Connor
Neal's Triumph PI Wag
53 posts in this topic
six on the floor.
Nah..doesn't work eh.
He could remove the 1st/2nd OD limit switch and be...
Eight on the straight!
2 people like this
Share this post
Link to post
55 minutes ago, yoeddynz said:
six on the floor.
Six on the stick?
1 person likes this
Share this post
Link to post
Hey Neal!
Nice score.  at least the body is tidy as fuck mate. looking forward to seeing this progress
rad
2 people like this
Share this post
Link to post
Leaks on the floor? As a possible new name?
Nice wagon btw. I like wagons.
4 people like this
Share this post
Link to post
The old Triumph six can still sound like a boganmobile when it's howling.
Share this post
Link to post
Plus there are a couple hooning about my region that are definitely Bogan spec.
But not mighty wagons..
1 person likes this
Share this post
Link to post
11 hours ago, Kiwibirdman said:
When is threeonthetree going to become 4speedOD?????
Time for a name change Neal now that you have swapped the bogan holdens for the British stiff upper lip.
Based on the interest in a name change, this may have to become a vote for all of OS to partake in.
I still have two three on the tree Holdens left but not sure on how long that will be for.
Share this post
Link to post
Neal-TrPIS
triumph PI sport
pronounced
nnnnnnnneeeeeeeeaaaaaaarrrrlllll   TTTTRRRppppptssssssss
Share this post
Link to post
Thanks to all those interested. I will try and take some more photos when I am next at the shed where the car is kept.
I've always wanted Wagon Time so this is ideal. The goal is Wagnats 2018 which is plenty of time for a refresh, WoF and some miles under its belt.
In the previous videos it sounded like it never quite ran right. I'll go through and thoroughly check the fueling system from the tank to the injectors. It still runs the original Lucas 'wiper motor' fuel pump so binning that is near the top of the list. Also the fuel surge issues below quarter of a tank will need to be addressed. I am thinking of a lift pump into a swirl/surge tank and then a better primary pump to send the fuel to the metering unit.
The car has been run for quite some time without any filter, plenum or cover over the throttle bodies so it's filthy on the intake side. All sorts of shit has gotten into into the throttle bodies. The injectors are leaking and the metering unit looks like it hasn't been touched in a long time. All straightforward things that just need time spent on them.
Following @BLIZZO's advice, I'll be replacing all the seals in the injection unit as this is one of the common causes of issues with this system.
1 person likes this
Share this post
Link to post
Good stuff man,  loved my mk2 wagon (the white one Conner started his build thread with). Such an odd ball shape, all the barrys be swooning.
1 person likes this
Share this post
Link to post
John still has those motors, he is on the shore now, you might be able to get them alot cheeper?
A cople of my triumphs had bearing problems, one did a hell clatter till it got some oil pressure, the other just had a regular heavy knocking from one rod bearing, it was driven all over NZ like that for years
Share this post
Link to post
John wanted stupid money for his engines so I don't think I'll bother dropping in to see him.
This engine has always had the standard cartridge type oil filter fitted and coupled with the age, is a bit rattly. But since the engine is coming out it will get dealt with.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
