rivalrx
Rivalrx - 1972 Mazda 618 Coupe
74 posts in this topic
13’s
Muffler Lovin
Guards
Car mocked on Spitties
Steering
NOS v used
Before paint
Prep the bay
Another couple of primer filler coats then sunrise red
Suspension this week from Koni
Diff getting rebuilt and rear brake brackets sorted
GAME ON!
5 people like this
Share this post
Link to post
Soooooo I caved and tidied up my pedal box - passivated bits, paint and new rubbers….
The door window mechanisms got some lovin also
The door felt metal trim got a spruce up also - good old black paint anti rust
I painted the rusty door frame, as I am a firm believer of black door frames on RX2 coupes - as much as I liked the patina
Glass in and all rubbers excl the door card
Suspension is done any day now.
S5 13bt box has had another mod with MX5 remote shifter, so it should fit in the tunnel hole now.
Mazda 24 spline LSD rebuilt with 4:4 gear and new bearings etc
New rad and cooler coming up this week
Share this post
Link to post
5 hours ago, rivalrx said:
Will try and re post.....
Photobucket sucks ma bawlz
Yeap
http://www.iforce.co.nz/
9 people like this
Share this post
Link to post
I hope these pics load...... thanks for loading the previous ones
We shot some paint (Mazda Sunrise Red) on the engine bay finally.
It was a tad humid out that night therefore the paint has bloomed a bit here and there. This is no bother as we plan on doing another 3-4 coats plus some clear also.
Now we can see the trouble areas that I missed and get to sanding them flat.
1 person likes this
Share this post
Link to post
this was taken mid first coat - forgot to add it before
1 person likes this
Share this post
Link to post
24 spline old school Mazda LSD rebuilt with new bearings etc and a 4:4 crown wheel and pinion from an RX7. Should give it more snap from the old 3:9
5 people like this
Share this post
Link to post
After another rub-down, we shot another layer of sunrise red in the bay. Now there are only a few patches where you can see the sanding marks therefore yet another rub down will be needed.
The colour really deepened after the second coat and should be looking bang on after another couple. Somehow I have lost 1L of clear in my shed somewhere….FML.
The FXGT brakes/s2 RX7 discs are all fitted to the dummy diff and this all should be ready to bosch together this weekend. The discs were opened up on the lathe so that they fit over the ‘snout’ of the hub extensions which allows me to run my RX2 wheel centres.
Hoping that this weekend I can have the rear end rolling and the bay painted.
6 mates pooled in $80 each and we got ourselves a tyre changing machine and balancer off trademe - this is living in a mates shed and will give us free tyre changes for life.
9 people like this
Share this post
Link to post
After much contorting, sweating and swearing, the side glass and rubbers are all in on the coupe. I just need to fit the door cards and window felts and jobs a goodin.
I tore my hood lining the other day….sooo I’m having to buy another $300-$350. I’m not entirely looking forward to fitting it…
The engine front mount bracket has been ditched…..the engine was at 8 degrees which is way too much of an angle. This was due to the fact that I’m running a 13b turbo box (89-91 FC RX7) which is substantially taller in the main body than the series 1-3 box. This means it limits the angle as the top of the box contacts the tunnel roof.
I’m now getting a custom front bracket that will lover the block 5cm ish which puts the drive train at an acceptable angle.
The sump is sitting on a spacer 20mm off the cross member at the moment - now the clutch slave clears the tunnel.
Now I need to get a drive shaft made to suit and then set the entire drive train up so that I’m happy with all the angles. THEN the front bracket can be made…THEN the custom quad throttle body intake manifold can then be made to suit the angle of the block.
I got a drive shaft off a mate however it appears to be 20mm too short unfortunately - when you are talking about a high revving engine, you really want the drive shaft to be on point etc.
Yes I have a loop to go in.
I also tidied up and prepped the diff brake line and fitted a new hose I had hanging about the place
4 steps forward, 6 back….
3 people like this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
