toy-mota Posted October 26, 2013 Author Share Posted October 26, 2013 page Quote Link to comment Share on other sites More sharing options...
toy-mota Posted October 26, 2013 Author Share Posted October 26, 2013 so have been busy piecing the crown back together,and the 2jz turned up this weekend so work begin stripping all the stuff i dont need off it,worked at chop shop speeds!! parts for sale.... power steer pump,A/C pump,exhaust manifold and the top of the intake manifold disscuss here //oldschool.co.nz/index.php?/topic/36351-toy-mota-1971-toyota-ms65-crown/ Quote Link to comment Share on other sites More sharing options...
toy-mota Posted October 28, 2013 Author Share Posted October 28, 2013 busy weekend doing fuck all,went to install my door seals and window channel and they dont fit so not very happy,so fittted some more and drunk some more rum also tossing up weather to put my personalized plates on,cause if i carnt get it put back on the black plates in the future i wont be keen,what you reckon is better Quote Link to comment Share on other sites More sharing options...
toy-mota Posted November 24, 2013 Author Share Posted November 24, 2013 process on the crown has been slow but getting there,should hopefully have a wof in the next couple of weeks.all that needs doing is sill chrome,inner guards fitted,a massive clean inside and out aqnd the back bumper put on.will lower it after its warrent. Quote Link to comment Share on other sites More sharing options...
toy-mota Posted December 1, 2013 Author Share Posted December 1, 2013 fresf wof and a years rego,what a joy it is to drive it again,i did some cruzing round the streets of chch on friday/saturday nights and had a ball of atime,the response from everyone else was great.Being asked if it was a ford or datsun most of the time.Also got to see some oldschool cars out (no photos tho) 1972 corona,1975 hiace,ke30s and SKDMRX which made my night.after finally seeing this car in the flesh and talking to john,what a piece of art and sounds amazing.was able to grap a quick snap 1 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted December 23, 2013 Author Share Posted December 23, 2013 so the crowns being running beautifully up until a week ago,the clutch started slipping and the motor just dies and has no power,so up on axle stands it goes over the xmas hoildays to try and get sorted.not to sure whats going on with the motor.the dizzy cap in the centre were the coil lead goes into was burnt out,replaced that it ran fine again for a day and now it cuts out wont idle.is this a fuel problem or timing? it does run rich abit. Quote Link to comment Share on other sites More sharing options...
toy-mota Posted March 4, 2014 Author Share Posted March 4, 2014 been awhile since an update.fixed the carb issue-it was completely blocked up,so a clean out was done and all is running sweet.Finally got round to lowering her,i got the springs compressed 75mm all round to drop it down to the legal 100mm.its my first time owning a car that scraps on bumps so the exhaust has been getting a hiding round the chch roads. last weekend the crown and fawty spent together,the fj40 got sold to a guy in hastings. crown at the performance car magazine meet up in new brighton,also made this months issue -so stoked discuss here //oldschool.co.nz/index.php?/topic/36351-toy-mota-1971-toyota-ms65-crown/ 2 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted June 7, 2014 Author Share Posted June 7, 2014 abit of work has been happening lately.motor is at the rebuilders getting some work done. i got some custom pieces laser and waterjet cut 10mm itb flange,the mounting holes were scribed by the machine and i drilled and tapped them,installed helicoils for stronger thread these pieces are for my rocker covers,and the teq logo is going were my belt tensioner use to sit as im not needing it discussion thread--->//oldschool.co.nz/index.php?/topic/36351-toy-mota-1971-toyota-ms65-crown/ 7 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted July 6, 2014 Author Share Posted July 6, 2014 productive weekend,exhaust leaks fixed for a wof so now i can take it to the hamner meet.Also starting my 2jzgte to 2jzge rocker cover conversion,the mounts are completely different, i just cut the old ones off and had new ones lazer cut,and i just tig welded them on.This is the first project where ive got to use my tig and learn how to do it,was pretty fun once i started getting the hang of it.a 3mm steel plate jig was made to bolt everything down and keep it all flat chur 3 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted July 10, 2014 Author Share Posted July 10, 2014 Had the last couple of days off work with the manflu and took advantage of the time finishing off the rocker covers.I welded on some an10 fittings for a breather catch can,added my lazer/waterjet cut pieces,these are joined on buy using 1.5mm brass rod tapped through a 1.5mm hole then used loctite retaining compound to hold the pieces together.Sent them off to get the mounts milled down as they pulled a little from welding.When i get them back ill bead blast the outside,paint them VHT wrinkle black then sand the paint of the high bits. discuss here ----> //oldschool.co.nz/index.php?/topic/36351-toy-mota-1971-toyota-ms65-crown/ 6 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted July 15, 2014 Author Share Posted July 15, 2014 so just bought some trumpets from SQ Engineering in oz,a specialist in 4age gear.he also turns up trumpets,he custom made a set of 6 for me 100mm long with a bellmouth size of 87mm,they have shaved edges to make them fit like these -> his trumpets work out cheaper than trademe,even with the extra machining and shipping.heres a link to his site----> http://s-86.com/velocity_stacks.php will post pics when they turn up 3 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted August 2, 2014 Author Share Posted August 2, 2014 wee update,motor is nearly reconded.trumpets have turned up and just got some new rims,even got to run my toyota center caps still ruff mock up "selfie" new rims.14x8 center lines with little stretch 205/55 4 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted August 3, 2014 Author Share Posted August 3, 2014 ......................discuss here....................... //oldschool.co.nz/index.php?/topic/36351-toy-mota-1971-toyota-ms65-crown/ Quote Link to comment Share on other sites More sharing options...
