Sams Lada 2104 Wagon.
Have you got a workshop manual for it? I can send the niva engine section to ya, should be the same if it helps?
Can you get a mirror down to see the condition of the tension shoe? they too can wear out and get noisy
I've managed to re use them, needle nose pliers.... but I've also replaced the lot they're retarded!, including the ones on the brake reservoir....
My radiator always leaks, had it recoed a few times too, found I just have to reflow that top hose occasionally, leave the cap loose or cut the springy seal doofa out so it can't pressurise, they don't seem to like the pressure too much!
