XSVWGN's TT132 Corona wagon - 2jzge
DISCUSSION THREAD
Hey everyone,
I recently joined oldschool but have been trolling here and there for the last few years. As my turbo ae100 corolla wagon was nearing completion I spyed a bright yellow 1980 corona on Hustle Live and I had to have it. I parted with some stereo equipment and $400 and I went over to Wainui to pick it up.
As soon as I got it home I started stripping it down to see what I was going to be working with. Eye moved the driveshaft as it was banging around and I took the fixed backs out that were pretty much welded to the floor
Fuel lines running through the middle of the car.... Car was built for skid and originally had a RB20det in it
Front had been hacked up to fit a huge radiator and to clear room for the intercooler piping. The passenger footwell had also been smashed up with a hammer to make room for the wastegate to clear...
Turned out they welded the bumper to the car rather then put four bolts in..
Battery tray behind passenger seat
Removed rear windows and found rust so that was repaired
Crack in bog around fuel filler... As I removed it I realiser the fuel filler and surrounding area was rusty so that was cut out
Started pulling it all back
matt-rearpaneltobaremetal_zpsa6c9d4ab.jp
Started to regret pulling it all back as I found previous repairs and more and more rust
All the way under the dash it was like this. Has rusted through the rain gutter.... Now what do I do!!!
Found a guy on trademe with a sedan shell in his lawn. He cut the front end off and sent it up to me. Cost me $150 so I definitely can't complain. Completely rust free too. Well, surface rust but that's nothing. Was thinking about sticking this front on as it hasn't been molestered at all!
f11c52fb689d4591a0c5cdbb7b908531_zpsca9c
b454d35ba95d24f22f6ed26004faa164_zps3c94
Previous owner also took a hit in the front right hand side and this is how he tried to counter things...
7f3893324ac775bb7f9668e5d17274e7_zps545f
Scored a complete interior for $40 from a guy in Paeroa that wrecked a wagon he found in the bush.
f1bbd8dff449a097bfc5a5c706668b11_zpsddef
As I was looking on trademe another wagon popped up but it's a 79 (same shape) and it looked to be in much better condition then my yellow one so money was traded hands and freight organised and I got it transported from Christchurch to Wellington.
It has no engine but it was complete otherwise and it came on some 13x7hotwires with decent tyres too
cc593cdd1ab906f985c1740fa31f3585_zps7d0e
72d423c3219f4d46a3bf4cb0d37d1fcb_zpsea63
c0159ea985c54f1116c5074806396b10_zps1e19
I had now sold my turbo corolla so I went a bit mental buying parts...
2jzge - 82k, loom, auto gearbox, ecu -$700
d16f73e3df37fa7ab5ca8b179e88bdb8_zps62ba
a182f6a717d7f18eadf7ed48993ae5fa_zpsf179
Shortened hilux rear end set up for 4link
ddf1c15e0db165457a66123d5e5cc9c3_zpsc667
4ad618e258ac6144324cbd676e766533_zpsb1ec
Pulled these out of CHCH two weeks ago and got tyres on them yesterday too...14x7 Volk Racing Wheels
bf147d7f504d9381ec81cb4be2f1d99c_zps8d40
9bba905f047bf46917c85787f4725325_zps3489
Brought some Tanabe Subaru coilovers off trademe for $100 and started stripping them down to make my own coilovers. Remove the sleeves, springs, hats and camber plates and I will use them all on my setup. Camber plates are getting re drilled to suit my setup at the moment. I will drop the car a further 20mm by using the camber plates too as the standard top hats are really deep.
da8672c899967a5903c7e190cecfd0ac_zps2dd6
57cb1d6803525eb83fee31e109e9b34a_zpsd0f1
dba4ce29ac0ce702b0297f2ff3ac2482_zps05d5
Now following seedy Als post on coilovers I stripped my standard ones and cut around the bottom spring keeper
de3b95ca391148bf7d7ef24a917eddb5_zps5011
b08d9a714912fc4c871a36b0cd2a55f2_zps143e
1a32471419fe9cbf2963c2438737ad68_zps669f
I them brought some brand new Monroe ae92 corolla inserts that were 55mm shorter then original so the standard strut housing will be cut down to keep the new inserts captive
0c1a0589e491ca61e4bfc40775d7df36_zps7edf
Tidied up the struts by grinding off the rest of the bottom spring keeper
e91c934208d294476452d190d9a112da_zpsc3bb
Also brought some series 5 RX7 4pot callipers yesterday so they are on their way too so I will be looking into setting those up at some stage.
I'm really keen to run power steering in this rather then the steering box so if anyone has suggestions then thrown them my way. I have been told to look in an 86 powersteering rack and column and go from there. Sound right?
Over the weekend I got some work done on the corona. I picked up my struts and put my coilovers together. Huge drop in height from standard that's for sure and I have set them 7 threads up just to see how everything will sit.
9d877d6b5e0ac3642774cf6a203ccab2_zps7728
65b6ba42c10c3b94a682036eff76fd2a_zps685a
1f01df6d94e5fb153f063a0a94a11a91_zpse78d
I put them in the car and realised the camber plates will need to be re drilled....
