Greenie Posted November 8, 2014 Author Share Posted November 8, 2014 ROLLS ROYCE?!? yeah, dads got two and grandad has two, plus all their other cars.. they're a bit obsessed tbh Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 8, 2014 Share Posted November 8, 2014 Greerton spring makers will reset leaves for $250. Quote Link to comment Share on other sites More sharing options...
Greenie Posted November 9, 2014 Author Share Posted November 9, 2014 oh cheers man! ill look into it Quote Link to comment Share on other sites More sharing options...
Mof Posted November 26, 2014 Share Posted November 26, 2014 Hey you got those indicators sorted yet? Check the bulbs. Sometimes when they blow they short out. Also the flasher unit can short out when it fries too. But your sparky should know that Quote Link to comment Share on other sites More sharing options...
Greenie Posted November 26, 2014 Author Share Posted November 26, 2014 Hey you got those indicators sorted yet? Check the bulbs. Sometimes when they blow they short out. Also the flasher unit can short out when it fries too. But your sparky should know that nah not yet, the sparky recons its the relays have shored out so he just got new ones from pick a part and have just got to put them in and put the rest of my dash back together Quote Link to comment Share on other sites More sharing options...
Bistro Posted November 27, 2014 Share Posted November 27, 2014 looking goot, what tyres are you going with ? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 27, 2014 Share Posted November 27, 2014 Looking good man Giz a yell if you want a hand to crank down the torsion bars and make the front bump stops better Quote Link to comment Share on other sites More sharing options...
igor Posted November 27, 2014 Share Posted November 27, 2014 I'd love to cut a Rolls Royce into a ute. Quote Link to comment Share on other sites More sharing options...
Greenie Posted November 29, 2014 Author Share Posted November 29, 2014 looking goot, what tyres are you going with ? the tires i got where 185/60/R14 and i think the look perfect. and thanks everyone. I'd love to cut a Rolls Royce into a ute. hahahahaha that would be ridiculous. but sick haha Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 30, 2014 Share Posted November 30, 2014 You will be surprised how much the wheels will pull in once you give the torsion bars a good tweak. Does this have plastic inner guards? Those are the part most likely to rub when slammed and the body loom can hang a bit low on the drivers side so it pays to check where it sits then pull the guard off to lift it higher if need be Quote Link to comment Share on other sites More sharing options...
Greenie Posted November 30, 2014 Author Share Posted November 30, 2014 You will be surprised how much the wheels will pull in once you give the torsion bars a good tweak. Does this have plastic inner guards? Those are the part most likely to rub when slammed and the body loom can hang a bit low on the drivers side so it pays to check where it sits then pull the guard off to lift it higher if need be nah there is no plastic inner or anything just the guard itself and then just all the suspension components. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 30, 2014 Share Posted November 30, 2014 Shouldn't be an issue then Looks sweet on those rims now they have been tidied up Quote Link to comment Share on other sites More sharing options...
Greenie Posted November 30, 2014 Author Share Posted November 30, 2014 yeah should look good when its lowered, yeeah they only took a day to clean up and paint, turned out better than i thought Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 30, 2014 Share Posted November 30, 2014 Measure how much clearance you have between the bump stop and the perch it contacts with as to how much you can lower it bearing in mind that you can trim the bumpstops and cut off the part they bottom out on trim it shorter and re weld it on to keep some suspension travel. Bring it over once its legal and we can have a play with adjusting them, it only takes about 10 mins to wind the torsion bars down to see how it will look and just the same to correct them back to normal height. Iv got a pair of drop spindles here too that havent been fitted to my lux yet that we could mock up and see if they do clear 14s which they might on those steelies because of the way the rear band steps down otherwise there is other options for getting the front of these hilux to sit low. Is it disk or drum brake on the front? Quote Link to comment Share on other sites More sharing options...
Greenie Posted December 1, 2014 Author Share Posted December 1, 2014 oh yeah that makes sense, ill try to get it legal this week if i have time to get the indicators working, then ill hit you up? itll be good to chat to someone whos done it before haha. but yeah sounds like a good idea and they are disks Quote Link to comment Share on other sites More sharing options...
HighLUX Posted December 1, 2014 Share Posted December 1, 2014 Yeah man sounds good Quote Link to comment Share on other sites More sharing options...
kseries.rookie Posted December 22, 2014 Share Posted December 22, 2014 Looking good bruff! 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 22, 2014 Share Posted December 22, 2014 also while you guys are here, this may seem like a stupid question but is it illegal for me to take tho factory mud flaps off the back tray? because they are ugly and i was just gonna cut them off if its legal for me too do so???? You can find the WOF rules for mudguards here The way I read it, you don't need mud flaps behind the tyre unless you have duallies. Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 22, 2014 Share Posted December 22, 2014 Yeah but kicking up stones to the car behind you is a cunt move too. Quote Link to comment Share on other sites More sharing options...
Greenie Posted December 23, 2014 Author Share Posted December 23, 2014 You can find the WOF rules for mudguards here The way I read it, you don't need mud flaps behind the tyre unless you have duallies. Yeah but kicking up stones to the car behind you is a cunt move too. thanks guys, i read though that page and all i gathered was it only needs it if the wheel will be exposed if ones not there, but considering that its still got the try to cover it i don't think i would be a problem, but i think i might just look and getting or making other ones that ill be happy with as appose to removing them all together. shot guys Quote Link to comment Share on other sites More sharing options...
