Guypie
Nominal's 1961 Morris Oxford Traveller
51 posts in this topic
Went away camping for a couple of weeks after the last update. Came back the day before anniversary weekend with the objective of finished the rust repair by the end of the weekend.
Just before we went away I'd noticed some rust at the back of the roof where the tail hatch hinges are. Not really sure why this area was rust, I guess a bit of water gets in around the hinge screws. Had to fix both sides.
Got the channels welded around the lower edge of the tailgate, and filled the remaining gaps in the bottom.
Painted inside the frame and the repaired outer skin.
On the final test fit I realised the shape was a bit screwed up so had to cut and re-weld the frame somewhat, then re-prime it before plug-welding the two parts together.
Took farking ages!
3 people like this
Share this post
Link to post
Filled the hole at the back of the guard. The shape is a little off but I was in a hurry and it is mostly behind the bumper.
Before
After (1/2 way anyway)
Next up was the drivers side floor which had a few holes.
New floor bit. Had to do this twice as I got the swage orientation all wrong the first time. Swage made on the Nibbler with some home-made dies.
3 people like this
Share this post
Link to post
The driver's side sill and underfloor structure wasn't as bad as the passenger side, despite the holes in the floor.
Patch panel bent up. It was much easier to fit this side with the floor section removed.
The outer panels were 'good enough' to weld back in (saved time too)
Sprayed etch primer in all the repaired areas.
So, all the welding was done by Monday night about 11:30 pm.
I had to pick up some wheels from Island Bay on Tuesday and didn't get home until later. Had to reassemble the front (bumper and grille), rear (gas tank, fuel pump, bumper, upper and lower tailgate, and number plate light) and finish the brake lines before a WOF check on Thursday.
Managed to get through all this by late Wednesday (got my son out of bed to help with the bumper bolts even).  Bleeding the brakes was a pain as usual - I'd missed tightening one line fitting so ended up with a mess on the floor.
Quick test run at about 11pm, then gave it a quick hose to allow testing the wipers and stuck it in the garage for the local mechanic to pick up on Thursday.
4 people like this
Share this post
Link to post
WOF man picked up the car on Wednesday, and had a few issues with the column change. I haven't driven it much yet but the plane change between 1-2 and 3-4 seems problematic, and seems to hang up somewhere.
Anyway, failed on the following:
- Windscreen washers non-op
- Exhaust leak at manifold/exhaust pipe join (I knew about this but ran out of time to fix it)
- Upper tailgate loose (needs washers under the bolts)
- Leaf spring shackle bushing shagged
- Fuel tank leaking
- Full set of tires.
Also it ran out of gas on the way home so the mechanic had to walk back to our house to get his car - oopsy.
I had a look at the windscreen washers and I can't really see how they were set up originally. I though it would be a manual pump (that's what the owner manual suggests) but I can't see that there was ever one fitted. I have a pump tank hanging around, or I might remove the whole setup as they are not required on pre-1992.
I had only noticed the tank leak when I put it back together this week, so pulled it out again. There must have been water sitting between the tank bottom and the inner floor as there were a few pinholes to address.
Broke out the soldering gear. Haven't refilled it for a test yet, but should be OK.
Also pulled the shackle from one side. Hopefully I can get some bushes from BNT today.
7 people like this
Share this post
Link to post
Wowed the Oxford wagon foamers at British Car Day.
Got a couple of contacts for parts, including one who has a Aussie 6-cyl Freeway wagon stashed away.
Also walked pickapart for awhile to find some 185R70 tires for the back which should help the gearing/looks a bit.
4 people like this
Share this post
Link to post
Plenty of room for important cargo.
5 people like this
Share this post
Link to post
Replaced the manky rubber spacer bush in the column shift cross-shaft linkage with a short piece of heater hose. Hopefully this will prevent it falling out again.
Also got an original brochure from the UK ebay.
Quality First - nice to know.
Moore power!
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
