Sign in to follow this
Followers 0
jakesae101
Jakesae101s 1985 mazda 323 rally car
33 posts in this topic
There we go
so in an effort to try keep some oil in the engine and not over my driveway / new shiny bits I chucked a new cam cover gasket in
I also fitted some side stone protection made from some industrial belt material i have had that was for my other car
its finally feeling like im getting towards the end now the list is getting smaller and smaller ive ordered my linkage so hopefully ill be able to report back after a test run this week
3 people like this
Share this post
Link to post
Got my linkage and fitted it had a few issues and took quite a bit of fiddling to get it right including grinding the throttle wheel tab to get the idle down and shortening the return spring ect but in the end it all worked out just wayy more of a faf round than i thaught . Went to pick a part today and grabbed a newer coil that had a bracket as the old one was cable tied to be held in place in clearly the wrong bracket owell.
for some reason none of my video links are working ill try to fix them later but it idles ect now
https://youtu.be/vXEz4ZKxa8I
https://youtu.be/KAodGSoZxGE
2 people like this
Share this post
Link to post
so not much has happened just tackling some of the small jobs and fixing some shitty wiring
Ever since I got the car it seemed to take forever to warm up but the fans would come on since my sender was in the top hose and the fan switch wasn't I figured the thermostat may be stuck shut and it was when I tested it so , New thermostat , radiator cap and gasket went on. I also tidied up some wiring as the terratrip had a 15 A glass fuse in it and had those shitty push in holders I hate as they can cause bad connections so put in 2x new blade fuse holders and the correctly rated fuses. wired it up some dash switches to power the terratrip and intercom and the intercom seems to work but I need to buy some headsets to test it. Bled up the cooling system and sits rock solid at 180-190 deg F with the new thermostat and doesn't take long to warm up from cold.
05A91E90-B352-421D-AB1E-D7A15CD1C0B0_zps
970D7E74-68E9-4D35-8356-332C038616B8_zps
2 people like this
Share this post
Link to post
So progress haven't had much time to work on the beast with the house renos taking my time but ive taken a break and with some fine weather tackled some jobs.
so put new rollcage padding in and some new 6 point harness
CFE7FCB1-167C-435E-8CF2-9521AFD1B303_zps
put in a 1.5 and a 1kg extinguisher in the car to meet requirements
2B3DAC11-9C3A-446E-BF93-B11E332C7565_zps
and when i got the dcoe 45 off Blizzo he had washed the filter in petrol K&Ns don't like this and they shrink and go hard as you can see a bit of a difference
13313703_10153446897851890_1256443294_o_
fitting it is a challenge as you can see its a wee bit tight for room
13295315_10153448352766890_1717806377_n_
did a bunch of little bits and pieces like fix the washer jets so they spray in a useful place and clean the connector to the wiper motor so they would work properly , also sealed up a few firewall holes, greased the front caliper sliders , replaced the 2 mismatched ht leads, replaced a dodgy hose clamp and fitted a factory expansion bottle that i got from pick a part to replace the random one that was just sitting loose
13289038_10153448371701890_846505579_n_z
Share this post
Link to post
so progress has been a bit slow with shitty weather ect
but i have got some things done i brought a monit trip meter as it came up cheap got it all mounted up and on.
