ThePog
The Pogs 1980 Nissan Uncivil Ian - Discussion
74 posts in this topic
Sure am! Just here scouting this weekend but will be here permanently later in the year
2 people like this
Share this post
Link to post
interested to know how you are going to lift the roof? will it be fibreglass or steel etc? do you use the existing roof?
thought the grill looked similar to something else.
1 person likes this
Share this post
Link to post
I am going to use the existing roof, split it just above the guttering and just in front of the side door, so basically the last 2/3rds.
I reckon to weld a bit of box section in a ring sitting on the cut, that way it will tie in all the roof ribs, then the same on the roof part.
Then some box section ribs to give the lift spacing - this will be at least 550mm. The new vertical ribs will be spaced so that I can have sliding windows pretty much all the way along the lifted sides, cos that is where any standing will be done and I want to be able to see out. Ullrich Aluminium have a couple of bus sliding window sections that mean i can make whatever size windows i want, Richmond Glass can supply the toughened glass in the size I want.
Then I will just sheetmetal and fully weld whatever gaps are left. The front will be sloped over about 800mm and I will probably leave that bit of the cut roof at the original height so that there can be some internal shelving/speakers.
The main issue with this method is that the existing windows slope inwards slightly, a direct lift means the new upright ribs will need to be vertical for it all to match up which I think will bollox up the looks.
To get around this I am probably going to split and re weld the roof ribs in 2 or 3 places so i can give the whole roof a bit more curvature - this will bring the roof width in so I can match the lifted bit to the slope of the lifted portion, thus maintaining the rather sexy looks.
Probably.
Share this post
Link to post
I have a great idea!  A plywood special. My mate whipped up a creation for his family bus :-) I cant find a photo but I have it on a video I made of Hannah's Bedford Housetruck she built.
If you head to about 5mins in you'll spot it in all its glory.....
Share this post
Link to post
I am scared to look, there will be turbos, rotors and modgies involved I have absolutely no doubt.
1 person likes this
Share this post
Link to post
No modgies in the uk :-( well not that I know of.
But lots of cool old trucks etc in that video.
Share this post
Link to post
That Bedford was a perfect base for a housetruck, so much room...
I see what you mean about the plywood roof lift........but no.
Steel is the construction medium I like working with, andas it happens I am pretty well set up to build stuff with it.
Share this post
Link to post
Yep- I was a little amused by Gerome's creation. But it served the purpose of housing his family in a short space of time.
Share this post
Link to post
Also check out Comac for bus stuff like windows and what have you.
Share this post
Link to post
Yea I forgot about comac, I used to use them all the time for prototyping stuff for work.
The rack is a cert now, I just can't see why not to do it...
Share this post
Link to post
I'm enjoying this build. When I first saw the Cad designed and laser cut seat bases I thought REDICULIOUS!
And then realised that's exactly how I roll too :-D
Share this post
Link to post
Ha, it is just the easiest way to make shit accurately. It helps a lot to have cad, so not for everyone.
The dude with the laser in Nelson is my favourite man, I get all sorts of things made that way now. I don't know how I survived without him.
Share this post
Link to post
Who is this chap? And what sort of $ were those seats bases? The ideas are spinning in my head...
Share this post
Link to post
Paul at fabriweld.
I think he cut the base parts for $150+gst or thereabouts, it is cheap as anything really. There is no way you could get the same result by hand.
1 person likes this
Share this post
Link to post
Have you got any ideas on how to build the front of the roof? Just a bit of sheet thrown on would not do this justice.
Possibly another windscreen and post setup of a similar width vehicle
Or perhaps a NoseCone    -     http://www.nosecone.com.au/nosecone-aerodynamics/catalogue
Or this?
1 person likes this
Share this post
Link to post
Fuck that top bus is amazing! Is there more info on it kk?
And please paint a lion on the front of this dylan.
Share this post
Link to post
I might let the kids do what they want with the outside paint, I am way more interested in the underlying form of things.
I have been thinking about a window there, but it wouldn't be the best if there was a rack, although this does depend on the rack design. If I did anything it would be a splitty type arrangement, 2x flat windows.
I looked pretty hard at this when I was at the wreckers browsing windows and seats, the main issue is the steel around the window frame. In vans etc framing has an inner and outer sheet, and it spaces out pretty wide straight away from the seal for shell stiffness, and this makes it a bit harder to fit. I will go have another look tho, it might work out.
Share this post
Link to post
How to tell that Dylan has been welding.
Anyone that welds daily will feel my pain.
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
