Seedy Al's 1981 Crown Sedan
SO.......... basically I couldn't help my self.
This came up for sale on here and I had to have it, becasue it was cheap, and I was going to where it was for sale anyway......
So the details.
is a 1981 NZ New Toyota Crown.
227000km on the clock
5m motor with auto, and thats about it really haha.
used to reside in napier, and came on these most yuck wheels, 14 inch 100 spoke wires.
From memory it didnt look to bad on these wheels when it was all slammed out, and it did come with the cut springs it used to have, now has some sort of aftermarket springs in it that have some how jacked it to shit?????
anyway, the story was when i bought it , it had an odd over heating problem. when i picked it up, it was running mint! drove it round napier for a bit with no problem.
come a few hours later and it randomly over heated..
Interesting, but basicly i topped up the water and drove it back from Napier to wellington, no problems. (although i did swap the radiator cap with another i had,)
Drove it round for a little bit, and noticed the temp was doing some weird things.
Got My lovely lady Mourning CupCake to take it to Alltorques work for a wof, failed on a spot of rust, exhaust leak, and brakes pulling to one side. not to bad.
Noticed at this point, that the water pump was original..... hmmm........ 227000km on  an original water pump........ good going, but whats the bet its fucked inside.
SO I started the hunt for a new one.
Then, one morning on the way to work, it mega over heated........
Yip, the head gasket is fucked now for sure.
So then came the fun stuff........ parked it in my shed and pulled it apart. its funny how quickly you can get things done with no distractions and a little no how. had the head off in about 40min. pretty happy about that.
Besides one thing........... sometimes, even as a trained mechanic, you still make fuck ups.
Mine was thinking that the reason the cam wheel bolt wont undo is because someone had fucked up the install at some point, however...... turns out they are left hand thread!!!!!!!! so I snapped it.
woops, a bit embarrassing indeed.
Moving on. I removed the water pump. Yip its fucked all right. I have no idea how I managed to get it down from napier. But im glad it worked.
Also found the blow in the head gasket. right on the back cylinder.
had the head skimmed by Grotty from Custom Works in lower hutt. Seems it had been leaking for some time thats for sure. took a bit of machining.
Also. managed to get water pump and head gasket from repco.
Dont normally use repco, but part master were fucking around. and I'm glad I did. Becasue they totally fucked up, and sold me the head gasket for $10 under there cost. Lol.
So thats my story so far. have some pics.
Strokers Life
Not bad for an oldish girl, besides being jacked to shit
Lovely
Blown
  • Replies 40
Average update. Got it running again today. Temp behaved nicely so thats good. Motor was a bit rattly in the top end. So ran it round to get it hot. Set the tappets. So hopefully that gets rid of most of it. However still have a few cunty problems that I had thought I had fixed. Mainly the exhaust leaks and the pulling to the left While braking. Rwbuilt the rear brake cylinders in a hope that was the problem. However. It was not. So had a look at the tyre on the left front. Has a bit of wear on the inside so am going to change it with the right rear one. And also grease the caliper slides
However I tjink its a wheel alignment issue. Which will suck if it is. Because I intend on lowering this after the wof. Which would need another wheel alignment again. But oh well.
Anywsy. Wall of text.
In an attempt to over come my pulling to one side issue, I rebuilt the rear brake wheel cylinders, as apparently it was dragging on the drivers side, so this seemed like it could be true.
Hover after rebuilding and re adjusting everything, it would seem that was not the problem
but anyway, today was a little bit succesful, kinda.
drained oil and changed filter, chuck in some desiel oil to help clean the motor out a bit, however, it would seem the 4 litre container i got was not enough to even get it reading on the dip stick. but started it anyway. After having adjusted the tappets the other day its oh so much quieter!!!!!!!!
Also pushed back front brake pistons so hopefully that will help with the pulling
Anyway, yay, hopefully be driving it tomorrow!!!!! again......
  • 3 months later...
  • 8 months later...
Hey!
heres an update.
Took this down to hamner springs
Went ok, but always smelt fummy, like gas was burning somewhere
Went to go to an os cruise up parmy way
got pink stickered
was a bit sad
so sort of thought about what I was going to do, get cert and try get one of my V8s in there was what I thought would be a good idea.
But this didn't happen, instead have decided just to fix the 5m, was running so rich the oil was getting thinned out, and as a result oil pressure was lacking
So, pulled off two main caps, and yeah, bit of scoring. So now its time to decided how far to go with the engine.
But firstly it needs to get pulled apart. managed to drag motor down to work today for a sunday mission.
And yeah.
yay crowns.
yay................
good afternoon
So a productive day, went to trenthan swap meat this morning, and then pulled my motor down
So far not looking to bad, someone has fondled the balls of this motor before, not much of a lip at all on the bores, and the big ends are 10 tho over sized,
So all in all ok, crank is a bit iffy from the lack of oil pressure, so not sure if going to get away just a polish, or if its going to have to be ground. very keen to not have it ground as that is heaps more work. but you can only do what you got to do.