425D5223-161B-4F30-A9E9-81BA2064E224_zps
now when i came to calibrate it it was showing no pulses for the terratrip probe in the gearbox i had had an issue once with the old tt2 but i put it down to wiring and re terminated the sensor on the back and it was sweet as. But this time i was getting nada and a new one is just over 90$ so in the words of AVE on youtube ya cant fuck it anymore so i took it apart and found the  orange cable had broken where it enters the potting for the sensor i removed the potting (and broke one leg off the sensor and resistor) so i ordered some 1k resistors and a honeywell ss41 hall effect sensor for a total of $2.70 with free shipping
this is what i found the cable was all cracked too and looked like it had been soldered by a 5 year old
19673B39-350F-4BE6-B416-B66AE0D57769_zps
nice new bits
8B919911-3CAC-4D32-9CDA-461FF90C59A2_zps
and all back together
C235D962-AAF3-495B-9CC8-3EB28B8EBEFA_zps
tested it today after taking the axela round the block to mentally mark some distances
BF3729A3-F416-45E8-A2D3-8FB4BB01E43A_zps
SUCCESS saved myself 80 odd dollars in the process
I also fitted a shaft stop on my linkage as my return spring being on the angle it was on kept sliding the arms on the pivots , fitted a new gearbox mount and a colder range set of plugs that were NOS obviously as i havent seen that packaging in years
502174D6-D80E-411B-BD05-3135D6071B99_zps
E95D163F-3FA2-40E5-AE3B-1A6FE2AC7BD8_zps
1 person likes this
Share this post
Link to post
sooo close to the end now been doing a whole bunch of tidyup stuff thats not noteworthy
after a talk with webber specialties he gave me some jetting advice on, when the carb was on blizzos car the jetting was
55 F8 idle
F11 emulsion tubes
125 mains
170 air correctors
his recommendations had the full setup but
50 F9 idle jets
F16 emulsion tubes
150 mains
180 air correctors
this was about 190$ worth of changes from nz and well that was just a bit too much for me this week so i got them in from the uk 105$ and was here in under a week
85EAC032-ADD2-4148-BEDE-D72994A8E839_zps
I had had a hard starting issue with the new plugs from cold and a stumble when blipping the throttle and i couldn't tune it out,
after talking to a friend that is much better at tuning carbs than me he asked my why i was still running my vac advance and that that could cause my issues with the stumble and just set it at 10deg at idle , so I changed my old plugs back today and found I hadn't tightened no4 so that is probably the hard starting issue haha . So today I removed the vac advance and tgb lent me his timing light and it was pretty much bang on 10 deg needed to wind in a bit more fuel as it was popping a bit so that was fine idling at 1100rpm quite fine (it isnt that smooth with the cam under that ) and the throttle response is much better than before . I have a lambda link afr gauge and a copy of a bosch lsm 11 semi wide band sensor to go in that ive had kicking round for years .
364D50A9-F99F-404B-A06E-4C0A2A9EFFAE_zps
2B0B50C5-9CA6-4879-9DB6-A090CB62A812_zps
so here is the result of todays efforts
1 person likes this
Share this post
Link to post
so been cracking on with a few small jobs . A few weeks ago Blizzo commented on Rhyscar's facebook page showing some 3d printed trumpets so iI contacted the guy they were cheap enough to take a gamble on so I got a set.
this was about half way through sanding them smooth
6AA167B5-D929-4CE0-BB5C-025F3E49E05A_zps
AE022F7E-7EEF-4620-9DE8-CB3ED2DF0F84_zps
as you can see they fit nicely I also modified my air filter housing to have bolts right through to make it much easier to get the element in and out and the housing back together I also made some cable tie ignition lead holders to tidy up the engine bay and cable tied all the loose wiring that was in the engine bay
24B39DA4-CF70-4ADF-80F9-381633EB4CD4_zps
now last week while I was fiddling with some stuff I finally worked out what the snapped off switch by the drivers side door on the dash was it was for the fuel pump I had thought it was strange it had no switch  , So I moved that to a better place and put in a switch for the afr meter and a overide switch for the radiator fan just need to make up some labels at work . I also got my horn working that turned to to be the contact for the ring was a bit jammed up and it wasnt maing any contact so that is all working so I can get closer to getting a wof
BCFA598B-3814-486F-9149-A2CEDEFB7F6F_zps
1EFBAD5D-4432-4888-90F6-832F997B6822_zps
2 people like this
Share this post
Link to post
ok so wee while between updates I blame the crap weather we have had and a busy schedule things have slowly been happening. Manu is currently modifying my aframe to work with the car so i can tow it round.
