kicker
Kicker's Honda Beat FC50
80 posts in this topic
Hopefully some of the other Honda parts like spannies are compatible.
Just looking it up now and stock the AF07 has 7.2ps @ 7000 versus the 5.6 @ 6500 for the AF18, MONSTER HORSEPOWER!
My japanese manual turned up today, so have been looking through it
Neat.
Starter circuit is working now after a clean, the horn is borked so will buy a new one and the headlights, of course, run off their own coil in the stator, derp.
Got the cylinder off, it was jamming on some congealed crud that had built up on the piston while it was sitting, need to replace the circlips as they are quite corroded.
Shopping list so far is
Horn
Headgasket
Circlips
Share this post
Link to post
Sick project kicker.
I used to have a Honda Elite 250 (CH250), it was proper fast for what it was and the styling so RAD!
Would trad eagain.
ch250_85big.jpgfree image hosting
Ha sweet! It's got the look.....
nananana, na na na na na, nananana, na na na na na, na na na na na
she's got the look
1 person likes this
Share this post
Link to post
Ha, used to own one of those, had one of the original style Kats too.
Mine was white and black with gold frame
1 person likes this
Share this post
Link to post
Was hoping a Dio exhaust would fit without too much hassle, looks like a bit of chopping is needed from a couple Japanese sites I have found.
^The Ruckus wheels look pretty sweet on these
5 people like this
Share this post
Link to post
kinda want to see one with the nosecone raised and used as a front fairing/windscreen, with clamp-ons tucked inside..
3 people like this
Share this post
Link to post
So the piston rings are mega stuck, heat and penetrant not working and the rest of it doesn't look too flash so I'm looking for a replacement.
Can't find anything listed as a Beat piston, I have a parts catalogue on the way which will help with part numbers. Bore and stroke are 40 x 39.3 which is common to some other Honda scoots of the same vintage but one difference is this runs a 12mm pin so I looked at oversize Dio pistons but height might be an issue with those. Eventually I found something on eBay which looks to be perfect, measurements all match up, just waiting on a couple details and it's $45 delivered.
1 person likes this
Share this post
Link to post
I've got an AF27 dio piston kicking round for size if you wanted to try it out or whatever. its scored to fuck down one side, but might be useful for a test fit?
Share this post
Link to post
Could be a go if this one falls through, chur man, will let you know
Share this post
Link to post
I saw a matching one of these outside KFC Kilbirnie last night. Same colour and gold wheels. The nature of Wellington means you will ride past this dude on yours and have a joyful moment when you see each other.
4 people like this
Share this post
Link to post
that 3D dynamic power output graph is out of sight. speed through the power of science
3 people like this
Share this post
Link to post
I think I saw that dude last night Rich, saw something riding towards me and thought wtf is this pos, lol'd hard when I saw it was the same as my recent proud purchase
2 people like this
Share this post
Link to post
Piston arrived, looks good. Will give the cyl a hone and wang it in.
The JDMness of this scoot means find replacement parts is a bum, have not been able to track down a headgasket and due to also having to seal the waterjacket and exhaust chamber I can't get away with a coat of copper spray.
I have been in touch with a custom gasket outfit based in Thailand, gasketstogo.com, they have quoted US$12.95 for a composite gasket with fire ring, no setup cost and a lead time of 12 days. Sweet.
The carb cleaned up a treat, was pretty damn clean inside, just a little bit of gelatinous old fuel.
Pulled the variator and clutch off to clean them up, has some green rollers in it, anyone know what the stock weight might be? No tiny scales to check them.
2 people like this
Share this post
Link to post
Stock rollers are 11.2g, have ordered some lighter ones to play with.
Share this post
Link to post
I got some 7.5's on the way, good starting point?
Share this post
Link to post
Yeah should be an improvement, will raise the shift point a fair few RPMs.
The way to do it is buy an assortment of cheap rollers in various weights (eBay ftw) and try different combos until you get it how you want it, then once you find what works swap the cheap ones out for a decent set.
You can mix 2 different weights too, I'm running 3X 3.5 and 3X 3.75 weights which has put my shift point at 10,750rpm/need to go slightly heavier as my peak power is at about 10,250rpm.
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
