flyingbrick Posted February 22, 2013 Share Posted February 22, 2013 Just use a pencil blow torch or grunty soldering iron to heat little loctited screws to enable removal easy Quote Link to comment Share on other sites More sharing options...
Goat Posted February 23, 2013 Author Share Posted February 23, 2013 I ended up using blue locktite. SHould i pinch the exposed thread with some pliers for extra safety? I should have just done what chris said, pull out dem chokes, as i never use them anyway. Hah Chair for all the opinions! Quote Link to comment Share on other sites More sharing options...
Goat Posted February 23, 2013 Author Share Posted February 23, 2013 Got some sweet grips from dime city. Needed a bit of modding to fit the bar ends. Had awesome eagle on them. I'm not really worthy of that manlyness so i had to cut them off... Tested fit on my clipons. Look smick. Shiny cap screws from Costal Fastenings in wellington. 20bux all up. I pulled down and reassembled the carbs. Replacing EVERY screw with stainless cap scre, including all the internal ones that hold the slides etc. All new seals, jets and needles too. These should be good to go... Some mech in the stacks to stop the big bits. Yummy undersides: Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted February 23, 2013 Share Posted February 23, 2013 Ohhhhhhhhhhhhhhhh! Looking so damn fine ! Quote Link to comment Share on other sites More sharing options...
Goat Posted March 3, 2013 Author Share Posted March 3, 2013 Had a weekend with my sheet metal and welder. Got cracking cutting and welding. Man my hands are sore after snipping through all that sheet metal.... Anyway, some pics.. Tracing templates onto sheet metal. (This is another design i made up last week. As the one pictured earlier in this thread wasnt looking like what i wanted. Folded up base pan. Folded this over my leg... Cut out dem sides: Mockups: Weld weld All tacked up. Looking good. Put on bike, i think the base looked high: I like the side profile, was umming and arring about the height of seat base for a bit. Made this to hold all the electrics. This will sit in under the seat. Used the mount points alreade there where the battery box andfilter housing are sitting (now binned). Not missing corner as it only had mounts on one side and a tabe to support it on the other. Fits like a boss, and will be sweet to hold all the required bits out of sight: After cutting the seat base shorter i think it looks alot better. Also cleaned up all the welding etc Also made up mount to drop the clocks. (Theyre about 110mm lower than stock... Have also been toying with the idea of lowering it a bit. THis is where it would sit with 11" shocks. Reckon i should do this? or just keep it at the stock height (in earlier pics) Next weekend i should finish the seat and then move all this stuff to the running cb (in wellington). Its great having parts bikes for mockups. So Ken for nats! 2 Quote Link to comment Share on other sites More sharing options...
KIRK Posted March 3, 2013 Share Posted March 3, 2013 looks cool Quote Link to comment Share on other sites More sharing options...
kicker Posted March 3, 2013 Share Posted March 3, 2013 Rad, coming along nicely. Those carbs look uber sexy in real life Quote Link to comment Share on other sites More sharing options...
AndyGal Posted March 4, 2013 Share Posted March 4, 2013 Lowering is good! 2 Quote Link to comment Share on other sites More sharing options...
Rookie Posted March 4, 2013 Share Posted March 4, 2013 ^This man, he knows.... 1 Quote Link to comment Share on other sites More sharing options...
Guest Goat Posted March 25, 2013 Share Posted March 25, 2013 Update! I have been busy. Rebuilt front shocks with new seals. Need to slam it at the front some more. Put carbs on. Put new rear shocks on. Hid all electrics. Dropped the clocks. Dropped the headlight. Put on my clipons. Put on cb350 tank. This involved major surgery to get to fit. Still need to do a bit of modding. But its about 80% complete. Todo: Solder up idiot lights and make a bracket for them (LEDs) Finish adapting cb350 tank Balance carbs. Add a brake light Mount number plate Mount muffler New brake hoses Drill Disk Rear indicators Paint seat to match tank. haggard spec Get seat apholstered Burnouts ANyway, Pics: Before: After: So yea, not much to do. Roll on nats! 5 Quote Link to comment Share on other sites More sharing options...
Guest durty Posted March 25, 2013 Share Posted March 25, 2013 Omg. Hot Quote Link to comment Share on other sites More sharing options...
Guest Toucan Posted March 25, 2013 Share Posted March 25, 2013 Looking sweet joe Quote Link to comment Share on other sites More sharing options...
Guest anglia4 Posted March 25, 2013 Share Posted March 25, 2013 Those bars look even more comfortable than mine... naaaaaaaaaahhhhhhhttttt!!!! Quote Link to comment Share on other sites More sharing options...
Guest kicker Posted March 25, 2013 Share Posted March 25, 2013 That is badass! Quote Link to comment Share on other sites More sharing options...
Guest thegreatestben Posted March 25, 2013 Share Posted March 25, 2013 phwoar that's looking swell. Quote Link to comment Share on other sites More sharing options...
Guest Rookie Posted March 25, 2013 Share Posted March 25, 2013 Good work Joe, Keep it up. Quote Link to comment Share on other sites More sharing options...
Guest Seedy Al Posted March 25, 2013 Share Posted March 25, 2013 saw this in person sat night and had a sit of it. so fucken cool. Bars are in fact a decent location. dont have to much weight on them at all Quote Link to comment Share on other sites More sharing options...
Guest Sparkle Posted March 25, 2013 Share Posted March 25, 2013 Wow. Quote Link to comment Share on other sites More sharing options...
Guest Bullitt Posted March 25, 2013 Share Posted March 25, 2013 Looks great Joe. Maybe I've missed it but other than the mesh in the ram tubes is there anything to stop everything being thrown off the back wheel ending up in the engine. I just know how filthy that area ends up on my much more standard bikes. Quote Link to comment Share on other sites More sharing options...
Guest Born Loser Posted March 25, 2013 Share Posted March 25, 2013 Looking Gnarly dude! Keep up the hard work! really excited about the amount of bikes that are gonna be at nats Quote Link to comment Share on other sites More sharing options...