I scored a bunch of bits off a guy I know that came off his old etude that he wrecked he was hording for that "one day"  he gets another that  that resulted in this happening much earlier than I expected they call it the vr4 conversion. Basically its 266mmx22mm vr4 mitisi rotors over mazda bfmp hubs that get machined to take the rotor over the top instead of bolted behind and then you use gtx calipers .
the rotors were almost brand new but needed skimming as they looked like they had sat in the sea but came up ok , the calipers are refurbished with new seals and the hubs had been modified and had longer studs put in the only bit I needed to get was some bfmp caliper bolts that weren't that easy to track down but I got there.
form this
73004ED2-7D7A-4ECB-932D-C1441A9472C6_zps
DFD0766A-481B-4898-8B16-138B25D8BD2B_zps
To this
50A5AF3E-D0E7-4E97-A7A9-AA95FC7236E5_zps
1E854EFE-78E2-45C5-BBC3-B5C8C5D0D128_zps
also scored a strut brace
97BAC774-D06A-4FAC-8050-12891FC60FA4_zps
While I was doing the brake upgrade I poked at a scabby patch that someone had put on and found a large rust hole so I was trying to find a patch panel from another car to make it much easier. I Hadn't seen one at pick a part in some time so I was trying a few other avenues and crustywhip said there was a KA laser at pick a part so I went down and liberated it of the section I needed it put up a good fight.
here's the patch ready to get cut up after i removed the spot welds here to remove the chassis rail its triple skinned here I dollied it back into shape after all the removal from the car and drilling it and cold chiseling it got a bit deformed
F7BE26B4-00A9-41D3-97FB-B766053C8296_zps
Once that bit of rust is fixed its ready to race took it for a test drive after doing the brakes and they make a big difference will be better when they have some quality pads in them and it was my first drive since rejetting the carbs months ago man it runs way better more mid range. Have to get my o2 sensor bung fitted so I can see what the afrs are doing.
Share this post
Link to post
sooo stuff has been happening I moved out from UJs place into a place about 5 mins from home that I can have both cars in so cue moving cars and putting in storage ect.
54BEFC91-E808-4A42-9AAA-568668570B03_zps
1F46EBC5-1328-44C0-8830-54AA5FCF7ACD_zps
6C158DF4-C401-41F9-88AF-AADA7CEA8C22_zps
so basically that has sapped alot of $$ however I did sell off a bunch of bits that allowed me to buy some stuff
025AABD9-195C-4C48-93AC-1518D61EE5FD_zps
4632CDFA-0D10-4BCC-B724-D7CC3BC0C882_zps
Randomly found this on yahoo Japan ummed and arrred about getting it then it became favorable $$ wise to bring it in its a 2.9kg chromoly flywheel (factory is 6.6kg im told) , And seeing as my clutch was almost at the end of its adjustment and the uptake was quite high I also purchased a new clutch kit and rear main seal.
B966407F-71AA-49D5-8B46-328ACD51AFA7_zps
Now last weekend when moving the car i noticed that the right rear drum was binding , now i never touched the rears because I didnt really want to mess with the drums but now had no choice i had suspected one wheel cyl was leaking anyway so I ordered new wheel cyls and had a set of new shoes in stock after buying them supercheap off trademe at the beginning of the year all up im about 45$ in as parts are super cheap.
Passengers side wheel cyl was stuck and not working at all and when I pulled the drivers side off the linings fell out they had come away from the shoes erm yea that will be that binding oh and the wheel cyl  was a bit stuck and leaking. Didnt get snap a photo stupidly of new gears in and just after I finished bleeding them the Coastguard pager went off so I haven't had a chance to road test it yet put pedal feel is much better.
58192C97-056B-4097-9D48-3B6753519C4A_zps
Ive signed up for the gravel sprint series next year so just need to do the following over christmas
Patch rust in passengers side inner guard
Replace flywheel , clutch and rear main seal
Replace torn outer cv boot
weld in o2 bung into exhaust and check afrs
waterblast the massive amounts of dirt out of the wheel arches and rear suspension
probably wont be road legal for the first round but wont be far off
1 person likes this
Share this post
Link to post
Right much like last year at christmas/ new years im getting stuck in after 4 days away over christmas i had to work 2 days before a 10 day holiday so.....
