RUNAMUCK Posted May 18, 2017 Share Posted May 18, 2017 Every single six cylinder Val I've ever had which has had headers, and an iron inlet manifold/factory carb has had an off idle stumble created by the loss of the warming from the hot box. On at least two cars I replaced the headers (to be fair they weren't super flash ones) with the factory iron zhorst manifold. Quote Link to comment Share on other sites More sharing options...
hellnback Posted May 18, 2017 Author Share Posted May 18, 2017 Yeah I've heard that but haven't experienced it myself except my brothers old VJ had a huge flat spot we couldn't quite get rid of. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 18, 2017 Share Posted May 18, 2017 It's a total ball ache for making small gaps in traffic. Mash pedal, bluegh-vroom. By which time the small gap is even smaller..... Quote Link to comment Share on other sites More sharing options...
grunta Posted May 19, 2017 Share Posted May 19, 2017 this is worth a look... http://www.hotrod.com/articles/slant-sickness-add-77-hp-mopar-slant-six/ 1 Quote Link to comment Share on other sites More sharing options...
hellnback Posted May 22, 2017 Author Share Posted May 22, 2017 On 5/19/2017 at 12:00, grunta said: this is worth a look... http://www.hotrod.com/articles/slant-sickness-add-77-hp-mopar-slant-six/ Read that on facey - fuck yeah, shame the head gasket blew - wonder what it would have ended up as. 1 Quote Link to comment Share on other sites More sharing options...
1963 AP5 Posted May 22, 2017 Share Posted May 22, 2017 Yep can confirm that you can have problems when you take away the manifold heat with a std carb, especially in colder climates. Dad always said that headers make bugger all difference when fitted to an otherwise standard engine and you are better off with the factory exhaust manifold. It will however sound way cooler with the pacemakers! I have heard of people adding a water heated block where the factory exhaust manifold bolts up under the intake manifold to help add the heat that the carb wants. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 23, 2017 Share Posted May 23, 2017 On 22/05/2017 at 17:34, 1963 AP5 said: Yep can confirm that you can have problems when you take away the manifold heat with a std carb, especially in colder climates. Dad always said that headers make bugger all difference when fitted to an otherwise standard engine and you are better off with the factory exhaust manifold. It will however sound way cooler with the pacemakers! I have heard of people adding a water heated block where the factory exhaust manifold bolts up under the intake manifold to help add the heat that the carb wants. I actually tried this. I still have the block somewhere. Iirc the hotbox flange on the bottom of the intake had to be milled flat before it would seal. 1 Quote Link to comment Share on other sites More sharing options...
1963 AP5 Posted May 24, 2017 Share Posted May 24, 2017 6 hours ago, RUNAMUCK said: I actually tried this. I still have the block somewhere. Iirc the hotbox flange on the bottom of the intake had to be milled flat before it would seal. Did it have any positive effect? I have been told that a lot of inline 6's with a carburetor actually benefit from having a functional heat riser. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 24, 2017 Share Posted May 24, 2017 I don't remember. I removed it because it had both heater hoses Going in and out. So I got no flow through the heater. Being cold su ks worse than a flat spot. 3 Quote Link to comment Share on other sites More sharing options...
Toddy415 Posted March 20, 2018 Share Posted March 20, 2018 Seen this at new world with the seats on top had heaps of people checking it out haha 1 Quote Link to comment Share on other sites More sharing options...
