ProZac Posted January 10, 2016 Share Posted January 10, 2016 Have just been reading your build thread, really really enjoying seeing someone put some development time into one of these engines. Did you ever manage to find a rocker arm? I've got many if not, and I'm local(ish) . Quote Link to comment Share on other sites More sharing options...
ToMitz Posted January 17, 2016 Author Share Posted January 17, 2016 Have just been reading your build thread, really really enjoying seeing someone put some development time into one of these engines. Did you ever manage to find a rocker arm? I've got many if not, and I'm local(ish) . Cheers man, Im really enjoying putting the development in. I ended up finding a set of rocker arms from an old mirage which have the same ID for the shaft but a different geometry which is going to suit my aggressive lobe design and reduced basecircle size even better, bit of a lucky find at pick a part so I will be running those. Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 17, 2016 Share Posted January 17, 2016 Yeah this is cool. "292 degrees advertised and 13.5mm" is what i had on a cam with this engine. Bigfoot has it in his lancer now. Was a good cam. Plenty more top end and was still perfectly drivable and didnt drink fuel. Quote Link to comment Share on other sites More sharing options...
ToMitz Posted January 19, 2016 Author Share Posted January 19, 2016 Yeah this is cool. "292 degrees advertised and 13.5mm" is what i had on a cam with this engine. Bigfoot has it in his lancer now. Was a good cam. Plenty more top end and was still perfectly drivable and didnt drink fuel. Nice, any photos or build thread for this engine? Quote Link to comment Share on other sites More sharing options...
fengqiu Posted January 29, 2016 Share Posted January 29, 2016 Oh man, there's this really mint sigma up at zebra. body work is perfection, maybe if you need any parts and ask nicely somebody will help out and send some parts down your way Quote Link to comment Share on other sites More sharing options...
ToMitz Posted January 31, 2016 Author Share Posted January 31, 2016 Oh man, there's this really mint sigma up at zebra. body work is perfection, maybe if you need any parts and ask nicely somebody will help out and send some parts down your way Mean!, I've been really struggling to find a suitable one for parts. I would be super keen, mostly on annoying little pieces of trim like window wider handles and door lock knobs if anyone is heading out there with a spare container one day pretty please Quote Link to comment Share on other sites More sharing options...
fengqiu Posted January 31, 2016 Share Posted January 31, 2016 Mean!, I've been really struggling to find a suitable one for parts. I would be super keen, mostly on annoying little pieces of trim like window wider handles and door lock knobs if anyone is heading out there with a spare container one day pretty please I managed to nick the dash and gauges off it thinking i could fit it in to my car. though... now looking at the size i think it's highly unlikely , not sure what i'll do with it. oh yeah all the trims, windows, etc is in top condition, I'll give you a buz next time I go and if it's still there you can tell me what you need Quote Link to comment Share on other sites More sharing options...
ToMitz Posted January 31, 2016 Author Share Posted January 31, 2016 I managed to nick the dash and gauges off it thinking i could fit it in to my car. though... now looking at the size i think it's highly unlikely , not sure what i'll do with it. oh yeah all the trims, windows, etc is in top condition, I'll give you a buz next time I go and if it's still there you can tell me what you need That would be great. Ill flick you a message with my phone number to make it easier. What vehicle were you planning to put it in? Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted February 2, 2016 Share Posted February 2, 2016 I think you need to cut the springs and widen the steels on the wagon asap! 2 Quote Link to comment Share on other sites More sharing options...
rxtoy Posted June 10, 2016 Share Posted June 10, 2016 Before you start swapping mounts over check that the L200 centre won't fit in the stock housing. When I was diff hunting for my EX lancer back in the day there was an unconfirmed rumour that L200 ones fit Quote Link to comment Share on other sites More sharing options...
MaxPower Posted June 10, 2016 Share Posted June 10, 2016 Before you start swapping mounts over check that the L200 centre won't fit in the stock housing. When I was diff hunting for my EX lancer back in the day there was an unconfirmed rumour that L200 ones fit have herd that may work on the early L200 diff nugget into sigma wagon centres , also have never seen a old model L200 with an lsd. FYI your wagon should have the stronger 'ten bolt diff' Quote Link to comment Share on other sites More sharing options...
