Sign in to follow this
Followers 0
Abarth
1970 Honda CB250k Super Sport
29 posts in this topic
New box of Honda bits arrived, installed new air filters, new rubber carb mounts, battery strap and clutch cable.
Old ones were fairly rooted
Popped open the clutch cover to see this mess, 45+ years of grease mixed with dirt. Cleaned in up and banged the new cable in. Adjusted the clutch bite and took it for a ride. Totally changed the feel of the bike! Clutch is smooth and gear changes are direct. Stoked, simile on dial achieved.
/ cool exhaust baffle, i'll replace this soon.
Thanks for looking!
2 people like this
Share this post
Link to post
Been riding this as my daily, everything was running good except the battery kept going flat.
Found these specs on the net:
CB250 = 110W output (~8A)
1156 bulb draw - 27.3 watts EACH (1.93A)
1157 bulb draw - 26.9 watts full (1.92A), 8.3 watts running (.6A)
Headlight - OEM - 25W/35W (1.7A/2.5A)
coil charging (assuming 5 ohm primary resistance, 14.5 volts) - 42 watts (2.9A)
neutral/indicator bulbs - 3 watts (.2A)
So the charging system wasn't up to the task of keeping the battery charged while riding round with the headlights on 100% of the time. To fix this I upgraded to LED bulbs which use about 1/8 the power; brake light, park lights and gauge lights. Way brighter now and the battery stays topped up.
1 person likes this
Share this post
Link to post
Next mission was to upgrade the way it went round corners, with blown front seals weeping milky fork oil and shocks on the rear which looked like the factory ones it was lose in the corners. Offered a lush ride over bumps but thats about it.
Got some new rear shocks and painted the tops black to blend into the bike better.IMG_3676.JPG
Share this post
Link to post
The tires on it also looked about the same age as the shocks so they were binned for new ones, I liked the ribbed vintage look so I got some new Chen Sheng and Maxxis tires.
Then had a massive day at the workshop;
Installed new rear shocks
New tires, inner tubes and rim tape
Stripped and rebuilt the front forks, new genuine Honda seals and fork oil.
New brake shoes, lubed the brake drum mechanisms.
Tided up some rough as guts wiring around the points.
Rides well now, handles solid round corners and the brakes actually work. Stoked!
4 people like this
Share this post
Link to post
Added a new chain, front and rear sprockets, what a difference! Since this is my first bike and all my previous two wheel rides were Vespas I had no idea the old chain had so much slop in it. Also banged in a genuine Honda oil seal behind the engine sprocket just for future piece of mind.
After a lot of work she seems to be running good mechanically now so the focus is on to tidying this up externally. I'm torn on keeping that big chrome, stock fenders classic look or cut everything down to create a cafe racer.
In the mean time I brought new mufflers to replace the old rusted out pieces. They came with the thinnest sound baffle already (yellow) so I added an extra sound baffle kit (white) to reduce the noise. Goes well now, although I need to have a fiddle with the carbs again to balance them out, one header pipe had a baffle jammed in it and the other side didn't.
Who knows why but I removed it so both cylinders flow at the same rate.
2 people like this
Share this post
Link to post
Was pining over tire stickers on some instagram cafe racers so decided to get some for the Honda. Loads of different types on tirestickers.com but settled on Yokohama Advan being a Japanese  bike and all.
I have the Advan stickers to add on the opposite side of the tire, so far so good.
2 people like this
Share this post
Link to post
I decided I like the factory chrome look so I added genuine Honda indicators to replace the old rusted out ones. I painted the triple tree and handle bar mounts in VHT Epoxy satin black. Slowly getting this bike tidier.
Now these bikes are know for their charging systems being weak, a common mod on these is to remove the old regulator and the rectifier and replace it with a modern 2 in 1 regulator/recifiter unit.
Got started pulling out the wiring and noticed it was pretty rusty round the battery holder so that all came out for a freshen up. Can see the factory regulator tucked under the bottom of the battery tray.
All removed
The original regulator wiring is left disconnected in the loom. The original rectifier (orange fins) is removed and the wiring for this is used for the new regulator/rectifier unit.
Yellow and Pink wires are from the alternator, green is earth and red is positive.
Cleaned up the battery holder, stripped to bare metal and gave it a couple of coats of epoxy paint. Luckily the new regulator/rectifier bolt holes almost lined up to the original regulator holes on the bottom of the battery holder. A quick file to slot the holes and bam fits mint. Added some super seal connectors for reliability and bolted it all back together.
Gave it a polish, as it stands now:
4 people like this
Share this post
Link to post
Been working on a couple of my mates bikes over the past year too. Massive amount of effort went into getting this 1971 Triumph running again.
Started off life with looking alright with chrome, metallic blue and white scallops. But yikes underneath was a different story, fuel tank was so rusty it leaked fuel on one ride ruining the factory blue paint, cooked no less that two Pazon electronic ignitions before we completely replaced the wiring loom. Positive earth wiring really?
New carbs, cables, shocks, tires, etc....
Boom, cafe spec.... runs good now! 650cc 4 speed, but my, such a brut to ride with so much torque on tap.
Also did some work on a 250 Honda Superdream, I really like this bike, sits low and has those sweet Comstar wheels.
5 people like this
Share this post
Link to post
Summer is finally here in London, been mint cruising round decent weather. She's been running good, super reliable.
She's getting a bit noisy in the top end so I'll get the cam chain and tensioner replaced for some peace of mind shortly. These motors apparently are notorious for their  chewing out their rubber tensioner wheels over time.
Got some sweet 78 Sprint glove for summer rides too, they have a lot of cool summer riding gear on this site, check it out: https://www.78motorco.com
2 people like this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
