Datsun280z's Datsun 280z
  • Replies 54
Started making some headway on the wiring. The original loom was in a pretty messy state due to years of people cutting and splicing not to mention my car having had a LHD to RHD conversion along the way. I have cut away as much of the old redundant fuel injection wiring as possible.
Front end done. Replaced a few of the old connectors and tried to route as neat as I can. All wiring now runs through the guard as wanted to try and keep the engine bay clean.
Engine bits finished. New 2G cable running to battery in the back of the car
Through firewall
I managed to score some sweet sealed 12V battery's from Craig260 to replace my old dead one, chur bo! These things are nice and small which is cool. One should do the trick but am going to use two.
Knocked up these guys to mount them
Decided to mount behind the rear seats, they just squeeze in there.
Been doing a few small things
Made up a rear strut brace out of an old R33 one.
Car had been struggling to stay cool when in slow moving traffic this summer with the alloy radiator I had fitted so upgraded to a bigger one and added double fans. Seems to have done the trick.
I have been using a Carter fuel pump I scored from my parts sponsor Craig but it has been dying a noisey painful death. Not only did it scream when operating but it was struggling to make the required pressure. Looked at different options and decided to give a kiwi company Fuel Flow a go. Their pump seemed to match the specs I need, is well priced and is made in NZ so worth a shot. The pump runs nice and quiet and is easy to mount. Good bunch to deal with too...
Here it is compared to the old Carter
Mounted to pump bracket
Will do some driving tomorrow to see how it goes...
  • 7 months later...
So I managed to score a z31 CLSD R200 with a NISMO center by a lucky fluke earlier this year. As far as I am aware it has a 3.7 ratio.
Ripped out the old 3.3 (I was told, will open and confirm) open wheeler. Only thing that needs swapping over is the front drive shaft flange as the Z31 one is different. Cool thing about this swap is the S30 stub axles plug straight into the Z31 CLSD center so it is a really easy conversion.
And the uni half shafts as they were looking pretty blue and shit. I actually have a set of Z31 CV half shafts I want to install to get rid of the uni's but I still have to suss out some adapters for that job so uni's stay for now.
I dont know what state the new CLSD is in but looked pretty tidy inside from what I can tell so best just to throw it in and see what happens
Gave the diff and half shafts a tidy up
Threw it all back in with some new oil and job done. Went out for test drive and nothing blew up, it is not overly noisy at all and seems to lock up OK. I tried to do a mandatory sweet skid but only succeeded in skidding up my shit house clutch so that is now on the list to get replaced stat.
  • Like 8
  • 7 months later...
  • 6 months later...
