HKM400
HKM400's 1969 Lotus 7 Series 3
90 posts in this topic
Surprised at lack of comments here. Keep up the build thread.. It's a good read!
I wouldn't be too harsh on them for brazing things. I could be wrong BUT I do believe even Frazer cars braze much of the frame for a few reasons.
1 person likes this
Share this post
Link to post
Awesome man, I always wanted to build one of those
How loud was too loud with that exhaust?
I had plans on doing a setup like that, but if its just ridiculous ill have to rethink
1 person likes this
Share this post
Link to post
Yeah I have seen Frasers with it done, and they are good solid cars, the guy welding my frame up had to chop a fair bit out anyway so welding was his preferred option. Hopefully mine will look half as good as a Fraser, some awesome ones out there.
Share this post
Link to post
As for the exhaust, it was running inside the garage so made it a bit louder, however I did have to put ear protection on and it was only idling... Was a lot louder than my friends Subaru and that has a 3 inch pipe off the turbo all the way back, and a 4 inch muffler with no silencer. Needless to say the wof man may take interest...
Share this post
Link to post
Haven't done much to that, but it is going to be taken apart after this one is finished, motor needs a rebuild, or maybe a V8. That would solve it nicely
1 person likes this
Share this post
Link to post
Very cool little car- what are you doing with the old alloys? Dunlop D1s = Yummy!!! I presume they are a ford stud pattern.
Share this post
Link to post
Wheels were indeed standard Ford 4 studs, sadly I sold them on trademe last year, probably to another oldschool member. Needed some funds to keep the project going
Share this post
Link to post
Good work man.
FYI Braising is the best method for joining tubes on a chassis, as you don't end up with HAZ that you get from welding which means that on a road car you are much less likely to crack it. And rivets are also legit, as they can't vibrate loose which you might find your screws do.
Share this post
Link to post
Makes sense, I guess the harder areas to get in with the welder are easier to access with braising. Plus there a few bits left in there which were strong enough as is. A few rivets have gone back in, just in much fewer numbers! Also wanted to make panels easier to remove without the use of a drill bit.
Cheers for all the comments guys
Share this post
Link to post
If it is reg on hold then yea just get a wof, they won't have any idea what they are looking at so it will be fine, then just change WOF shops as you do more mods to the car so they aren't familiar with it. It is the done thing in the lotus 7 world.
1 person likes this
Share this post
Link to post
The panels have been stuck on with adhesive and also have rivets holding them in place, also screws for ease of removal. Are they really considered structural? The chassis is braced throughout the front and sides of the car, the side panel is really just a covering being a thin sheet of aluminium. Are they considered to add significant structure? I guess they would serve a purpose of slowing objects down in a side impact but really the chassis will be taking the bulk of the impact?
Share this post
Link to post
The glued aluminum panels provide most of the stiffness to the chassis.
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
