. Burgerfuel, Mexicali Fresh, Ajadz, Subway, Doolan Brothers etc. Corner of Robert St and Hurst St, Ellerslie See map. The DEAL$: FREE Drink with Burger and Chips Purchase (From the COKE range , excluding mini burgers) FIRST MEET?? If you are new to these meats here are a few points that may help; Most people usually show up between 7:00pm and 8pm-ish. We roll down to get burgers and whatever else is available whenever we're hungry. We sit around either at Burgerfuel or back up top in the carpark and continue the yarns. Remember its always a casual affair, a place to yarn to mates and make new ones. An Oldschool car is not required at all, but if you've got one on the road then bring it and show it off!! Doesn't need to be flash or special, As long as it's special to you And to be honest, only lame people would drive a boring modern daily driver there anyway. MOST OF THESE ARE COMMON SENSE. WE WILL PROVIDE A FEW GENTLE REMINDERS WITH THE NEW RULES BUT REPEAT OFFENDERS MAY BE ASKED TO LEAVE. RULES AND THE BORING STUFF!! Basically these are in place so we have a fun and friendly meet and leave the carpark clean and tidy like we were never there. Take your rubbish away with you or put it in a bin, Use the public bins downstairs not the private ones belonging to the business up top. Smokers please don't dispose of your butts on the ground! Please limit the ALCOHOL consumption. Its a public place and the Police/security regularly stop in and we don't want want anyone getting in trouble, We also don't want people leaving empties around. You are welcome to invite a few mates, but please note you are 100% responsible for their behaviour If you belong to other clubs and feel they might be keen to come check out our meet then that's cool but please see Threeonthetree, Shakotom or BDA780 for permission before inviting them. NO Skids or Reckless/Dangerous driving Please leave a space near the fenced off area clear for the cleaners and don't block them in if they are there. Park in a proper carpark! If its full then just use a bit of common sense and try not to park too many people in. Newschool cars please park to one side and be prepared to move if we get short on space. I have had to ask Newer cars to move and park elsewhere and will continue to do so. The old cars get first preference for parking. Don't be offended if you're asked to move your newer car to make space for something old. AU Falcons may apply for an Oldschool dispensation in writing, by sending applications to "Dave's Intech Compassion Klub" or DICK, 126 Grey Street Onehunga where they will be reviewed. If its raining and we have to park downstairs then new cars park upstairs or out of the way. The covered carpark is very small and needs to be OS only,! If you drive your Mum's Suzuki Swift etc than bring ya Mum. If you have any suggestions or input for the meets then PM Threeonthetree, Shakotom or BDA780 Thanks!!1 point
Mine is a wagon so can't help on rears , front was about an inch lower than a mates au3 ticford xr6 but still has reasonable ground clearance so not really low at all by oldschool standards !1 point
If it's rocking a petrol manifold, I'd be sticking that pyrometer in the primary for number 6.1 point
Today I received my Route 6 close ratio T50 from Japan. Bought in an auction with 25mm large T series axles and an LSD 3.9 diff head to go in this build mainly. It was listed as having a broken gear. Being the gambling man I am I took a punt on it and 4th* is damaged. I have some spare T50 bits that I could take in and probably get it fixed, but I also checked the gear ratios and to be honest I think I will just stick to the standard T50 and sell this one off! These go for good money for the racers, will look into getting this fixed first. Discussion //oldschool.co.nz/index.php?/topic/52401-pbaines-1971-toyota-corolla-ke25/&page=21 point
can prolly do Timaru, if you get stuck.1 point
Fingers crossed it can be removed, I don't know exactly what the booster is out of so don't fancy sourcing another one. Will remove it and go from there I suppose...1 point
@flyingbrick I bought a couple of chapters last night too, quite impressed with it really. As I need to lengthen the pushrod it looks like my only option aside from squeezing an OE booster back in (which will prevent the rocker cover being removed/ may not even actually fit ) is to have an engineer turn up a 1 piece pushrod. Provided the pushrod is one piece, constructed from suitable material and its diameter is appropriate to it's length I think this will be acceptable? First time I've dealt with this sort of thing so its all a bit confusing.1 point
