Roman Posted January 23 Share Posted January 23 Also its awesome how with VVT it just seems to absolutely nuke all of the downsides of a bigger cam. Quote Link to comment Share on other sites More sharing options...
kpr Posted January 23 Share Posted January 23 yup, I think it runs even better than the other engine on stock cams, which had the inlet advanced a little. its even fixed my weak starter motor. since the cam is pretty retarded at the zero position, it has less dynamic compression and turns over faster haha. from memory it has from 0 to almost 5mm lift at tdc. the recommended setting for that cam is 2.7mm at tdc 1 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted January 23 Share Posted January 23 2 oil caps because it burns twice as much oil as a normal 4age? Quote Link to comment Share on other sites More sharing options...
kpr Posted January 23 Share Posted January 23 one cap cant keep up. Quote Link to comment Share on other sites More sharing options...
Dudley Posted January 23 Share Posted January 23 Still doesn’t run as good as my freshly diy tuned carbs Quote Link to comment Share on other sites More sharing options...
Dudley Posted January 23 Share Posted January 23 And pictures of wiring plz Quote Link to comment Share on other sites More sharing options...
