GuyWithAviator's 1974 Austin 1300
  • Replies 105
Right, page 6!
Ever since I got the car (and it's been getting progressively worse over the years) there has been a knock under the passengers floor when going over bumps.
Did some reading and found out there's a bush in the steering rack that wears and lets the rack move in it's housing. Luckily Nolathane make a replacement.
Picked up one of those and set about the arduous task of removing the rack - involving dropping the subframe for clearance.
31627673384_ba13b03239_b.jpgUntitled by GuyWithAviators, on Flickr
This is the old bush (got damaged while removing but half of the material was gone anyway) compared to the new one.
31627672474_b2525b6c1b_b.jpgUntitled by GuyWithAviators, on Flickr
And in...
32092704520_9de2c9af47_b.jpgUntitled by GuyWithAviators, on Flickr
And now the fun part, put it all back together and in the car. The knocking noise is gone, great success! Wheel alignment is out, no biggie.
...But there's now a little too much (i.e more than none at all) play in the steering wheel when starting to turn it, along with a nasty grinding noise at the start of the movement. So this morning I took the rack back out - and found this broken rack spacer, must have chooched the U bolts up too tight. But I don't think that would have caused it, I couldn't see the rack moving underneath the car - seemed more internal.
32349472211_e123636d3b_b.jpgUntitled by GuyWithAviators, on Flickr
Also found one of the bearings within the pinion assembly had a little play so will track down a better one of them and muck around with the shims also. Was a little low on oil also after it all fell out while trying to manoeuvre it back into place.
If anyone else has experience with these BMC racks and excessive play please give me your wisdom!
Discuss: //oldschool.co.nz/index.php?/topic/35012-guywithaviators-1974-austin-1300/&page=11
  • 1 year later...
Yearly update. Didn't drive this as much as I'd have liked but got it a wof.
Then one day when pulling out of a driveway the steering locked breifly and I lost all oil pressure. Odd.. Quickly pulled into the cloest carpark and could smell hot oil. Uh oh.
Leant under the car and yup. When have we seen this before :rolleyes:
On 31/08/2014 at 14:07, GuyWithAviators said:
If you're driving down Bealey Ave / Papanui Road in Christchurch today my apologies for the huge trail of oil...
The diff decided some parts were better off outside of it's casing. Not really sure what/why happened yet. It's strange though because it made a loud clunk (I assumed it was just Chch's roads) and continued driving fine but then I noticed the oil pressure light come on so stopped.
Will have to take the motor out and split the block and gearbox. Luckily I have a spare gearbox but it's a pain :angry:
Note the bowl I went and begged the takeaway shop I pulled up outside for :cyclopsani:. This time it was just a hole in the diff casing, not the gearbox side also. Now I guess time to pull the engine out and see what's up.
42122187_474724053046973_6186160607541067776_n.thumb.jpg.dacdf23467fd5e44bd7702add389a17d.jpg41991997_717906655212463_1779440221004234752_n.thumb.jpg.7c339137885e5782d44e4201bc4a552e.jpg42058737_231016834439133_2571237559648649216_n.thumb.jpg.4a3e89d804ec354824aea4224fcf47bb.jpg
  • Sad 2
Let the car sit and think about what it'd done then got into pulling the engine out with help from @Shakotom & @Raizer. Getting way too quick at doing this..
Split the block from the gearbag and found the broken bit. But what happened next will shock you!
41942285_1967698189962320_3352402689571946496_n.thumb.jpg.7af3bbdad116ced15505904b2eecf38e.jpg
Zoom, enhance.
41850520_766125553729644_9218305624712937472_n.thumb.jpg.f857384495588cf608276adaa45a3a92.jpg
So, broken spider gear and a crank thrust washer (?!).
Checked the crank in my engine and it has all of it's washers... So this one must have always been floating around in the bottom of the sump underneath the gearset from a previous rebuild I suppose?
Anyway, checked for other damage and everything else seemed fine. I had an entire spare diff head assembly in stock and a casing so swapped all of that over. Counted the teeth of the final drive and it matched also - as I'm not sure what parts I have from Mini, A+ gearboxes or 1100.
Put engine back into car, end of job right? Not quite! Stay tuned for part 2.
  • 4 months later...