Anyway, yeah, rad. head went in the stripping bath hang out over night and get most the shit out of it, will probably strip that down tomorrow night maybe, see if the valve seats are going to seal up ok.
So once I have measured the bores and have the crank looked at, can figure out how much shit I am going to have to buy etc.
And then the cleaning fun begins.
  • Like 7
  • 8 months later...
Gah, its easy to forget how much a conversion can cost when your are trying to sort out the whole lot at the same time haha
Just purchased EFI pump, fuel lines (need to replace all rubber lines for EFI hose), pipe fittings and hose clamps. Along with a fuel pump bracket.
Total of 253.60. Not to bad I guess
Actually think that is the most of the spending sorted now, Just need to do rear exhaust section, and some rear tyres.
Damn.........
Oh and buy a 32mm hole saw to do my clutch master cylinder mounting.
WHO DOES UP CARS!
Slash might need some recovery time before I start on the next one.......
So the pictures above relate to fitting the clutch master cylinder.
I pulled the setup out of my wagon, so this actually gave me a good way of making a template.
I basicly took a piece of cardboard and took a "rubbing" of the bolt holes and hole for the cylinder it self
This crown already had the bolt holes, but not the master hole. So after taking a rubbing, I traced it out with a pen, then used a compass to find the center.
If no one did this sort of stuff at school I will explain, basicly, take the diameter of the circle, then divide by half.
Set your compass to this measurement, and then scribe an arch from the outside of the circle in, do this in two places, and where the arches cross, is the center of the circle.
I did more than two for good measure (pun)
then, punch the bolt holes in the cardboard, taped it to the fire wall using the bolt holes as a reference. then center punched the middle of the circle, drilled pilot hole and hole sawed my 32mm hole.
Un fortunanlty cant fit cylinder yet, as I went to go fit it, and noticed a bit of weepage. opened it up and it needs a rebuild, surprised it worked at all to be honest! so have a kit coming Monday.
Also got my new fuel pump, fittings and bracket together, have found a place to mount it in the chassis, but need to make a plate for it to mount on.
Also started the replacing the fuel lines for EFI ones (showing the EFI proof writing for easy reading under vehicle)
And yeah, that, is where I am currently
Really need to get the floor sections welded up so I can progress, was hoping for this weekend, but work is oit of gas and from what I hear Boc have no argo shield atm
Plus have some other shit going on this weekend
But it really needs to be done during the day, as its a bit dark down the back of the shed...... this might put me back a week damn it.
UPDATE
I finally fucking finished the fuel system.
/ Just need to wire in the cable I have run to the relay which is yet to make it onto the car.
So pump is mounted, rubber hoses all changed, and shit like that
Oh and I rebuilt the clutch master cylinder today, so that went in along with the clutch pedal,
exciting right?
Pictures
pump wiring
Master and mounted
So, I finally managed to get over a mild stone, floors are now floors again after fucking around trying to arrange a time when I could borrow a welder (thanks TGB for the offer!)
now I just have the super un fun job of grinding it all back, welder was a cunt in spots, went super bird shit in one area. never figured out why. Oh well.
Atleast its done
looking forward to getting the drive shaft loops in and finally get the carpet and seat into this thing.
And
because this thread doesn't have enough pictures,
  • Like 9
10 days later and something else has happened!
Last weekend was out as I donated my Saturday to Driving Born loser Chris around, which was a pleasure
And then had oldnrustys 30th that night which fucked my sunday
So progress has been slow
But have a full day to play with tomorrow
However Wednesday I managed to get the floor sections undersealed, and installed the drive shaft loops today
so everything is coming along
  • Like 6
ALLLLLLLLLLLll RIGHT
Consider water blasting engine bay A Great Success.
Painted some degreaser stuff on Wednesday, figures crossed weather was going to be not raining Thursday. It wasn't, So woop, the blasting commenced.
Its amazing how much difference such a simple act can make. For the first time ever I found a chassis number for the car haha
Anyway, spent yesterday Fixing Nikis daily, so didn't get very far on this. Managed to drop the steering box and idler out of the car, so I can paint hat stuff gloss black. Then proceeded to paint the chassis with a light coat un under body seal in a can.
Maybe not the most best or showy stuff to use, but I like the matt colour and it sprays really nice and controlled.
Might try get another cost on it today. Then I can look at getting motor in next week.
Sunglasses.pdf
Oh And I pulled my brake master cylinder apart for rebuilding.
BEFORE
Middle
Inner gaurds I am going to paint with satin black, probably out of a can as setting up a spray gun is more fucking around than its worth.
This aint no Sheepers / Snoozin Build.
Oh Brake master cylinder insides for fun'
  • Like 6