ToMitz Posted June 10, 2016 Author Share Posted June 10, 2016 Before you start swapping mounts over check that the L200 centre won't fit in the stock housing. When I was diff hunting for my EX lancer back in the day there was an unconfirmed rumour that L200 ones fit I was hoping this would be the case but it is not so. You may be able to tell in the photo, probably not due to crappy quality but the l200 diff is alot bigger. Wont even come close. Quote Link to comment Share on other sites More sharing options...
ToMitz Posted June 10, 2016 Author Share Posted June 10, 2016 have herd that may work on the early L200 diff nugget into sigma wagon centres , also have never seen a old model L200 with an lsd. FYI your wagon should have the stronger 'ten bolt diff' Yeah i haven't found any LSD that will drop into the stock, smaller housing. currently tossing up between cutting, shutting and welding axles and housing to create a mix up or simply using the complete l200 axle and running 6 stud on the rear. Quote Link to comment Share on other sites More sharing options...
MaxPower Posted June 10, 2016 Share Posted June 10, 2016 is there not a way to get the 6 stud ute axles down to 4 stud mitsi? what do they do to the hilux diffs in corollas etc? I was pretty keen one day to make a jig to shorten L200 diffs into sigma size Quote Link to comment Share on other sites More sharing options...
ToMitz Posted June 12, 2016 Author Share Posted June 12, 2016 is there not a way to get the 6 stud ute axles down to 4 stud mitsi? what do they do to the hilux diffs in corollas etc? I was pretty keen one day to make a jig to shorten L200 diffs into sigma size I have no idea what it is going to take at this point, i am completely winging it buying this diff. I will let you know if the axles fit or anything easy like that but im expecting it to require quite alot of customization. Quote Link to comment Share on other sites More sharing options...
ProZac Posted October 3, 2016 Share Posted October 3, 2016 In a completely non creepy way, I feel like you and I should be friends. . Super interested in what you're doing with the spark computer. I put some time into a crank / cam trigger setup for my Starion motor a while back, with the aim of having it all hidden behind the factory covers, and completely deleting the original distributor. Got as far as making the cam trigger setup, but needed some machinery I didn't have to get further. I should really pull it back out and continue with it. 1 Quote Link to comment Share on other sites More sharing options...
ToMitz Posted October 4, 2016 Author Share Posted October 4, 2016 In a completely non creepy way, I feel like you and I should be friends. . Super interested in what you're doing with the spark computer. I put some time into a crank / cam trigger setup for my Starion motor a while back, with the aim of having it all hidden behind the factory covers, and completely deleting the original distributor. Got as far as making the cam trigger setup, but needed some machinery I didn't have to get further. I should really pull it back out and continue with it. Yeah man will have to grab a beer or something at some point. Hopefully the little speedunio computer will do the trick. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted October 13, 2016 Share Posted October 13, 2016 I do like the 80's NZ Mitsi colours, but that green, not so much. But if you dig it thats all that matters. Are you keeping the same green on the outside? If so, id keep the same colour on the outside in the engine bay. This thing is going to look great no matter what colour it is Quote Link to comment Share on other sites More sharing options...
ToMitz Posted October 13, 2016 Author Share Posted October 13, 2016 I like them too, Yeah i dig the old green. Need to get a pot of the original colour for the outside anyway so might just use that. Quote Link to comment Share on other sites More sharing options...
Kc'sEX Posted November 7, 2016 Share Posted November 7, 2016 I love that green! ive owned a few of these sedans and this is the only one i have seen in this color, iv had blue, light brown, red, white, poo brown, orange but never green. id love to see it stay that way just because its so different to the other standard sigma colors. if your going shiny everything on the motor, a nice satin black in the bay looks nice as well though, brings attention to the engine. but awesome build thread and ill be watching it every step of the way! Quote Link to comment Share on other sites More sharing options...
