SR ROLLA
SR ROLLA's 1974 Mitsi Colt GTO
72 posts in this topic
When I put semi-sealed units in mine the locator tabs matched one of the cups and not the other cup. The units I used had thin metal tabs in a sort of a loop and I was able to manipulate the tab so that they fitted into the cup correctly. The difference in the cups is to stop people putting the wrong headlight in the wrong location so the high/low has different taps to single high. I put in two sets of high/low semi-sealed units and just running one set as high.
Shame about the rust/bog/dent.
Share this post
Link to post
Question with your seals...
Did you by the door seals off rare spares only?
Or did you also get the weatherstrip for the top of the door (called door belt as well I believe)
Trying to find that part for my 16L, including the rear seat side window belt seals
Share this post
Link to post
Hi, sorry for the slow reply, only seen these questions just now.
The only thing I've had from Rare Spares so far is the door rubbers. I replaced the brush seals (which run along the top edges of the doors and under the rear windows, I think that's what you're after?)direct from Mitsubishi NZ. Not sure if they will still have them, they only had a few left when I got those, which was a couple years ago now.
Share this post
Link to post
hey,
saw your post about breaks, i am currently in the process of getting my Celeste certed but i've turned down my hubs and used re drilled rx7 roters and Subaru calipers with a custom rear plate as you can still get the pads and roters for those.
can discuss further if interested.
Share this post
Link to post
Ah, Yes, The perfect wheel combo in my opioion
Gun metal, chrome lips and wheel nuts with white walls
Same as I rock on my C20 Van
Top work. this looks rad as hell
Share this post
Link to post
What you have is a brochure for the English market. They probably had different colours.in the Aussie/kiwi market.
Share this post
Link to post
take your fuel flap into auto industrial and they will match some paint and put it in a rattle can for you. its not cheep but ill be the right colour.
http://2cu.co.nz/auckland/listings/62464-auto-industrial-supplies-ltd
pay to give them a ring and talk about what you're after. they are usually pretty busy so see when they can do it.
Edited by sheepers
1 person likes this
Share this post
Link to post
Take your fuel flap off - or some other small removable panel - or the whole car in
Id image theres a few paint suppliers up there can do it. But they can do a spektro (?) match, we have a couple places down here that can do it.
Spray store, RJ Patersons down here do it
Share this post
Link to post
Best bet as others have said is get it colour match. My 75 has Himalayan Blue, but my 76 originally had Tahitian Blue. I suspect your car was/is Himalayan Blue AC10178. NZ cars came with the standard JDM colours plus a few extras like gold and yellow. A good guide to the colour options strips can be found at http://www.galantgto.net/option-stripe.html
By the way the wheels and whitewalls look great.
1 person likes this
Share this post
Link to post
Thanks, that's a handy reference.
Looks like I need to research more carefully and spend the money to do jobs properly/go to the right people. Shocking.
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