Popular Post toy-mota Posted September 22, 2014 Author Popular Post Share Posted September 22, 2014 Picked up the 2jz in the weekend after sitting at the rebuilders for months on end.first thing was put it on the stand and try out the itbs and rocker covers.pretty happy with the first mockup fit.also got a new dslr camera for better pics but still trying to work out the settings so goal is to get all the parts made then put it in storage while im away in canada for a year then come back and rip into it comments/opinions/thoughts are most welcome 15 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted September 24, 2014 Author Share Posted September 24, 2014 Progress over the last two nights.Dizzy cleaned up and fitted.Rocker covers now fit just waiting on new oem seals this weekend along with waterpump,hopefully paint them this weekend depending on weather.Front TEQ logo all made just needs paint and polish.i was thinking about back lighting it with some white LEDs..thoughts? also cut up the 1jzgte oil cap to adapt to the more suited 4m cap which will get a fresh zinc plating. 5 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted September 24, 2014 Author Share Posted September 24, 2014 discuss //oldschool.co.nz/index.php?/topic/36351-toy-mota-1971-toyota-ms65-crown/ Quote Link to comment Share on other sites More sharing options...
Popular Post toy-mota Posted October 17, 2014 Author Popular Post Share Posted October 17, 2014 Maybe one of the last updates before it all gets chucked into storage for year while im away in Canada.i painted the rocker covers with black VHT wrinkle paint and i got the effect i wanted on the top and partially on the sides,the rest just gave a flat finish,i followed the instructions doing 3 heavy coats in a cross pattern,so now im not to sure on how to fix this,maybe put the covers on there edge? nearly there getting the retro 70's look that im after,should look sick in the bay of the crown 27 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted December 12, 2014 Author Share Posted December 12, 2014 A couple of pictures from its last outing. (edited in photoshop) 3 Quote Link to comment Share on other sites More sharing options...
Popular Post toy-mota Posted July 5, 2015 Author Popular Post Share Posted July 5, 2015 Finally have the old girl back home.Starting to get all the bits together to pull the engine and box out.Ive been working on it mainly at smoko at work,making little bits and welding up the intake manifold.Also have redone the rocker covers in a flat black powder coat finish as i wasnt happy with the out come of the VHT wrinkle paint. 19 Quote Link to comment Share on other sites More sharing options...
toy-mota Posted July 26, 2015 Author Share Posted July 26, 2015 productive weekend .stripped the new w58 gearbox to inspected the internals.the rear bottom bearing had colapsed,it was missing 4 ball bearings and the cage which has then managed to get into 5th gear as thats missing half a tooth,but im thinking it should still be fine to use? gears 1-4 are still solid.So new seals and bearings for the box and it should be a runner.Also removed the engine and box from the car,everything went smooth and now the fun begins making the 2jz fit. So i have a 4m and 2x w50 boxes for sale //oldschool.co.nz/index.php?/topic/49374-fs-4m-2x-w50-gearboxes-chch/#entry1559794 discuss here ... //oldschool.co.nz/index.php?/topic/36351-toy-mota-1971-toyota-ms65-crown/?hl=%2Btoy+%2Bmota 7 Quote Link to comment Share on other sites More sharing options...
