KPR's 84 chromelux discussion
Stu
  • Replies 345
Pretty sure he said that one came out of a prado,  unsure what else has them.
fitted the hilux case no drama.  only thing i had to do is correct the pinion angle.  which gave it some sweet race car caster over factory. watch out oldshool track day, i'm gonna be passing you on the grass.
Those diffheads come from surfs too. It should have 4 cast ribs on the outside instead of 3 on your standard head? I've got a high pinion head in the rear of my lux
edit: or maybe I'm getting confused with 4 pinion V6 diffs..
Yeah your confused, 4 pinion has the extra ribs but some are different again with late model stuff because all the new stuff is 4 pinion and there are a few different castings
