Giant Posted April 21, 2017 Share Posted April 21, 2017 Hello all. Welcome to what I call the giant shit heap. A 84 hj60 long wheel base high roof landcruiser. 1st up I'm not sure what to do with it yet bush truck? Restore to factory? Or most likely restomod. discussion thread Quote Link to comment Share on other sites More sharing options...
Giant Posted April 21, 2017 Author Share Posted April 21, 2017 https://imgur.com/gallery/qh0hd 3 Quote Link to comment Share on other sites More sharing options...
Giant Posted April 22, 2017 Author Share Posted April 22, 2017 Well i went rust hunting today found a fair bit of it. Going to start cutting it out Tuesday. rust https://imgur.com/gallery/34d2W Quote Link to comment Share on other sites More sharing options...
Giant Posted April 22, 2017 Author Share Posted April 22, 2017 Hers some more Rust Might need to get a tetnis shoot after this Quote Link to comment Share on other sites More sharing options...
Giant Posted April 26, 2017 Author Share Posted April 26, 2017 Well i still haven't started on the rust. But I did start on the engine bay. One new thermostat and one less ac system(didn't work) https://imgur.com/gallery/2bZKH Quote Link to comment Share on other sites More sharing options...
Giant Posted April 29, 2017 Author Share Posted April 29, 2017 I am seriously pondering the metal state of the last owner. found a patch of bog covering perfect steel no rust, no dents. Nothing. Quote Link to comment Share on other sites More sharing options...
Giant Posted May 6, 2017 Author Share Posted May 6, 2017 Well iv decided what direction this project is going in. Off road. Slowly chewing though the parts list. 2inch anti inversion shackles with longer shocks and 35s for a start. Made some progress on the rust. All the small holes have been filled. Took a wire wheel to them rust killed filled with fibre glass and hit with some primer. Pics to follow Quote Link to comment Share on other sites More sharing options...
Giant Posted May 7, 2017 Author Share Posted May 7, 2017 Slowly ticking things off the wof sheet. Today was brake lines Brakes https://imgur.com/gallery/aVdme Quote Link to comment Share on other sites More sharing options...
Giant Posted May 11, 2017 Author Share Posted May 11, 2017 Lift kit finally on its why from oz. 2inch anti inversion shackles. Now to find some adjustable shocks. 1 Quote Link to comment Share on other sites More sharing options...
Giant Posted May 22, 2017 Author Share Posted May 22, 2017 Lift kit is here The 60 looks a bit stupid now So much guard clearance atleast a foot. Lift https://imgur.com/gallery/YrpKD Needs tyres. And big ones 1 Quote Link to comment Share on other sites More sharing options...
Giant Posted May 28, 2017 Author Share Posted May 28, 2017 Done wheel bearings today. What a shit fight. Last owner tightened the ever living shit out of the lug nuts. Que blow torch and my big power bar. At some point a seal has failed to do just that. Found a bit of water sitting in the hub. Quote Link to comment Share on other sites More sharing options...
Giant Posted June 4, 2017 Author Share Posted June 4, 2017 Today's progress. Went father into the hub. Swivel seals,bearings and bronze bushes are getting replaced slowly ready for a diff lock. Only have to open it once this way. Don't have a lot of picks was covered in shit all day More hub stuff https://imgur.com/gallery/oIdK9 Quote Link to comment Share on other sites More sharing options...
Giant Posted June 16, 2017 Author Share Posted June 16, 2017 Rebuliding the front brake calipers Went pretty smooth Brake rebuild https://imgur.com/gallery/ehXHx Quote Link to comment Share on other sites More sharing options...
Giant Posted June 16, 2017 Author Share Posted June 16, 2017 Also forgot to post this. New radiator https://imgur.com/gallery/OTI2H Quote Link to comment Share on other sites More sharing options...
Giant Posted September 8, 2017 Author Share Posted September 8, 2017 So if been a bit slack lately new job moving house and what not so the 60 has just been used as a daily with not much else. I have decided where this is going. Swap the 2h anchor out for a 6BD1T(pretty much a Cummins 6bt) intercool and up boost and fuel. Goal is 180whp.160hp flywheel is stock Re gear the diffs to suit 35s and lock the rear(auto locker) Currently on 32s. Ute chop is a maybe. Current state https://imgur.com/a/yxopx Quote Link to comment Share on other sites More sharing options...