Just to give everybody an update. I splashed out and replaced the rear shocks and all the bushes with nolathanes, reinstalled the good set of springs with some 2" blocks. I thought the driveshaft didn't look as far in as the saggy springs let it go in but put it back on the ground and road tested. Vibration is back but not nearly as bad, probably 40% of the original intensity. It is also now only there between about 50mph and 60mph then goes away again completely. From here my plan is to get the driveshaft extended by 20-30mm and balanced and that should solve my problems once and for all.1 point
Made some brackets for the ARB awning. ARB wanted $25 each for these. Took maybe an hour to make. I really wanted to just mount the awning directly to the rack towers but they are all ever so slightly at different angles and out if line because of the curve in the roof. Sits maybe an inch or so further out then i would like because I made them while the van was at my friend's shop. Had him do the transmission fluid and filter. Normally I'd do this myself but it requires dropping the exhaust to get the transmission pan off to do the filter, which is a pain without a lift (an hour job that takes all day on the ground). Fluid looked old but good so I'm happy with this transmission.1 point
Nothing wrong with a bit of good healthy overkill. 1+1=4 but we call it 10 to be safe.1 point
I built my own triangulated 4-link for the Mercury. No tests needed, but I did use the specified sch 80 pipe (heavy car) and drilled inspection holes for the threaded ends. I did all the welding myself, including the adjustable ends. I do know the certifier through the Hot Rod club, so I guess he thought I could weld OK.1 point
It was good to have a ride in this at nats. Bloody good in person1 point
Wicked wagon man I'm currently building my own few years off looking like yours but its goof to see there's still a few of these around !!1 point
Got the engine bay cleaned up and painted. The body is all paneled and primed now. Just about ready to paint, just a few small imperfections to tidy up and then wait for a sunny day to paint it. All my painting is just done a a outside shed I rigged up made from corrugated iron roof and plastic sides. Not perfect but defanatly better then painting outside under no cover1 point
but not as fun as twisting a throttle/riding a miniature train..1 point
The road to toytafest! Here's a pic to prove i made it, will post how I got there in the coming days1 point
Leadfoot Time - Part 2 Sunday Sideways Here's Leadfoot from behind the wheel Caught up with Tanner in the pits who was super friendly just like everyone else I had talked to over the weekend. Top Bloke Times are in and here's mine for the weekend Prize Giving time Cheers Rod , Shelly and the Leadfoot crew for a very memorable weekend One very happy Father , Son Duo1 point
Batteries on the frame... Took me way longer to drill, rivnut and bolt up then i want to tell... Lots of little complications. For some reason this whole battery thing took me a lot longer than i feel like it should have. Rebecca fortunately made progress on the sound deadening while i rolled around on the ground acting like a like a complete muppet. Did both sides, still have the roof and doors to do.1 point
So after a lot of down hill testing while the kids were in bed I thought it was time to focus and chuck the motor on. After thinking how I'd mount the motor out back I was having trouble working out how I'd brace the mount as the axil was right in the way. I finally decided to dig out the motor to see what I was working with. Oh that's right, it's the size and weight of a jandle. More than strong enough. Next up the exhaust had a big bow in the flange where it bolts to the motor, had no gasket material so pulled it off to file it flat and found this. Bit more manual die grinding with a file. While I was at it I cut the tiny little exhaust tip off and replaced it with a piece matching the rest of the pipe. Don't know if 2 smokes like this or not but the boy racer urges were in charge at that point.1 point
Some clever ideas. I'd over complicate it myself and it still wouldn't work as well as yours. Watching with interest.1 point
Had a similar issue many years ago , turned out there there was a pair of pliers inside the tyre , had almost completely rooted the inside of the tyre though the wire, we had the tyres balanced but the pliers where almost held in suspension by all the rubber fluff from the pliers spinning in the tyre1 point
Has 8 little levers (4 down each side of drivers seat). What they control I have no fucking clue, get it running and play with it lol1 point
