UTERUS'S KP60 PANTAY DROPPER
danger
  • Replies 154
You can use the appropriate sized electrical flex for the outer seals. Put the join at 12 o'clock and use a dab of sealant at the join. Then only buy the inner seals. Maybe a new front cover seal and a bit of a clean then hey presto- rebuild for under $200-300.
While you're in there it would be rude not to run a few 6mm holes through just to the outside of the mark the corner seals have made...
