clintus' Valiant Hardtop
kyteler
  • Replies 55
Also, once you have torn down that nipped up teen, I have a lead on VERY cheap overhual kits for SBM's.
I scored gaskets, big and and mains bearings, and hastings moly rings for $112usd. plus postage. And I'm up on the play with pistons too. The is an SBM Magnum piston, which has a wide enough distance between the pin bosses to accept an LA conrod. (An issue apparently) Which has a 1.755 compression distance. Much much better than the eye water-ingly low compression of 1.720 that most bargin basement psitons have. I even have some 40 over slugs with a 1.668! Which is so shit I wont even put the motor together.........
Jolly good show old chap!
one day (hopefully a long time from now) I'm going to inherit another hardtop.
Any leads on why it seized?
I am getting very mopar fizzed after helping the old man fit up his 340/418 SBM to his VF hardtop on sunday.
not sure why its siezed, was going to have a chat more about the history behind it when the guy has a bit more time, has been sitting since 1985 so might just be lack of use.
ahh.....unfortunately the purchase of this used up all my spare $ so im probably going to have to give OSN 2014 a miss now...... i just knew id kick myself on a daily basis if i didnt buy it
Noooooooooooooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You still have enough time to save for an air fare to CHCH.
And then you can bum a ride with someone. I intend to be moparing. (one way or another) So fly down, And I'll give you a ride. Nats without Cletus, would be like crate day without beer!
plan= pinch the stock carb/manifold/exhaust off the coupe and fit to the ute, sell ute.
rebuild the 318 out of the coupe, fit carb/manifold/headers off ute to 318, put in my white VG.
do panel, paint, half cage, tubs, etc and put turbo motor in coupe, do skids
this sounds like a sound plan, this thing will look and go awesome, pro street FTW!
  • 1 year later...
VE front clip would look awesome, would make it so much more like a dart!
You will need to shorten the VG front clip and or change the front support from memory. (VE guards bonnet etc are a bit different obviously)
Maybe just get it going first them think about it haha
