Toyota Diff Info - Crown wheel sizes, Ratios, General info
Carsnz123
I'm not sure where I got this info but I thought I'd share it.
First of all some basic info about the F series Diff.
Crown Wheel: 7.5"
Braking: Drum and Disc variations
RA65 Celica = Drum
RT142 Corona IRS = Solid Disc
MA61 Supra = Vented disc
MX73 Cressida = Vented Disc
YR22 Tarago = Drum
MS112 Crown = Drum
Corona Mk2 = Drum
RT142 live axle borgwarner discs can be adopted (semi) easily onto some F and T diffs
F series ratio info here on Toymods too.
http://forums.toymods.org.au/index.php?t=msg&th=33561
To see which ratio your F diff is check out this:
Read the Axle Code from the vehicle indentification plate.
first digit: ring gear diameter
A 138mm
B 145mm
C 6.25"
D 6.62"
E 7.1"
F 7.5"
G 8"
H 9"
J 9.25"
K 9.5"
L 10.5"
M 12.5"
N 13.5"
P 14"
Q 12"
R 162mm
S 6.38"
T 6.7"
U 6"
V 10.6"
W 15.5"
X 142mm
Y 158mm
Z 202mm
- no ring gear = FWD
Second, third digits: gear ratio
01 3.30
02 3.36
03 3.545
04 3.556
05 3.70
06 3.889
07 3.90
08 4.111
09 4.222
10 4.375
11 4.444
12 4.625
13 4.79
14 4.875
15 5.125
16 5.286
17 5.60
18 5.714
19 5.833
20 6.167
21 6.667
22 6.78
23 6.833
24 7.64
25 4.556
26 5.571
27 3.364
28 4.30
29 4.10
30 3.727
31 3.909
32 6.591 or 4.807
33 7.503 or 5.583
34 6.781 or 4.786
35 7.636 or 5.60
36 4.778
37 3.583
38 3.417
39 3.154
40 5.375
41 3.308
42 6.500
43 3.550
44 3.214
45 3.533
46 2.928
47 3.944
48 3.356
49 3.729
50 3.400
51 3.736
52 3.722
53 3.250
54 3.941
55 3.333
56 2.821
57 4.058
58 3.238
59 3.234
60 3.519
61 2.724
62 2.892
63 2.655
64 4.312
65 3.837
66 3.071
67 3.526
68 3.095
69 4.176
70 5.857
71 2.962
72 3.949
73 4.285
Fourth digit: no of pinions, ltd slip-yes/no
Code pinions ls
2 2 no
3 2 yes
4 4 no
5 4 yes
Example: F372 = 7.5" 3.58 final ratio 2 pinion diff. Will not be stamped on the diff, you will have to check the build plate on the firewall of the car you pull it from.
LSD Availability: Altezza LSD's form the likes of Kaaz etc will bolt in but a spacer ring needs to be made up for it to work. Can anyone shed more light on this? Steroidchickens?
Tomei Altezza centre into an MS112 Crown = Works, no problem!
Cusco Altezza centre into YR22 Tarago = Success!
IRS centres will bolt straight into Live axle F diffs so you could use an MA61 LSD but apparently no good for proper driving with small clutch plates and small surface area they aren't very effective and usually well worn out. An aftermarket 1.5 or 2 way or locker is your best bet for grip or drift work. See Kaaz, Tomei, OS Giken, Cusco, (TRD no longer available)
Side note for celica/cressida/irs corona - Altezza/RS2000 Cusco LSD was a nightmare for my diff guy into RT142/RA65 IRS centre probably due to the car not being LSD to begin with. Machining and lots of hunting for correct bearings needed. Have been told (but can't confirm) that the MA61 diff centre half shafts are needed as they were lsd from factory and are shorter to suit.
Torsen and Truetracs LSD's are also available. Many hilux 4wd live axle ran 7.5" FRONT diffs too 80 and 90's, possibly 2000's. Lots of options from 4 wheel drive aftermarket companies.
Cars:
MX13 Cessida - 3.9 - 1410mm (Same width as T series/S series/KE70 BW)
Tarago YR22 - 4.1 manual and 4.3 auto - 1435mm
Uses a G series (Hilux) diff nose flange bolt pattern (60x60mm) All other F series is 55x55mm)
Crowns:
MS110 Solid Axle (coils) F362: 7.5", 4.77:1, 2 pinions, Open
5x114.3 1450mm Solid disc
MS112 Solid Axle (coils) F292: 7.5", 4.10:1, 2 pinions, Open
MS123 Semi trailing arm IRS F285: 7.5", 4.30:1, 4 pinions,
Clutch LSD 5x114.3 N/A Ventilated disc, 1 piston calipers
MS50 Solid Axle (leaf) F292: 7.5", 4.10:1, 2 pinions, Open
5x114.3 unknown Drum