0ca1b716f910aa5861bdbba0edd82eb9_zps1de8
Take into account there is no engine or gearbox etc and it is sitting at this height.
c00f789ca76045f42f8770bb18904b6c_zpsc02f
I then put her in the garage and next on the list will be to drop the rear end and see how my shortened hilux setup will fit.
95dabce95c6eab68630f50bee4a0ddac_zps05fb
I am also contemplating building some rear strut towers to run a coilover suspension setup on the rear rather then the normal shock setup. Just an idea at this stage.
Matt
  • 1 year later...
Well i havent updated this build thread in over a year and not much has changed really. Well i sold my wheels,sold the 2jz, sold my coilovers and sold the corona rear end too. The rear end now sits on a s13 subframe (not mounted yet) with plans to run s13 hubs, knuckles and adjustables up front.
I have wanted to get another 2jz for a while now so i can start playing around with mounting things and then this turned up on trademe for $700!!! Deregisterd but all i wanted was the engine. Managed to pull the engine out last Saturday and on Sunday a guy from palmy turned up and took the rolling body away for $550 so i was really happy.
Playing around trying to put the 2jz into the corona
So i picked up a 1ggte radiator for $200 recently and have that a go. As you can see there is NO room to run fans here and on closer inspection i may end up recessing the firewall to get some better clearance up front.
The other thing is that the sump sits on the sway bay so i will re think things and may run a custom swaybar setup
Thats all for now.
Matt
Had a chance to get into the garage again today. I got more carried away with tidying the garage then i did working on the car but i still got some stuff done. I wanted to drop the sway bar to see what kind of room i would have with the engine as the sump sits on the sway bar currently and then i realised that the caster arms and sway bar are all mounted up to the same thing so i ended up removing it all.
Sump sitting on the sway bar in this pic
Removed all of this. Will have to make some custom mounts for the caster arms
Front end is pretty empty
I put the radiator in to have a look at clearance and have market out what sections i need to remove. The whole bottom radiator support panel is going to need to be replaced as it is full of rust so i will end up having quite a bit of room.
Matt
Evening Everyone,
Today i got up to all sorts and the pics will reflect that. I also dropped my AE86 Powersteering crossmember to Spire Fabrication in Kapiti last week to do the mod that Sheepers has done. 40mm box tubing at either end and had it cut down on the ends to fit my chassis rails. I pick that up next week so im looking forward to getting that back and bolted into the chassis. The box tubing is to help drop the JZ down a bit as it is a really tall engine and it also helps sort the suspension geometry as well.
Love this bottom radiator support. The more i look the worse it is. Massive steel plate on the front and underneath there is another steel plate and heaps of bog!
Brought some s14 adjustables and they pretty much bolted straight in. I will be using a full nissan front hub assembly, s14 lower control arms and rxt 4 pots so its a bit of a mongrel
Also took some measurements as the 2JZ fits in the engine bay JUST and i cant run radiator fans so i am recessing the firewall to give me some more room to play with
Then i pushed it outside so that i could air out the garage from all the grinding smoke etc. Man its a pig thats for sure!!!
Matt
So i got carried away and brought some things from driftmotion.com. A bit of a rookie error on my part as i got stung $150 ish in freight from the states and then i got hit with $140 in duty when it came into the country so this radiator shroud and a few other little bits i brought now have turned into expensive parts but hey its all a learning opportunity.
I am VERY happy with the quality on the shroud and fans to say the least though :D MISHIMOTO!!!
11846473_10153591205116457_1820007970_n_
11868761_10153591204976457_1732810773_n_
11844057_10153591205051457_1626053364_n_
Matt
  • 1 year later...
Well when i got my 2jz it didnt have a water pump pulley and i had wanted to get the silver ones through driftmotion but the freight was going to be about $88 on their own so i got these ones from Aliexpress
6B916CDE-B9A7-4EF1-9C7F-DB366510F06D_zps
And here is an update of the S13 rear subframe conversion. Chassis rails got the cut to be able to build the strut towers
9E03B7E1-8A8A-40D1-B98F-458E185F404F_zps
7F3E5AAA-EE00-48CC-99EA-7B4084A2DBF9_zps
Front mounts made and tacked in
BD02C88B-C922-4420-9BBA-9DF1B7A64548_zps
Welded in and chassis rail notched
D9B16A8E-6D78-493D-BC92-498DD4705D87_zps
6D506EFB-0A1F-4F32-9F15-693930B732B7_zps
Rear Mounts folded up and in place
2F04F330-B4A5-4AFC-B37A-37F908111DF0_zps
57436D26-9E38-4133-919D-5D76E12A7999_zps
3A907715-46EC-4CBB-B299-F688CEC7323A_zps
Discuss here
Haven't updated this for a while. Car is on the rotisserie at home in the garage and nothing new has really happened. I did receive my individual throttle manifold from @evil_si (Simon at Max Fabrication) and to say I'm happy is an understatement. Looks awesome on the engine! Need to get it in the engine bay to see how much room I have for trumpets.
This manifold uses the standard 2jzge intake runners. They have been cut down and a 10mm plate was CNC'd. All throttles needed no modifying at all. Quite effective and didn't cost me the moon.
  • Like 9
