jtkp61 Posted August 16, 2012 Share Posted August 16, 2012 New project of mine, 4 speed manual 50cc with a clutch. Bought seized and my mate Josh (fliboi) and I are starting to rebuild her. More pics to come, only know of mine and one in Wellington. Keen on ideas for paint to, thinking of going grey / black but give me some feedback. Cheers Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted August 16, 2012 Share Posted August 16, 2012 Yup one in the window of Boyal kawasaki in Wellington Looking forward to more pictures Quote Link to comment Share on other sites More sharing options...
felixx Posted August 16, 2012 Share Posted August 16, 2012 This is cool Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted August 17, 2012 Author Share Posted August 17, 2012 Cheers Felixx, (btw I'm Jack I work with Josh at Super Cheap). Itl be sitting out side work in summer parked up next to Joshes cub Quote Link to comment Share on other sites More sharing options...
felixx Posted August 17, 2012 Share Posted August 17, 2012 Cool, I know who you are jack.. you helped me out/ took my $$ for my compressor! Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted August 17, 2012 Author Share Posted August 17, 2012 Yeah yeah thats me haha. Compressor treating you well? Quote Link to comment Share on other sites More sharing options...
felixx Posted August 17, 2012 Share Posted August 17, 2012 yup surely is thanks Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted August 17, 2012 Author Share Posted August 17, 2012 Nice, what colour are you painting the Anglia? Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted September 1, 2012 Author Share Posted September 1, 2012 Still looking for colour ideas, still keen to roll with old school black and grey. Just sorting out the wiring and the re-charge system so I can get it running mint. Will be awesome to get it out over summer. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted September 1, 2012 Share Posted September 1, 2012 needs points and to work out why it eats battery's and leaves them unable to charge anymore. might just be deep discharging them? Quote Link to comment Share on other sites More sharing options...
felixx Posted September 1, 2012 Share Posted September 1, 2012 try phil at belfast auto electrical Remind him he told me he would look after the old school boes Quote Link to comment Share on other sites More sharing options...
NaN Posted September 1, 2012 Share Posted September 1, 2012 needs points and to work out why it eats battery's and leaves them unable to charge anymore.might just be deep discharging them? direct current short. something in the 10amp region, or more. check the condition of the starter motor cable, remove all the fuses, and then unplug the main cable, see if you get a spark, if you do try and test it with a multi meter, see how much current various circuits are drawing with no key in it. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted September 1, 2012 Share Posted September 1, 2012 currently its running bare essentials. rectifier from the engines ac circuit, into the battery. and off to the coil. but i only just put the rectifier on, and have been running straight off a battery and it eventually flatens them, i think thats the problem Quote Link to comment Share on other sites More sharing options...
NaN Posted September 1, 2012 Share Posted September 1, 2012 yep. that would do it. Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted September 1, 2012 Author Share Posted September 1, 2012 Cheers Felixx may be worth a trip out that way Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted September 1, 2012 Author Share Posted September 1, 2012 By the way, nigelwade cheers for sharing your knowledge cant wait to get this beast running mint Quote Link to comment Share on other sites More sharing options...
NaN Posted September 1, 2012 Share Posted September 1, 2012 your welcome, when I'm looking for a drain on a battery I start by making sure the battery is well charged, the I test the voltage with nothing connected (lets say 12.2 volts). Then I run the motor, and see if I'm getting 13.8 (ish) volts, (is it charging), Then I turn the motor off, and leave everything connected. (testing 11.5volts), ok, so now I ~know~ there is drain. (and it's not a bad battery: which has just been charged gives a good reading, then drops a cell batteries have 6 cells usually, each 2 volts(ish)=12volts, not uncommon for one to die) Then I drop the main cable, not the starter motor one, test again (12.2) ok so the starters fine. Reconnect the main cable, and rip alot of relays and fuse out, and then have some one watch it while I put them all back in one, by one. (~boring~). Hello, my helper says when I installed the ~who-dang-whats-it~ fuse it dropped to 11.5 volts, and there is the faulty thing/bad cable etc/thing which is on and should not be, sorry for the odd way this is written, it's 8am on sunday half awake, yet to have a coffee, it was just easier to write this way., Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted September 2, 2012 Share Posted September 2, 2012 makes perfect sense. had a laugh at things like starter motor, such luxuries are unheard of in thee bikes i work on since im just running the coil at the moment, im pretty sure its not getting a charging current from the engine, will get the batterys sorted and take to it with my multimeter. i wired up my c90 in the same style and every things gone perfect, except this bike ate the battery for it haha Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted November 7, 2012 Author Share Posted November 7, 2012 Bike starts stronger now, still having charging issues. Emailed boyle kawasaki with no reply. Is it worth giving them a ring? Quote Link to comment Share on other sites More sharing options...
felixx Posted January 9, 2013 Share Posted January 9, 2013 I like this bike, but dont have the $ sorry 1 Quote Link to comment Share on other sites More sharing options...