Thursday night i started to remove the box and swap over flywheel and jam a new clutch kit and rear main seal in whilst I had it all out to my surprise it has a puk clutch in it with a standard pressure plate the plates a worn ish so i chucked my new HD exedy clutch kit in.
D86F9455-1D91-418F-B9C7-5641E26BBB9F_zps
666F7D59-2C66-431C-B520-9FBE9D46453A_zps
9E7F3300-0ED0-49F4-835D-25C7AF5EF3DB_zps
all relatively painless turned a bit of 20x20 box into a flywheel holding tool a mate gave me a hand and all up it probably was abut 5-6 hours work , Certainly much easier than my ae92
revs up pretty fast the new flywheel is less than half the weight of the old one bum dyno suggests its a bit faster and now the brakes work its less sketchy
anywho todays job was tackling the last bit of known rust i cut it all out and patched it with the patch panel i had including patching up the chassis rail as it had rusted through both skins , all relatively painless skim coat of filler and some rust kill and underseal looks mint , with a authority card ect it would pass a wof now I hope.
from this
FA49B2D9-A400-4375-A426-02DAA7CBC744_zps
to this
17C83DA1-74C5-4C90-9FC2-EEA090590046_zps
truck bed liner stuff ive used looks shiny but will go matte when dry its a bit harder wearing than underseal  on gravel ive found and here's a short vid its quite revy now
th_A1BF3BDF-4EB4-4399-9963-063449C6E825_
Share this post
Link to post
Not much else has been happening really purchased another better A frame from Crustywhip have been trying to get it ready for the first round of the sprint series next week but have fallen short with the car being ready but me not so much with $$$ a bit short currently i need to get new overalls and resit my license as I let it lapse a couple of years ago
B9C40BBB-FE10-4228-BAE8-309C973A7033_zps
semi sorted my roof with some plastidip untill I can afford to get it properly done still a bit rough but it will do for now
C883E1CB-6B22-40EE-8D39-CD785DD21837_zps
E1004759-2398-4443-840C-3D58310E8969_zps
231A2215-2A4C-441E-9E96-511335D4370F_zps
Got the missus to give it a good scrub up whilst I was repairing her new mazdas broken window motor gear came up looking semi respectable if you dont look too hard.
0B499037-E270-4F15-BD24-DBDE2F2CC539_zps
basically ready to run now probably needs a jam on a dyno at some point to fine tune and I need to make up a bashplate / underbody protection it came with some thin as alloy plate so hopefully iI can use that for a template.
Share this post
Link to post
So not too much has been happening whilst I spent money on safety gear, Purchased a new Sabelt 3 layer FIA suit , Second hand hans sport 2 and a omp helmet and a headset for the intercom.
However I had been looking for some cheap 15s and a something to protect the engine bay area. Some honda type r wheels popped up on facebook so nabbed them and a mate was selling a 6mm alloy bash plate that was on his runix race car so ventured to palmy today and picked the wheels up in levin on the way. With the larger front brakes the track gets pushed out 6mm so the new rims fit perfect on the front but the tyres are rubbing on the strut body on the back so have to run some 5mm spacers to clear they will be for gravel tyres only anyway as cheap second hand ones only come in 15 or 13 inch.
5EB42480-8A31-430B-B316-8AE50542527D_zps
87BCBDCA-FC42-4AD3-A969-F7D4038FB0B0_zps
My mate also gave me a big bit of underbody plastic as he doesn't need it now his car is track only.
179A51C6-3B53-4B72-B15A-B9F3A403C03B_zps
Now I haven't done nothing in between updates 63Ragtop saw a momo benetton steering wheel at a tip shop and posted it in spam knowing mine was really rough I asked him to get it for me and send it down.
Now I never thought to look to see if my old wheel was legit and I never had the horn center on it  as who would copy anything so ugly its cool but turns out it was a fake!
4658C5D7-85D2-4681-BB90-9D614EE1425C_zps
I also installed one of these gizmos that gives me launch control and rev limiter easy to install and works really well and is easy to change
5 people like this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
