robs30m Posted March 7, 2013 Author Share Posted March 7, 2013 Quote Link to comment Share on other sites More sharing options...
robs30m Posted March 7, 2013 Author Share Posted March 7, 2013 Heres a pic with the sides on, i prefer it i think, opinions? Quote Link to comment Share on other sites More sharing options...
robs30m Posted March 7, 2013 Author Share Posted March 7, 2013 Picking her up! The Diamante towed it fine even though i was a fair way over the towing capacity. Glad i installed a trans cooler! 1 Quote Link to comment Share on other sites More sharing options...
Guest robs30m Posted March 18, 2013 Share Posted March 18, 2013 Shortened deck down, after removing tired ply. Still thinking of decking options. After! Quote Link to comment Share on other sites More sharing options...
Guest robs30m Posted March 21, 2013 Share Posted March 21, 2013 Interior shot, made some mats for it, general clean up. Quote Link to comment Share on other sites More sharing options...
Guest robs30m Posted March 21, 2013 Share Posted March 21, 2013 Ive been using black guard rust converter and primer to coat the under tray area, chassis, and the back of the cab. Welding on deck rear piece, then light brackets and plate bracket this weekend. Ive found some quila decking timber to line it. Been cleaning up wiring too. also derusted and converted the brake booster area in the engine bay, must of had a fluid spill as paint was gone. Quote Link to comment Share on other sites More sharing options...
Guest robs30m Posted March 25, 2013 Share Posted March 25, 2013 Machined up new steel bushes for leaf spring shackles. There were tired nolathane ones in the rear, and after reading in manual that stock ones were steel , Decided to make some , had work mate turn them down, then i finished on my mill. OD is 22mm, ID is 16mm, lenth is 56.5mm. Fitted nicely with new spacers. i used conical spacers so they had less contact area with bush and shackle. They are a press fit on spring and mount, and a loose fit on shackle. New bushes old versus new (fronts were still origional steel) fitted on shackle to check finished tool i made to press originals out, also use parts of this to adjust draglink. Quote Link to comment Share on other sites More sharing options...
Guest robs30m Posted March 30, 2013 Share Posted March 30, 2013 Ha i could do, need more money! Heres a pic of the beast at a Greerton Car show, i won a digital camera was stoked! and heres rear lights done, tray welded, needs decking now! Quote Link to comment Share on other sites More sharing options...
Guest robs30m Posted April 17, 2013 Share Posted April 17, 2013 New tray lining been fitted, rough mock up at this stage, needs finishing, staining etc. thats if i use this timber. hardwood would be nice. not fixing anything down yet, its handy been able to access chassis etc. did alot of wiring to rear lights and tidied it all up. remounted electric fuel pump and filter next to tank. Quote Link to comment Share on other sites More sharing options...
Guest robs30m Posted April 17, 2013 Share Posted April 17, 2013 few pics! took her for an offroad trip, with a mate, decided its going to be the last heavy trip it does, took me so long to clean all the mud out of her, to get her mint and clean again. its to rare to use for heavy offroad. looking good though i think!!! 1 Quote Link to comment Share on other sites More sharing options...
robs30m Posted May 8, 2013 Author Share Posted May 8, 2013 I removed the top, with the aim to replace rusted bolts, fix some minor rust bubbles around windscreen that the hardtop covered, and maybe re gelcoat fibreglass roof. i love it! drove it to work, was awesome. got a few looks...... plus one cop who didnt seemed fazed lol 3 Quote Link to comment Share on other sites More sharing options...
robs30m Posted May 8, 2013 Author Share Posted May 8, 2013 Â %20pics/IMG_3659_zps9e04ce32.jpg.html][/url] 2 Quote Link to comment Share on other sites More sharing options...
robs30m Posted May 18, 2013 Author Share Posted May 18, 2013 so have sorted out clutch issues i had, all the linkages and clutch slave cylinder was worn. sorted that out, plus flushed system, feels nice now. you can remove a large inspection plate and see whole clutch and flywheel assembly, without removing box. today i cleaned up few rust bubbles along top of windscreen, sealed it up with silicone and applied a foam rubber strip to act as an isolater between the windscreen frame and fibreglass top, also did this to base of roof where it blots down, its alot quieter now, less rattling and vibration. trying to get stuff sorted for the first OS Tauranga meet on the 5th of june. looking forward to it!!!! Quote Link to comment Share on other sites More sharing options...
robs30m Posted May 18, 2013 Author Share Posted May 18, 2013 1 Quote Link to comment Share on other sites More sharing options...
robs30m Posted May 29, 2013 Author Share Posted May 29, 2013 Heres some new pics, gave her a cut and polish, followed by a wax. suprised how the paint came up! also secured deck down and coated it with polyurethane. I was going for a lod school kinda look ie old farm truck, and im happy how it looks. didnt want the the deck to outdo the paint! Â Â Â 1 Quote Link to comment Share on other sites More sharing options...
robs30m Posted May 29, 2013 Author Share Posted May 29, 2013 1 Quote Link to comment Share on other sites More sharing options...
robs30m Posted June 4, 2013 Author Share Posted June 4, 2013 Finally got around too cleaning up the surface rust in the engine bay, it had formed where there was a brake master cylinder leak. paint had been taken off. i rust converted the area awhile back, and now applied a rust primer paint i tinted as close to origional as possible. Â Â Â 2 Quote Link to comment Share on other sites More sharing options...
robs30m Posted July 8, 2013 Author Share Posted July 8, 2013 well been busy cleaning and degreasing engine. also inspected and repacked rear wheel bearings. waiting on new rear brake shoes. need to make a new brake line too. close to ready for a wof check. oh please like and keep an on on nz blokes. co.nz Facebook page. my patrol is car of the day today! Quote Link to comment Share on other sites More sharing options...
robs30m Posted July 9, 2013 Author Share Posted July 9, 2013 Quote Link to comment Share on other sites More sharing options...
